Macbook pro A1706 2017
  • String2016
    • Nov 2015
    • 2238
    • philippines
    I need help on this macbook pro A1706,The problem is 1 hour auto shutdown, when i playing videos or music it stays working for 1 hour after that it shuts down,anyone encounter this problem please help
  • mon2
    • Dec 2019
    • 14670
    Re: Macbook pro A1706 2017
    Are you powered off battery or external adapter during these tests?
    Is the adapter original?
    What is the power adapter rating?
    Is the one hour exactly one hour or an estimate?
    Check if the logic board is extremely hot at the end of this use? Perhaps overheating and shutting down due to lack of proper heat dissipation / ventilation.
    • String2016
      • Nov 2015
      • 2238
      • philippines
      estimated about 1 hour it shuts off and sometimes cannot turn on quickly many times to press power button to turn on
      • mon2
        • Dec 2019
        • 14670
        Try the PRAM reset. See attached. Hold these keys down while powering up and wait for 2 chimes. See if this helps.
        Are the fans running? Exhaust air is hot?
        Perhaps the cpu needs some fresh heatsink compound.
        Unit clean or is dusty?
        Could be perhaps a capacitor that is starting to fail.
        • String2016
          • Nov 2015
          • 2238
          • philippines
          tried pram reset still problem exist i check it almost 1 hours it goes to auto shutdown, fan is clean and new thermal paste.
          • String2016
            • Nov 2015
            • 2238
            • philippines
            anyone who encounter this same problem please help
            • mon2
              • Dec 2019
              • 14670
              Try this,
              https://www.ifixit.com/answers/view/...ry+charge+left
              • mon2
                • Dec 2019
                • 14670
                Do you see this issue with an external adapter or on battery power?
                Can you test with another power adapter to rule out overheating of the power adapter?
                • String2016
                  • Nov 2015
                  • 2238
                  • philippines
                  Already tried different good adapter same issue sometimes many times to press the power button to turn on then once turn on after 1hours auto shutdown, anyone can help on this please, does this smc problem?
                  • mon2
                    • Dec 2019
                    • 14670
                    Review this webpage and confirm this is not a timer or scheduled shutdown:
                    https://www.cnet.com/how-to/how-to-p...r-mac-desktop/
                    • String2016
                      • Nov 2015
                      • 2238
                      • philippines
                      I think this is a board problem
                      • Ryan.man
                        by Ryan.man
                        02-04-2025, 12:23 PM
                      • sofles
                        Macbook a1707 2017 model 820-00928 GPU issue
                        by sofles
                        Hello there
                        I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
                        I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
                        11-21-2024, 05:25 AM
                      • Tennen
                        MacBook Pro 2017 A1706 820-00923 no power, low voltage PPBUS_G3H
                        by Tennen
                        Heya, so recently a MacBook Pro 2017 A1706 820-00923 reached my table, showing no signs of life at all. I am trying to use it as an opportunity to get more into the details of fixing Apple products. What I did so far might not have been ideal, but I am trying to improve.
                        The story I got told:
                        The MacBook received a new battery at some point and later at a random point in time just stopped working. Some specialist shop tried to diagnose the issue but only tried another battery - concluded mainboard damage and returned it to the customer.
                        What I did and learned...
                        10-20-2022, 07:26 PM
                      • kurtspirit
                        Macbook A1706 EMC3071 (2017 Touchbar)
                        by kurtspirit
                        I have a Macbook Pro 2017 Touchbar (A1706) that suddenly shut down for no reason.
                        So I took it apart and started measuring.
                        The PP3V3_G3H seems problematic. I traced the line to component U6903 and on Pin 10, I measured 1.9V instead of 3.3V.
                        Unfortunately, my skills stop there and I don't understand where this type of failure can come from.
                        I saw on videos of repairers that the failure could come from the U7000 component which would be at the origin of the 3.3V but they have absolutely no voltage. I have a 1.9v...
                        What do you think ?...
                        08-23-2022, 05:57 AM
                      • afarr
                        Apple MacBook Pro Mid-2017 A1706 - C7490 Capacitor Help
                        by afarr
                        Hi all, this is my first post, I offered to check out a friends MacBook Pro, A1706 which doesn't power on, before this happened they smelt something burning inside, and Apple refused to help with out being out of warranty.
                        Among investigating a capacitor on the logic board spilt and scorched surrounding area please refer to images; https://imgur.com/a/AmSwFr3
                        I found a schematic (x362 MLB Schematic) for the logic board on a thread from this site, I'm unsure about the right terminology when describing so please forgive me.
                        On the location I assume...
                        02-13-2023, 01:11 PM
