Toshiba Satellite - Locks up when plugged in
+ More Options
Posts
  • Awfa
    • Jul 2012
    • Indonesia
    #261
    Re: Toshiba Satellite - Locks up when plugged in
    thank for respon..
    My L300 no display then I replace the NEC 907 with 2 x 470 uF/2.5 V and successfully boot but it freeze when using the AC adapter. Then I added another 2 x 470 uF/2.5 V. Now successfully boot with batt or use charge but only about 1-2 minutes, can help me..
    • rievax_60
      • May 2012
      • 897
      • australia
      #262
      Originally posted by Awfa
      thank for respon..
      What is the part number of the capacitors so we can see the ESR spec in the data sheet.
      • rievax_60
        • May 2012
        • 897
        • australia
        #263
        I scored a faulty Satellite A200 via eBay.
        The proadlizer had already been replaced with 4 yellow surface mount capacitors. I measured the ESR of one of them at 80mΩ.
        Does anyone recognize the type of this capacitor?
        https://www.badcaps.net/forum/images/attach/jpg.gifhttps://www.badcaps.net/forum/attach...1&d=1342226613
          They look like Tantalum caps.
          • rievax_60
            • May 2012
            • 897
            • australia
            #265
            Well, that's a worry because it means they have limited life also.
            • Wester547
              • Nov 2011
              • 1268
              • USA.
              #266
              I thought Tantalum capacitors didn't lose capacitance in the way Class II (along with III especially and worse) Ceramic and Electrolytic capacitors do? D:
              • rievax_60
                • May 2012
                • 897
                • australia
                #267
                The main problem is the ESR being too high. I have not been able to find the data sheet to see what the ESR is supposed to be.
                Maybe the ESR was always high.
                • Notsosure
                  • Nov 2011
                  • 71
                  #268
                  That is most likely TPSY337*002#0040, which is AVX TPS Series Tantalum Cap, 330uF, 2.5V, 40mΩ:
                  http://www.datasheetarchive.com/TPSY337-datasheet.html
                  This cap seems similar to RS Stock No. 548-3337, which did not work on my A200.
                  • rievax_60
                    • May 2012
                    • 897
                    • australia
                    #269
                    Thanks. That makes sense.
                    I replaced them with 10x 100uf ceramic caps and its working fine.
                    • mockingbird
                      • Dec 2008
                      • 5484
                      #270
                      I just scored a motherlode of Kemet T520 "V" case caps for a great price ("V" case is lower in height than "D" case - 2mm vs 2.5mm). They're 4V 330uF and have an ESR of 0.009 and a ripple ratting of 4600. My A200 has had some random (Albeit rare) crashing.
                      • Notsosure
                        • Nov 2011
                        • 71
                        #271
                        I might have less than 800uf because the capacitance decreases with applied voltage with these ceramic capacitors.
                        I dont know the ESR. Ceramic capacitors usually have very low ESR.
                        Your ceramic caps apparently have 1mΩ ESR, which will give a much lower total ESR than the original OE128 or OE907 ( http://translate.google.com.au/trans...ed=0CG8Q7gEwBg ). However, the cap's upper operating temperature limit is around 85C, which could be a problem in hot summers for some people.
                        It may be worth noting that people have successfully replaced their Proadlizers with small caps of total capacitance from two-thirds to around two-and-a-half times the original value. The safest approach appears to be the exact value to one-and-a-half times the original value but perhaps there is not much risk involved in extending those limits further. It would have been good if we knew the upper limit for ESR as well.
                        • Notsosure
                          • Nov 2011
                          • 71
                          #272
                          Both OE128 and OE907 with a Case Code of F25 have a maximum height of 2.5mm so any small cap up to that height should be fine (Case D tantalum caps with a height of 2.8mm are not really suitable anyway). However, especially in Toshiba Satellites that have a metal plate covering the top of the Proadlizer, the lower the height the better it is. Toshiba's designers might have been drunk when designing this metal plate because it conducts heat from the CPU to the fan thus compelling the poor Proadlizer to cope up with this additional heat apart from its own heat and whatever comes from the pads below. In other words the Proadlizer remains in an oven as long as the laptop is on (perhaps it is a good idea not to leave it on for long periods unnecessarily). I had once even considered cutting off the portion of the metal plate that runs on top of the Proadlizer but dropped the idea thinking this might reduce the heat removal from the CPU. After all it is much cheaper/easier to replace the Proadlizer than the CPU.
                          • mockingbird
                            • Dec 2008
                            • 5484
                            #273
                            Yea, you're right, Case D is 2.8mm, not 2.5mm. I thought everyone was using Case D... Another important thing to consider is the ESR... I checked a lot of Tantalum caps and a lot of them have a pretty high ESR.
                            • rievax_60
                              • May 2012
                              • 897
                              • australia
                              #274
                              I measured 2.8mm of space under the aluminium plate but extra clearance might be needed for soldering.
                              Extra gasket thickness could be placed under the CPU heatsink bracket plate, shown in post 263.
                              The same thickness of metal shim will need to be placed on the northbridge chip.
                              • farid multintech
                                • Apr 2012
                                • 37
                                • malaysia
                                #275
                                hi everybody
                                I got one acer aspire 2920 got symptom like the toshiba,using nec/tokin OE907.can somebody guide me how to repair the problem.what type/value capacitor I must use.Thanks
                                • rievax_60
                                  • May 2012
                                  • 897
                                  • australia
                                  #276
                                  Originally posted by farid multintech
                                  hi everybody
                                  I'm not certain if I am able to help much.
                                  I prefer to use ceramic capacitors. Others prefer to use tantalum capacitors.
                                  Read this thread for details.
                                  Have you located a faulty capacitor in your Acer?
                                  • mockingbird
                                    • Dec 2008
                                    • 5484
                                    #277
                                    Well, I opened up the A200 (PSAE6C I think), and it didn't have that cap, but a bunch of tiny ceramics under the CPU and a couple of polymer SMDs. I put in some fresh thermal paste, hopefully that will solve my problem.
                                    • farid multintech
                                      • Apr 2012
                                      • 37
                                      • malaysia
                                      #278
                                      I googled and found out that acer aspire 2920 has same problem with the toshiba,nec/tokin cap got problem
                                      • Notsosure
                                        • Nov 2011
                                        • 71
                                        #279
                                        If you have decided to take the risk of changing the cap then my suggestion is to buy two of either 737-2832, 147-651 or 147-639 and five of either 692-5762 or 692-5766 from http://malaysia.rs-online.com/web/ and use some or all of them, as necessary (I would use all the 7 caps to keep the total ESR low). On some websites 737-2832 is being shown as not in stock but actually UK has plenty in stock. It may be better to call RS and check with them before going for the costlier alternatives.
                                        • Notsosure
                                          • Nov 2011
                                          • 71
                                          #280
                                          Sorry, made a mistake in reading the ESR of Case A caps suggested above. In view of this the options I can think of now are (1) 3 or even 4, if necessary, of 737-2832, (2) ceramic caps suggested by rievax 60 or (3) a new OE907 (which may not last too long but safest choice as it will surely work).
                                            Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro A40-C-1P5 boardview and Satellite Pro A40-C-1P5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 06:10 AM
                                            Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro R50-C-17C boardview and Satellite Pro R50-C-17C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 05:40 AM
                                            09-06-2024, 05:27 AM
                                            Toshiba Satellite Satellite P50t-C-111 Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Satellite P50t-C-111 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite P50t-C-111 boardview and Satellite P50t-C-111 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-06-2024, 08:10 PM
