Galaxy Tab P7510 no power no image
  • thesame
    • Mar 2018
    • 141
    • Romania
    Hy guys , i have this tablet to fix , i measured the battery looks ok 3.6 v i have power from the charger through the flex 4.15 v measured on the battery connector without the battery conected, its drawing 0.12 amps without the battery plugged and 0.41 A with the battery on , pressing the power button does nothing, i have found these capacitors near the charging circuit i think it is all shorted to ground and removed them , but i still have the short could it be the charging circuit, does anyone has any idea what could i check at this point?
    • 21922
    Re: Galaxy Tab P7510 no power no image
    Heres the service manual,follow the flow chart on page 25 https://www.manualslib.com/manual/80...-Gt-P7510.html
    • thesame
      • Mar 2018
      • 141
      • Romania
      I had the manual , thank you , i was waiting for some advice from someone who already had this problem or knows what it could be.
      • mkdj
        ASUS X571 no power : battery issue?
        by mkdj
        Mark and model: ASUS X571
        Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
        Tests already made:
        - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
        - I have removed...
        07-14-2025, 09:16 AM
      • GLISIT
        by GLISIT
        01-16-2025, 02:29 PM
      • Gust zhang
        Mid 2014 A1398 MacBookPro,Is it feasible to remove the battery from the MBP and connect it to an external power supply?
        by Gust zhang
        ​I have a 15 - inch Retina MacBook Pro from the mid - 2014 model. Here is the link: https://www.badcaps.net/forum/showth...light=820-3662 . The battery broke some time ago. After I removed the battery and plugged in the original power adapter, the MBP could boot up normally. However, when I checked with IntelPowerGadget, I found that the CPU speed was limited to 0.8 GHz, and it ran very slowly. Later, I found a solution on GitHub. There is an open - source project called cputune that can set the CPU running speed. So I can now run the MBP at full speed. But another problem...
        02-16-2025, 08:39 AM
      • survivalbloke
        Acer Predator Helios 300 - will not power up if battery is CONNECTED
        by survivalbloke
        This was a no power initially. Thanks to your help, I discovered it was the first mosfet, so I replaced. Now, the device will power up only if the battery is NOT connected. As soon as I connect the battery, it shuts off. If I connected the battery while the device is off, it simply will not respond to the power button. I replaced the battery, and while I suppose the new battery could be faulty, I'm assuming it is not. I'm having the same behavior with the new battery. I measure .2v at the charging coil. Manually applying power to the + and - at the battery header, there is no charging happening....
        06-25-2025, 12:20 PM
