Macbook A1466 trackpad flash ROM burned
  • marce002
    • May 2018
    • 316
    • Argentine
    Hello
    Trackpad and keyboard not working... a close up shows this IC (: Serial Flash memory) burned
    Is it a direct replacement job after buy? or it needs to be programmed after... since it is a flash menory...?
    Maybe available in another donor motherboard non apple, even if it is not same size package? i
    I do not want to replace whole trackpad.
    Thanks in advance.
    Marcelo J
  • mon2
    • 14659
    Re: Macbook A1466 trackpad flash ROM burned
    While we have not studied the track pad design...this flash memory component will contain some firmware code.
    This code is the local operating system for the embedded stand alone track pad design. As you use the track pad, the track pad module streams out the x,y coordinates of your touch actions to the main logic board.
    Best to source another working track pad but you may get lucky to clone the chip but will need some work.
    The trackpads get damaged easily due liquid spills, etc.
    Believe the trackpads are about $30.
    • marce002
      • May 2018
      • 316
      • Argentine
      Thanks i will do... but in the meantime remember this left me with no keyboard too and the problem is that it can work perfect with external usb genius mouse and keyboard kit but it is Extremally slow! I know this happens when no keyboard is not connected because no thermal feedback is sent back ( i think).. but in my case how can i bypass this to have full speed ?? maybe resistor R5290 and R5291 ? ( the cpu is normal and cool for sure).. thanks
      Marcelo J
      • marce002
        • May 2018
        • 316
        • Argentine
        removed r5410 to leave the u5410 without vdd but same results..spin increasing until too fast. thanks
        Marcelo J
        • marce002
          • May 2018
          • 316
          • Argentine
          ok by now just removed the offending chip from trackpad and the problem is solved... of course no working trackpad but CPU and fan works fine now
          Marcelo J
          • mitchw
            MacBook Pro M4 Pro - no keyboard / trackpad / lid sensor
            by mitchw
            Hello
            I got this MacBook Pro M4 Pro to have a look at.
            It was tiny bit liquid damaged, just the edge of the board got 1 small 10x10 mm area wet. I've seen much worse that still worked fine to be honest.
            Since it was liquid damaged, warranty does not apply anymore.
            Anyways it was checked at an local Apple Store and they discovered that it needs new trackpad, new top case, etc. Also it needed a new lid angle sensor which they replaced.
            The main issue was that the screen remained black.
            Anyways I cleaned the liquid damaged area, put the machine back...
            09-06-2025, 07:19 AM
          • No Lan
            [Macbook pro A1708] [Boot loop] [Trackpad ?]
            by No Lan
            Hey everyone,
            Usually, I'm not the type to ask for help, but this time, I'm calling on your wisdom and expertise I've seen what this community can do, so I'm pretty sure you guys can help me out.
            Here's the deal: I noticed my MacBook got stuck in a boot loop. After opening it up and doing some initial troubleshooting, I found that the boot loop stops only when the trackpad is unplugged.
            Now, just so you know, the trackpad actually works — I tested it with another motherboard and it's all good. Same for the cable, no issues there. The problem is only...
            05-24-2025, 03:09 PM
          • Skrndelj
            Apple Macbook Air M1 A2337 Trackpad problem
            by Skrndelj
            Hello all,
            I am repairing a Macbook A2337 and i have a problem
            The Macbook is stuck in restore as someone before me tried a DFU restore and bricked the device, now i can't do a restore as AC2 throws error 1 which is related to the trackpad.
            When i turn on the device i get the trackpad click for a few moments and then nothing, i tried 7 trackpads and 7 trackpad flats, i know all 7 are functioning okay, especially one as i use it for testing and DFU restore.
            I inspected the whole board and everything seems fine.
            Can anyone help me as i didn't fiddle with trackpad...
            06-11-2024, 04:26 AM
          • redbaron1007
            Macbook AIr a1466 Trackpad jittery/nonresponsive in macos, but not in recovery mode.
            by redbaron1007
            I've got a MacBook Air A1466 that had liquid damage that I got working entirely except for the trackpad. The track pad is jittery or outright unresponsive when it is in macos, but works perfectly fine in recovery mode. The keyboard works and there are no issues with any of the keys not pressing. I have also replaced the track pad with 2 known good track pads and still am having issues with it.
            I can't find anything wrong on the board with any of the IC's that would be in circuit with the track pad and am assuming it's some sort of os issue, but I don't know how macOS actually works...
            04-28-2023, 10:20 AM
          • rynr
            MacBook Air M2 A2681 no Trackpad
            by rynr
            I have been following the posts in the forum for some time now and have learned a lot. I would first like to thank you for this and hope that it will continue for a long time.
            I received the MacBook in DFU. The recovery always failed with error 1. After some search, I was able to find a defective inductor (LT202).
            After replacing the component, I was able to successfully complete the DFU restore. Unfortunately, the trackpad and keyboard where still without function.
            So i measured all voltages and diodereadings on the JT400 connector. ...
            11-04-2024, 09:56 AM
