lenovo 320 nm-242 touch pad not working
  • nabilgo
    • May 2016
    • 302
    • L.A
    hello i have lenovo ideapad 330 borad numb nm-242 touch pad not working
    i did try install new windows update bios update driver nothing work and when u
    take look at device manager i see yellow triangle on **i2c hid ** code errror i did install all the driver nothing is missing and when u try f6 nothing happaen
    10
    any suggestion 3v present
  • tomodachi
    • Apr 2012
    • 602
    • Turkey
    Re: lenovo 320 nm-242 touch pad not working
    try to plug a windows install flash drive and see if it work in that environment
    • nabilgo
      • May 2016
      • 302
      • L.A
      does not work
      • nabilgo
        • May 2016
        • 302
        • L.A
        this is the problem
        • nabilgo
          • May 2016
          • 302
          • L.A
          Originally posted by nabilgo
          this is the problem
          any one,,,?????
            • 20869
            Try these drivers
            Intel serial IO driver
            https://download.lenovo.com/consumer...s/9u0d03af.exe
            Touchpad drivers
            https://download.lenovo.com/consumer...st08af09mc.exe
            • paulo66
              • Dec 2020
              • 88
              • Portugal
              Go to device manager and under "view" allow it to show old drivers.Get rid of old drivers. Get rid of (uninstall) them all.
              Good luck.
              • paulo66
                • Dec 2020
                • 88
                • Portugal
                Better yet, download a portable called device cleanup tool and run as administrator. Remove everything that shows up.
                • nabilgo
                  • May 2016
                  • 302
                  • L.A
                  Originally posted by SMDFlea
                  didnt work bro i think it a hardware probleme
                  • nabilgo
                    • May 2016
                    • 302
                    • L.A
                    check the picture
                    • nabilgo
                      • May 2016
                      • 302
                      • L.A
                      any oen pls
                      • obelix24
                        Macbook Air 2020 (a2179) - touch id not working
                        by obelix24
                        Hi i have one Macbook Air 2020 where touch ID is not working (it's not scanning fingerprints). Touch ID was working before, there is no error message during scanning fingerprint it's just not scanning on screen you can see only fingerprint but there are no red updates as when it's working. Power button is working fine.
                        I've checked boardview and also schematics but i'm not able to find anything related to TouchID ... i have similar issue on a2338 where there was problem with PP3V0_TOUCHID​ and after replacing UT610 it was working but here i'm not able to find anything related to...
                        02-09-2025, 12:57 PM
                      • purepower
                        Lenovo laptop IdeaPad C340 touch screen not working,
                        by purepower
                        Good day to all any one here ,,I need Lenovo laptop IdeaPad c340 touch screen driver , I installed driver ,,but it's doesn't work,I go to Lenovo support ,I installed right driver from there and still no luck ,, touch screen not working ,,
                        01-04-2023, 12:44 AM
                      • hopkok
                        Lenovo Legion 16ITHg6 NM-D721, keyboard not working, LEDs too
                        by hopkok
                        Hi masters, I need your help.
                        I am working on Lenovo Legion 16ITHg6
                        Motherboard number NM-D721, no BV, no schematic but I am attaching very closes ones.
                        INPORTANT: My motherboard version is with IT8258 IC, that is controlling keyboard and RGB LEDs.
                        My problem is on UI142, +3VALW_AG is not stable, floating from 0V to 3,3V.
                        AGKB_PWR_EN_N signal is floating too (that is why+3VALW_AG not stable).
                        Power LED is not working as well, power button working well.
                        UI26 ??? is there any firmware too? Powered by +3VALW_AG.
                        Motherboard...
                        05-04-2025, 09:35 AM
                      • someonenotyou
                        Lenovo A485/T480 USB stops working when USB2.0 is plugged.
                        by someonenotyou
                        Hi.
                        I have 2 Lenovo laptops (A485 and T480) with identical USB problem.
                        When I plug in a USB 3.x device (USB storage), the USB ports are working normal.
                        But as soon I plug in USB 2.0 device (mouse, USB storage), all the USB ports stop working. Even if I plug in USB 3.x device.
                        The only way to get USB working again is disconnect battery and reset BIOS.
                        Has anyone had anything similar?
                        I have not yet tried another BIOS, but would that be the problem with USB?
                        Thank you.
                        03-19-2025, 12:15 PM
                      • Gabriel Lucas
                        microsoft surface pro 5 touch screen not working
                        by Gabriel Lucas
                        Hello everyone, I bought a Microsoft Surface Pro 5 and the touch doesn't work. According to what the previous owner said, the screen stopped working after an update. The screen has no physical damage, and the touch works for 1 second when it turns on and then stops working. I've tried updating the drivers, formatting, and returning to factory defaults, but nothing worked. Can you help me?
                        02-18-2025, 09:24 AM
