No Power MacBook Pro 13" Mid 2009 820-2530-A
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 674
    Tested all points of PPBUSG3H is present. PP5V is present.
    What is not present is PPV_S0_CPUVTT and MCPCORES0_IMON is not present etc. On the MCP VCORE POWER SUPPLY , PPVIN_S0_MCPCORE is present for all Caps C7563, C7560, C7571 etc. Resistors are good and visibly good as well. I am assuming the CPU is dead, I also replaced the SMC chip (assumed it was a bad SMC chip) and that didnt solve the problem. Anyone have an opinion?
    sigpic
    MEOWING IN THE IMPOSSIBLE UNIVERSE!
  • mon2
    • Dec 2019
    • 14672
    Re: No Power MacBook Pro 13" Mid 2009 820-2530-A
    U7600 is the voltage regulator for the CPU Vcore @ 1.062V (PPCPUVTT_S0_REG).
    What is the voltage @ L7620, pin 2 ?
    Also post the voltage into L7620 as per attached diagram.
    Please reference the exact net names as per the original schematics so they can be quickly found through the PDF search feature.
    If your 5 volt rail is present then U7600 should have the 5 volts as the input - please confirm.
    • Stephen
      Meow Meow MEOW!
      • Apr 2020
      • 674
      Damn fast replay mon2! Ok checking now
      sigpic
      • Stephen
        Meow Meow MEOW!
        • Apr 2020
        • 674
        0 volts present at L7620
        sigpic
        • mon2
          • Dec 2019
          • 14672
          Yeah, going cross-eyed in designing a new product. This new widget should assist in the repair of these logic boards.
          Check and post the voltage on pin 10 of U7600 (PP5V_S0_CPUVTTS0) which should be 5v0.
          Check and post the voltage on pin 1 of U7600 (CPUVTTS0_EN). This pin turns the switching regulator ON / OFF via this ENABLE pin. This is driven by a RC (resistor & capacitor) circuit - see attached.
          • piernov
            • Jan 2016
            • 4439
            • France
            https://www.badcaps.net/forum/showthread.php?t=88758
            No power
            • Check if DC-in jack LED lights up
            • Check voltage on all the large inductors
            • Follow power sequence if it exists in the schematics
            • Follow list of power rails if it exists in the schematics
            Note: don't forget to trigger power button when measuring for the rails that only come up when machine is turned on.
            When requesting help, please attach a picture of the board with voltage and resistance to ground measurements on all the large inductors after triggering power button.
            • Stephen
              Meow Meow MEOW!
              • Apr 2020
              • 674
              Pin 10 = 0 Volts
              Pin 1 = 0 Volts
              sigpic
              • Stephen
                Meow Meow MEOW!
                • Apr 2020
                • 674
                Also mon2, tested R7881 Resistor to see if it is blown or failed. I have 33K on the resistor so it shows good on the board. No power at cap C7881. RIP life lol
                sigpic
                • mon2
                  • Dec 2019
                  • 14672
                  Wait , the cap could be fine. What is the voltage reading @ the junction in the attachment?
                  This whole cluster of resistor & caps are a poor-man's delay circuits to sequence the power rails. They really should have used voltage supervisors that once they reach a specific voltage threshold -> release the reset line and/or enable the next power rail, etc.
                  This power sequencing is done to prevent latch up conditions. In our opinion, rc circuits are not recommended but it is a cheap method that appears to be 'just ok'. We strictly use power supervisors in our designs. Never a fault.
                  Need to know if you have +voltage on PM_SLP_S3_L_BUF.
                  Then if this rail is zero volts here, keep checking 'to the left, to the left'
                  https://www.youtube.com/watch?v=2EwViQxSJJQ
                  • Stephen
                    Meow Meow MEOW!
                    • Apr 2020
                    • 674
                    No voltage at all on PM_SLP_S3_L_BUF Going to check further
                    sigpic
                    • Stephen
                      Meow Meow MEOW!
                      • Apr 2020
                      • 674
                      I kept going to the left...LEAD to the damn CPU ROFL I KNEW IT.
                      sigpic
                      • mon2
                        • Dec 2019
                        • 14672
                        I would suggest to review sheet # 3 of the schematics (K24 POWER SYSTEM ARCHITECTURE) and follow and record the order of the power rails (the order is inside each circle).
                        Perhaps you will find some other critical rail is missing which is leading to this demise.
                        • Stephen
                          Meow Meow MEOW!
                          • Apr 2020
                          • 674
                          I guess you have a point. I will get back with you! Also just found a damn data recovery tool for this A1707 I been working on! WOOT we can save the customers data!
                          sigpic
                          • PantherDave
                            by PantherDave
                            Hi all!
                            05-29-2024, 02:01 PM
                          • GLISIT
                            by GLISIT
                            01-16-2025, 02:29 PM
                            by sam_sam_sam
                            03-31-2024, 02:12 PM
                          • SarcasticOP
                            General question about MacBook power rails for repair.
                            by SarcasticOP
                            I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
                            • PPBUS_G3H (12.6V-12.8V)
                              • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
                            • PP3V42_G3H (3.42V)
                              • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
                            • PPVRTC_G3H (3.3V)
                              • This
                            12-12-2024, 05:50 PM
