Macbook AIr a1466 Trackpad jittery/nonresponsive in macos, but not in recovery mode.
  • redbaron1007
    • Jun 2021
    • 116
    I've got a MacBook Air A1466 that had liquid damage that I got working entirely except for the trackpad. The track pad is jittery or outright unresponsive when it is in macos, but works perfectly fine in recovery mode. The keyboard works and there are no issues with any of the keys not pressing. I have also replaced the track pad with 2 known good track pads and still am having issues with it.
    I can't find anything wrong on the board with any of the IC's that would be in circuit with the track pad and am assuming it's some sort of os issue, but I don't know how macOS actually works since I'm not a mac user. I know on windows I would just reinstall the drivers to test that, but I don't have a clue how to do that on a mac.
    Any and all help would be greatly appreciated.
  • redbaron1007
    • Jun 2021
    • 116
    Re: Macbook AIr a1466 Trackpad jittery/nonresponsive in macos, but not in recovery mo
    I managed to figure it out. Don't know why, but reinstalling MacOS resolved the issue. No clue how a liquid spill corrupted an installation of MacOS, but apparently it did somehow.
    • duwane
      A2141 (2019 16" MB Pro) Strange macOS install issues. NAND? WIFI? FIRMWARE?
      by duwane
      Hi All.
      Sorry ahead of time for the text wall. This is a strange problem and I have tried to explain it as best I can. I realise this is a hardware forum (mostly), but I am still not sure if this is even a hardware fault! I am hoping that someone more knowledgeable than me in the area of understanding installation logs, or someone that has had a similar issue in the past may have some ideas of what might be causing this.
      The issue:
      Unable to do a clean install of any macOS versions supported for this model, even after fully erasing and formatting the internal SSD,...
      10-26-2022, 07:02 AM
    • mitchw
      MacBook Pro M4 Pro - no keyboard / trackpad / lid sensor
      by mitchw
      Hello
      I got this MacBook Pro M4 Pro to have a look at.
      It was tiny bit liquid damaged, just the edge of the board got 1 small 10x10 mm area wet. I've seen much worse that still worked fine to be honest.
      Since it was liquid damaged, warranty does not apply anymore.
      Anyways it was checked at an local Apple Store and they discovered that it needs new trackpad, new top case, etc. Also it needed a new lid angle sensor which they replaced.
      The main issue was that the screen remained black.
      Anyways I cleaned the liquid damaged area, put the machine back...
      09-06-2025, 07:19 AM
    • No Lan
      [Macbook pro A1708] [Boot loop] [Trackpad ?]
      by No Lan
      Hey everyone,
      Usually, I'm not the type to ask for help, but this time, I'm calling on your wisdom and expertise I've seen what this community can do, so I'm pretty sure you guys can help me out.
      Here's the deal: I noticed my MacBook got stuck in a boot loop. After opening it up and doing some initial troubleshooting, I found that the boot loop stops only when the trackpad is unplugged.
      Now, just so you know, the trackpad actually works — I tested it with another motherboard and it's all good. Same for the cable, no issues there. The problem is only...
      05-24-2025, 03:09 PM
    • sureshbobby
      Macbook air A1466 Shutting Down while installing Macos
      by sureshbobby
      Hi friends
      i have Macbook air a1466
      unable to Install macos while installing it shutdown after some time
      any solution
      please help
      07-02-2022, 10:20 PM
    • Sierra89
      Macbook Air 13ich A1466 trackpad 923-0438 and keyboard schematic request
      by Sierra89
      Hello!
      I've used this forum a lot in the past and always found the information I needed to keep on learning and solving the problems. This time, though, I haven't been able to find what I needed so I wonder if any of you could share it.
      I have a 2017 Macbook air A1466 that won't turn on.
      I can turn in on with the power pads, and even shorting the SMC_ONOFF_L
      line to ground in both sides of the flex cable (mother board and trackpad board), I also changed the whole keyboard assembly to a new one which works well.
      All this leads me to think that my problem...
      08-15-2020, 02:05 PM
