Help me repair this UX305 motherboard please
  • Clinteastwood1
    • Apr 2021
    • 23
    • France
    Re: Help me repair this UX305 motherboard please
    Ok some people told me it's not reliable to use the ohmmeter to test mosfets so I took all the measures again in diode mode (testing random pins of the mosfets side by side). Please look at the pic below.
    Red circles = faulty mosfets
    Green circles=good mosfets
    Yellow area = slightly hotter than the rest of the board
    I really hope you can help me because I really do need this laptop
    • Clinteastwood1
      • Apr 2021
      • 23
      • France
      Little mistake sorry, pin 8 of winbond bios chip is not the right one, it's the first one at the top and it reads 1v (it's pin 5 that shows 0.28v).
      It should read 3.3v I think so there is problem. Is this chip dead?
      • mon2
        • Dec 2019
        • 14679
        On the flash chip, you are showing the voltage on pin #1 (pin close to the circle in the plastic housing). Then the pins count up going counter-clockwise.
        So you have measured, pin 1 and pin 5 from the last diagram.
        What is the voltage on pin 8 of this flash chip? It should be 3.3volts.
        Also good to check and post the voltages on each grey coil. Each coil is linked to a voltage rail.
        In general, each rail should work to make this laptop operate normally.
        • Clinteastwood1
          • Apr 2021
          • 23
          • France
          Hi Mon2 thanks for your help. I took some measures as per your suggestions. This time I took measures for all the bios chip pins to avoid confusion. Also for coils.
          This area around the coils becomes very hot after a short moment.
          Thanks I hope it helps
          • Clinteastwood1
            • Apr 2021
            • 23
            • France
            Is this mosfet dead? Strange behavior
            I am trying to troubleshoot a laptop's motherboard, I measured the resistance of the 2 entry mosfets, and the second one seems to have a weird behavior.
            As a matter of fact, it has an infinite resistance (meaning it's dead, right?) but when I measure its voltage it shows 19v as the first one, as if it was fine...
            So is it dead or my method to detect dead mosfets is crap? ( I tried with the diode mode of my multimeter, it also shows there is a discontinuity)
            Thanks for your help guys.
              • 21969
              Re: Is this mosfet dead? Strange behavior
              Your thread post has been moved from the "Troubleshooting Desktop Motherboards, Graphics Cards, and PC Peripherals" forum to this thread.
                • 21969
                The best way to test mosfets is to desolder them and test on the bench. What make/model is your meter ?
                • Clinteastwood1
                  • Apr 2021
                  • 23
                  • France
                  #28
                  This thread was confusing enough with all my measures and posts I don't think it was a good move adding the mosfet measuring question, this thread is already overloaded I think and nobody still participate to it...
                  Ok thanks for your reply mate, if I desolder it I will replace it straight away no need to test it
                  I am going to replace all the mosfets on my board i guess, because I'm afraid I won't be able to troubleshoot it
                  Cheers
                    • 21969
                    Ah so you can desolder them. OK go ahead,desolder them and test them first before buying new ones. Maybe this will help - http://mayohardware.blogspot.com/201...g-mosfets.html
                    • Clinteastwood1
                      • Apr 2021
                      • 23
                      • France
                      #30
                      Thank you very much for the link SMDFlea I'm sure it will help me avoid desoldering mosfets for nothing. I hope I will be able to find my motherboard's problem too, thanks again
                      Edit: thanks to your link I realized the diode mode has to be used taking into account the sense of the measure. So I took new measures and my mosfets are all fine.
                      Now with this new information i hope someone here can help diagnose the board.
                      Here are my last mesures in the 3v/5v area (hot zone)
                      • Techtiger
                        • Oct 2014
                        • 1602
                        • france
                        #31
                        Assuming you don't have a power Lab to find the short there is a alternative method give a try (FINDING SHORT ON MOTHERBOARDS WITH COMPRESSED AIR https://www.youtube.com/watch?v=AOALg_rDIZk )
                        put the multimeter continuity test the 2 coils on red and musure the readings the yellow is you 3/5 Regulate do the COMPRESSED AIR test arround this chip and see
                        • Clinteastwood1
                          • Apr 2021
                          • 23
                          • France
                          #32
                          Mate this tut is magic thank you !!!
                          I don't have any compressed air right now but seen in the comments that you could achieve the same with gas lighter oil or isopropyl alcohol, since I have both I'm gonna test it this way.
                          Before doing it (I'm not at home right now) and since this area on my board is very hot, couldnt we just conclude it's the chip you circled in yellow which is faulty, since coils don't get faulty, right?
                          And 2nd question, this chips reads "1285a tp 5c8 a3sh" do you know if I can replace it with this one with a slightly different ref since I can't find the exact one:
                          https://www.ebay.fr/itm/1PCS-TPS5128...b-15db0b89a2f9
                          Thanks again for this cool idea, and if this chip is making my MB faulty I surely owe you a big one my friend !
                          • Clinteastwood1
                            • Apr 2021
                            • 23
                            • France
                            #33
                            I made the alcohol test and the only chip on which alcohol evaporates very fast is this 3/5v regulator. I tested all the chips on the board and coils and mosfets and other components this is the only one causing the alcohol to evaporate in a heart beat.
