Need help - to understand Motherboard Symbols
  • rxyzm
    • Apr 2016
    • 64
    • India
    I am in the process of fixing my laptop.
    I need some help to understand some symbols that are shown in schematic. I have attached a part of schematic doc here that sows them.
    The + Symbol (one that looks like a double plus - one inside the other), appears on MB. I believe that represents a particular +ve bus (since they are numbered as FM2, FM4 etc.), but I am not sure. Also, I am bit rusty on these symbols used - particularly on MB.
    The O symbol(a doughnut hole) also appears in schematic. I am find with the Ground/Earth presentation. But, the one where there is a small x at the end of line is a bit cryptic for me.
    The same small x also appears on the + symbols. I am not sure whether it means that they are not connected to anything (float by itself?).
    Will certainly help any guidance.
    Warm Regards,
  • khaahk
    • Dec 2013
    • 756
    • Estonia
    Re: Need help - to understand Motherboard Symbols
    This page on the schematic has no useful information to you if you plan to fix the laptop. Good starting point is here:
    https://www.badcaps.net/forum/showthread.php?t=88758
    • rxyzm
      • Apr 2016
      • 64
      • India
      Thank you KhaahK.
      I have already gone through the forum that you have suggested.
      What I want to know about + (hollow + symbol) is, is it used to indicate different + rails? There are identifying labels such as FM2 etc. Do these labels have any specific meaning or they change with the company?
      Warm Regards,
      • khaahk
        • Dec 2013
        • 756
        • Estonia
        What is the platform name? The FMxx symbol should be represented on the schematic elsewhere if it had some importance in electrical meaning. You have the mainboard at hand, also i hope mutlimeter - so take measurements: are the + signs interconnected and what are they electrically connected to.
        My opinion is that they have no importance to you, maybe internally to mainboard manufacturer or some meaning in emc domain.
        • rxyzm
          • Apr 2016
          • 64
          • India
          Hello Khaahk,
          This is MSI MB - MSI-16P51.
          On the MB, I do see the hollow + with a label such as FM2. But the exposed copper in the hollow + does not show continuity with other hollow + as much I have checked.
          It is possible that the hollow + is covered with a protective material after or during board etch process.
          There seems to be a short on 1.05 V bus near GPU and I am trying to find that. But I do not want to connect it to power (battery or Power pack) until I am reasonably sure that I have a location for short. Now for this, I need to know the supply rails (and there are many) including the 18V that is used to provide large current loads through local power management parts for GPU, CPU, Memory etc.
          Warm Regards,
          • piernov
            • Jan 2016
            • 4435
            • France
            FM* are fiducial marks used during production for the calibration of the assembly line.
            • rxyzm
              • Apr 2016
              • 64
              • India
              Hello Piernov,
              Thank you for providing that insight. That could be another case.
              I also went through your sticky - Beginner's Guidelines.
              One point therein caught my eye as that's the condition that I am trying to understand.
              It is mentioned there -
              2.2. Don't suspect that something is shorted with no reason
              Shorted components are not the only failure mode of a laptop. Additionally, some places will measure low resistance to ground under normal operation. In general, high power low voltage (<2V) power rails will measure less than a few hundred ohms to ground. CPU VCore will measure a few ohms only. GPU VCore with newer NVidia GPU can even measure less than 1 ohm. It's normal. If you suspect a short to ground, always report your exact resistance to ground measurements.".
              On my MSI MB - the GPU is nVidia N17E (in schematics it is mentioned that the chip is GTX 1070). I find 0 (Zero Ohm) resistance between the +ve supply plain and the -ve supply plane post the mosfets (87350D) that feed in to this rail. There are three driver chips (uP1909) and 6 mosfets.
              I did the resistance check on the mosfet for highside and they seem to be fine. There is ample resistance between the gate and drain/source.
              On the low side mosfet (for each mosfet) the source and drain show 0 (Zero) ohm resistance. But, this is expected because the source of lowside mosfet is connected to the output rail directly. The gate and source/drain show resistance depending on the probe polarity.
              So, for me the resistance check is inconclusive in this case (can be right or wrong) if I consider point 2.2 above.
              Also, in continuity mode, the probes may output more than 1 volt and that may impact the resistance reading too.
              Problem I am trying to fix is - when I press power button, the power and caps lock leds blink alternatively. The exhaust fans do not switch on. No 1 V supply on nVidia power rail. And I think because there could be a power issue, the CPU supply may also not be switched on.
              The issue occurred few times in the past, but the laptop would start when the power button was hit the next time.
              Reason I have not connected the power supply to MB is, the 18V supply runs to all mosfets that provide large currents to GPU, CPU etc. Taking chances with key chips is something I would like to avoid.
              Will appreciate any guiding pointers towards a plausible cause for this issue.
              • rxyzm
                • Apr 2016
                • 64
                • India
                Well, After a long break (COVID and other interrupts), back on this topic.
                I fixed the plastic body of the laptop. Fixing the Plastic Body was another experience.
                On the MB side, I reassembled the laptop and started testing it module by module.
                When first connected to power, it showed the original problem where the power light and caps lock LEDs blinked. But after 3 - 4 tries of hitting power button, suddenly, the laptop responded by turning on and then started working.
                Now, for the very first time when connected to power source, it does not boot on the very first press of power button. The power led comes on and then goes off. After about 3 - 4 tries, the machine responds and then boots on charger as well as battery on the press of power button. But what causes this behavior? Now that's the question.
                Well, something to work further with...
                • Gibon378
                  What caused the BSOD?
                  by Gibon378
                  Hello there!
                  I was doing some usual stuff, browsing the internet, listening to music, coding, etc. and my computer froze. It looked like the website couldn't process the request (logging into the account, there was the loading symbol) and it took a few seconds, then my computer totally froze except for the mouse cursor. It lasted for about a minute and I got the BSOD. It happened yesterday and today (just now).
                  I managed to get the MEMORY.DMP content, but I don't really understand it. Could somebody help me?
                  Code:
                  ************* Preparing the environment for Debugger
                  06-23-2023, 06:20 AM
                • glovecaps
                  Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
                  by glovecaps
                  I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
                  My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
                  The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
                  11-25-2024, 04:23 PM
                • Docus
                  Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
                  by Docus
                  Hi everyone 😀,
                  I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
                  To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
                  Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
                  1. I already own the exact same model, but its plastic chassis is badly damaged.
                  06-10-2025, 04:24 PM
                • Archimedes
                  HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
                  by Archimedes
                  Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
                  Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
                  Fans are spinning. Blindly could install windows11 and got the device manager...
                  07-30-2024, 05:14 PM
                  ASUS P5GC-MX motherboard recap
                  by momaka
                  Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                  This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                  So here is what the motherboard looked like with its original caps:
                  CPU VRM area up close…...
                  01-27-2021, 11:59 PM
