820-3435-B THSP Thunderbolt proximity temperature sensor problem
+ More Options
Posts
  • mantza
    • Sep 2020
    • 36
    • GREECE
    hello, i have this board have replaced smc u5000 and u5810 but it is slow and goes high fan after a few secconds
    in asd it gives this error
    Sensor-Temperature THSP Thunderbolt proximity test 1
    error sensor is reading below the low limit
    any clues?
  • piernov
    • Jan 2016
    • 4436
    • France
    Re: 820-3435-B THSP Thunderbolt proximity temperature sensor problem
    Only error when continuing on error?
    https://logi.wiki/index.php/Mac_sens..._2013_820-3435
    • mantza
      • Sep 2020
      • 36
      • GREECE
      yes
      • CapLeaker
        AcuRite 5 in 1 temperature sensor replacement repair
        by CapLeaker
        Got a new victim:
        AcuRite 5 in 1 Iris outdoor weather station not updating the temperature / humidity anymore. The original sensor is a SHT21. Also there are identical other sensor manufacturers. I chose the HTU21D to replace the original SHT21. Both have identical specs. I've had two failure modes with these sensors.
        A: outside temp stuck at -40? It's cold here at times in Canada, but not that cold!
        B: stuck at some temperature and maybe updating once in 12 hrs or so.
        Easy solution is to go to AcuRite website and purchase the sensor. Right?...
        04-15-2025, 01:32 PM
      • groomit
        Google Pixel 5 - Proximity Sensor Issues - Reflow/Replacement procedure tipps wanted
        by groomit
        I just replaced the battery on a Google Pixel 5.
        After that the proximity sensor isn't functioning properly any more. It is constantly activated. So when playing a voice message on Whatsapp, the Screen instantly turns off.
        Checking with a sensor app I can verify weird behavior of the sensor. It is triggered when nothing is near and sometimes works correctly when squeezing the phone next to the sensor hole.
        The rubber seal is on again (as mentioned in various suggestions in other forums).
        This smells like a cold or broken solder joint. So I'd like to reflow...
        06-11-2025, 02:21 AM
      • drake441335
        OLED65G6P-U.BUSWLJR Temperature sensor issue
        by drake441335
        I am a very beginner at tv repairs. I am trying to fix my tv before I end up buying a new one. I do not know names of boards, but I will do my best to explain what I have done so far.
        Tv is an LG OLED65G6P manufactured in april 2016. I had a warranty on it till September of 2021. Warranty is done. The problem I am having is when I turn the tv on after about two or so minutes a popup comes up and says the temperature sensor issue, and then it powers itself off. The tv works as designed, picture, sound, wifi, settings and everything, before it just powers itself down.
        So i did what any...
        02-13-2022, 03:34 PM
      • ErParucca
        Thinkpad X390 (motherboard NM-B891 shared with other models) : battery sensor reporting wrong temperature -> sudden power off
        by ErParucca
        I have a thinkpad X390 that would work fine if not for a problem: sensor temp5 (battery as far as I know) shows variable values over 100° C. When it reaches higher temps (I guess 110° as I was able to list temperatures up to 109°) it simply powers off. All other sensors show 0° except for the CPU which seems to report correct temperatures.
        In a wishful thinking I hoped replacing the battery (as far as I know the temperature sensor is in the battery) would fix the problem, but it didn't.
        Given this situation I can't even upgrade the firmware as the machine powers off...
        07-10-2025, 10:46 AM
      • Windows8RTMUser
        Repair knowledge for -55c CPU temperature on AMD Ryzen CPUs in bios, the AMD Sideband temperature sensor interface (SB-TSI)
        by Windows8RTMUser
        Recently I came across an x570 Aorus Elite where the temperature in bios was reporting -55c, i had checked the CPU_TEMP line connected to the IT8688
        In my particular case, the SIC line going to the X570 chipset (PM_SIC) was shorted to ground, so far disconnecting the 0 ohm resistors connecting APU_SID and APU_SIC to the chipset has fixed my -55c issue, it seems like -55c is the fallback reading for CPU_TEMP which is just pulled up to VREF on most gigabyte motherboards
        I wanted to post this as even the ever-reliable vlab forum was stumped on this issue
        tags:...
        07-28-2025, 07:26 PM
