Asus X555LA autostarts when charger in. OK on battery
  • Caimano
    • Nov 2020
    • 54
    • Italia
    Laptop Asus F554L
    Motherboard X555LA Rev 3.3 ;P/N : 60NB0810-MB1610 with soldered Intel i3 5010U. no graphic CPU
    I received the laptop as working, but with 3 problems :
    1) Laptop display not working, but ok with external monitor connected via HDMI
    2) Keyboard not working, but ok with external USB keyboard
    3) Laptop starts up and boots windows as soon as charger is connected, without pressing power on switch. Laptop always automatically reboots after shutdown or pressing power off switch if charger is connected. Everything ok if battery only is connected : it is possible to power on /power off by switch and does not reboot by itself after windows shutdown.
    I used boardview and repair guide attached to https://www.badcaps.net/forum/showthread.php?t=70958
    Problem 1 solved by fixing the display LED backlight circuitry, as laptop display was working but without backlight.
    Problem 2 solved by cleaning the keyboard connector.
    Problem 3 is still open and driving me crazy. Every thing works fine and I managed to install and use Windows 10 without a problem. Battery charges fine. But if AC charger present laptop automatically boots itself.
    So far I did the following checks/tests:
    - There is no CMOS battery on this board, but I tried to reset config by shorting many times JRST2201 and JRST2202
    - Cleaned MB with isoprophilic alcohol:no change
    - Looked for some autostart parameter in BIOS : found none.
    - Reset BIOS to deafults and tried to disable Fast Start, lid open and all boot parameters : no change
    - Removed all connectors from MB : no change
    - Tried a different power supply or new battery: no change
    - Replaced SIO chip with new IT8585E FXA (which regularly reprogrammed itself at first boot)
    - Installed latest BIOS using ASUS EZ flash utility : no change
    - Checked 3.3v on power on switch and signal and it goes low as expected when pressed (same as line PWR_SW#) . The PWR_SW# line never goes down by itself when attaching or using the charger,but goes low as expected when pressing the switch both with mains and on batteries.
    - Line PM_PWRBTN# regularly goes to 0v for a short while after pressing the switch and goes back to 3.3v. At this point it stays at 3,3V if on mains or goes to 0V if on battery (I don't know if this is correct)
    Windows has nothing to do with the problem as it happens even with just the MB.
    It looks like the typical problem which can be solved by resetting the CMOS or flashing the bios or replacing SIO, but not this time.
    After fixing many laptops which could not boot I am running out of ideas on how to repair this one which auto starts !?!
    Any help is highly appreciated
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3630
    • slovakia
    Re: Asus X555LA autostarts when charger in. OK on battery
    check for bad battery switching mosfets. this laptop use main battery as bios battery. so autostart is when is something bad with battery circuit
    • Sametbey
      • Jan 2021
      • 229
      • Turkey
      The number 5 pillar of the battery is 3.3 v RTC signal foot, the problem can be solved by installing external 3V battery. + 3v end will be connected to r2234 resistor
      I'm not happy to be so strong. because it's not humanly
      • Caimano
        • Nov 2020
        • 54
        • Italia
        I checked mosfet's as er ktmmotocross suggestion, but found no problem.
        I then followed Sametbey's suggestion to install a 3V battery between pin 5 of the battery and GND (LDO_V3.3) and problem is solved !!!!
        Now there is no autostart when charger is in the laptop.
        Thanks Sametbey! I spent days checking power on sequence and solution was elsewhere.
        Just one question for the experts : from what I understood the battery is supposed to provide 3V for RTC on pin 5. From what I saw neither the original battery (still working) nor the new one I bought (not original) give 3V on pin 5 to support rtc. How is this possible?
        Thanks again!
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3630
          • slovakia
          from what i know the ITE 8585E is programable and x555 dont have EC bios ic
          • Sametbey
            • Jan 2021
            • 229
            • Turkey
            Original battery is faulty. but the new battery doesn't provide 5 pin 3v? Should the bios be reset when new battery is installed? update to data.
            • Caimano
              • Nov 2020
              • 54
              • Italia
              I did some measurements with the new battery installed and found out that:
              -there are 0V on pin 5 when no charger is connected
              -there is a NEGATIVE voltage varying between -0,4 and -1,2V on pin 5 when charger is connected
              So I run into a faulty or not fully compatible OEM battery which I will try to return to seller to get a working one. In case this is not possible I will leave the external battery as a workaround.
              Thanks again for your help!!
              • Caimano
                • Nov 2020
                • 54
                • Italia
                Right, X555LA has just one main BIOS chip (8MBytes chip).
                EC chip is a programmable IT8585 chip : I installed a new unprogrammed chip and it was automatically programmed at first boot. So for this kind of motherboard there is no need to buy a programmed one.
                • ktmmotocross
                  Boardkiller
                  • Feb 2014
                  • 3630
                  • slovakia
                  but how did i know if EC needs programming when is programable?
                    NVDC charger configuration...
                    11-05-2024, 03:28 PM
                    ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                    Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                    The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                    for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                    Narrow VDC applications where the system power source is
                    either the battery pack or the regulated output of the charger.
                    This makes the max voltage to the system equal to the max
                    battery voltage instead of the max adapter voltage. Operating
                    at lower system voltage can improve...
                    11-05-2024, 04:43 PM
                  • mkdj
                    ASUS X571 no power : battery issue?
                    by mkdj
                    Mark and model: ASUS X571
                    Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                    Tests already made:
                    - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                    - I have removed...
                    07-14-2025, 09:16 AM
                  • flat-earther
                    how to prevent a connected charger from draining battery when not charging?
                    by flat-earther
                    I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                    So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                    but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                    So the battery is backfeeding the charger and being drained.
                    How can I prevent...
                    08-07-2025, 01:04 PM
                  • Bowline
                    by Bowline
                    06-11-2025, 10:13 AM