                            Is there something else could test? Or I can replace this chip and hope for the best...
                            These chips are very tiny compared to the others, it won't be easy I should probably buy a dozen of them just in case
                              • 21969
                              Have you desoldered/soldered a QFN chip before ? ,do you have a hot air station
                              • Clinteastwood1
                                • Apr 2021
                                • 23
                                • France
                                #35
                                I've watched videos on YouTube haha.
                                I'm gonna buy an air gun, I already have a microscope, a soldering iron, and flux, so it should be fine. I will train myself on another old motherbord first.
                                  • 21969
                                  What type of air gun, not the paint stripper type i hope
                                  • Clinteastwood1
                                    • Apr 2021
                                    • 23
                                    • France
                                    #37
                                    Not the elon musk's one at least
                                    If you have one to advice me please let me know, or I'll buy one from Amazon considering the reviews. Not to expensive though since it will be for a one time use.
                                    This guy on yt even replace this kind of chip without any air gun, only zooming with his phone
                                    https://youtu.be/ljyGMOi5JPo
                                    My chip ref is something like "1285a tp 5c8 a3sh", I found similar chips but the end of the ref isn't exactly the same, I guess my chip is a "TPS51285A" as well so it should be fine ?
                                    https://www.ebay.fr/itm/1PCS-TPS5128...0/152822560965
                                    https://www.aliexpress.com/item/32813670403.html
                                    • Clinteastwood1
                                      • Apr 2021
                                      • 23
                                      • France
                                      #38
                                      I bought it from ali I suppose they are the same.
                                        • 21969
                                        The guy on youtube hasn`t desoldered a QFN chip,he`s only soldering one around the edges, he hasn`t soldered the centre pad. https://www.youtube.com/watch?v=c_Qt5CtUlqY
                                        The 858D is about as cheap as you`ll get for a hot air station, i`m not recommending it though,as they have some well known quality control and build problems, but you can check the prices and YT videos .As its only a one-off you could take the part and board to a phone/pc repair shop ,they should be able to solder it cheaper than the cost of a hot air station.
                                        • Stevedb
                                          Stevedb
                                          • Feb 2018
                                          • 624
                                          • Belgium
                                          #40
                                          It is possible that the output from the chip is shorted I would first check the VIn , EN1 , EN2 , LD03.3, LDO5 pins are shorted. Which ic do you have on your board.
                                          Good luck
                                          Best regards
                                          Steve
                                          • glovecaps
                                            Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
                                            by glovecaps
                                            I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
                                            My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
                                            The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
                                            11-25-2024, 04:23 PM
                                          • angeloavv
                                            ASRock H81M-DG4 power cycles and glitches - sometimes POSTs sometimes not
                                            by angeloavv
                                            Hello everyone! This is my first post and this motherboard is driving me crazy because everything looks so non-trivial that I don't know where to start investigating. During these days I believe I watched half of the YouTube videos trying to understand how to troubleshoot power cycles but at the same time, I'm confused because my motherboard doesn't always do that and sometimes completes the POST for a few seconds: the right amount of time to freeze, show glitches on the screen, and then reset itself.
                                            Let me give you a bit more context to understand why and how we got here.
                                            12-26-2023, 03:32 PM
                                          • dragon3x
                                            After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                                            by dragon3x
                                            Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                                            power on.
                                            Here are some examples :
                                            (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                                            switching supply area).
                                            (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                                            than 6.3 V.)
                                            1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                                            I replaced capacitors with aluminum-polymer.
                                            3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                                            03-21-2025, 02:46 PM
                                          • dhenion
                                            Asus VivoBook F510UA-AH51 won't run on battery after motherboard replacement
                                            by dhenion
                                            I'm working on my sister's laptop: Asus VivoBook F510UA-AH51 - The motherboard died so I replaced it.
                                            The original board was:
                                            ASUS X510UNR REV 3.0 A
                                            The replacement board is:
                                            ASUS X510UNR REV 3.0 B (identical except B vs A - I couldn't find an A board anywhere. Visually they are identical.)
                                            It boots right up on the replaced motherboard and everything works fine on the new motherboard - but it won't run off battery. When I disconnect the charger it immediately dies. When I plug it back in and reboot the system - it still shows the battery at...
                                            01-30-2024, 01:45 PM
                                          • Stanley1843
                                            Motherboard W26361-W84-X-02 - Black Screen
                                            by Stanley1843
                                            Hello to everyone.
                                            My W26361-W84-X-02 motherboard starts but don't show image (no logo screen neither bios). Because, I have two of them I desoldered the bios chip from the no working motherboard and I soldered it to the working motherboard and the motherboard works OK, so the bios firmware isn't the problem. Below I took some measurements from the no working motherboard when is power on. Also, I replaced the RAM and didn't work again (maybe some pins from the RAM slot don't have the right voltage?). I replaced and the bios battery, and I made reset on the bios and again the problem didn't...
                                            05-23-2024, 03:51 PM
