Asus X555LD, Won't power back on after being shut down.
  • gcain
    • Jun 2016
    • 8
    First post here, if there is another forum that's better suited, let me know please.
    I have an Asus X555LD board come in with a blown backlight and no image.
    Managed to repair those two issues, but now the board will only turn on once when the power is connected. When I power it off, the adapter and battery need to be disconnected and reconnected before it will power back up again.
    Aside from that it seems to run okay.
    Any suggestions on where to start measuring?
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Asus X555LD, Won't power back on after being shut down.
    Do you have 3.3v on power switch?? If you do have then check RTC section. If you have schematic post it here.
    • gcain
      • Jun 2016
      • 8
      I've uploaded all the docs I have on this board.
      Will take measurements when I get back to the office again.
      • gcain
        • Jun 2016
        • 8
        @mcplslg123 I do have 3.3v on the power switch. It pulls low when I press it too.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          You mean backup battery or cmos battery need to be pulled?? I assume backup battery is what you mean. Have you checked Qm3024 fets(2 connected to dc in and the other one to battery output?? Gate voltage on fets at dc in?? Do you get charging indicator? I suspect something wrong with ac-dc output in charging section. have you flashed bios??
          • gcain
            • Jun 2016
            • 8
            @mcplslg123 I don't follow.
            I mean when I press the button the 3.3v goes low, as it should.
            Would I really need to flash the bios?
            • caspian
              • Oct 2015
              • 1591
              • Laptop
              Bios flashing is not recommended now until you finish some basic measurements to discover what the problem may be.
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Yes, it can be 'coz of bad bios and thats why i recommended flashing bios. I dont know why caspian differed with me in opinion. Btw, you didnt replied to my query regarding fets.
                • gcain
                  • Jun 2016
                  • 8
                  Sorry mcplslg123, the cmos battery comment made me thing you had the wrong thread.
                  I can't find a faulty mosfet, they all seem to measure okay (I'm not familiar with PC though, I tend to only work on Apple Logic boards).
                  One thing I have noticed, the IT8585E IC (KBC I think) get's so hot almost instantly that I can't put my finger on it when the machine is running.
                  If you can direct me on what you need measure it would be helpful, I haven't had the ahhh-haaa moment with these yet and am wondering a little blind.
                  Edit: compare the IT8585E temperature with another board, and the known good board runs cold.
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    Oops that smells like a bad kbc. Resistance to ground on PIn26 or pin50 of kbc?? I feel you need to replace kbc.
                    • caspian
                      • Oct 2015
                      • 1591
                      • Laptop
                      Dear mcplslg123,
                      I always respect your recommendations. you helped me in a number of my laptop repairs. This is a great forum where experienced technicians cooperate in repairing laptops. This cooperation is really helpful.
                      Dear gcain,
                      Does any other component get hot too?
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        Dear caspian, I dont mind. Everyone's analysis or understanding will differ in some sense and thats good for a final solution as we can rule out the odd ones. Your contribution in the forum is great. Keep up the good work bro.
                        • gcain
                          • Jun 2016
                          • 8
                          26 = ~2MOhm or 0.416v in diode mode.
                          50 = same as above.
                          Those figures seem about right to me.
                          Not that I can feel.
                          I have the identical chip from another board, does it need to be flashed?
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            IT8585E is programmable but it will automatically be flashed once you turn the mb on with new kbc. Do remember to put up screen while turning on after installing new kbc so that you can see if any message pops up during kbc flash. Since you have a spare kbc , i'll suggest to change it.
                            • gcain
                              • Jun 2016
                              • 8
                              I swapped out the IT8585 for another and everything is working again.
                              Well, except for the trackpad, but I think that's another issue.
                              Thanks everyone for the advice and help.
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                Happy to know you fixed it.
                                • t.danes
                                  • Jan 2016
                                  • 8
                                  • ba
                                  Can anyone advise me on what I should focus on when the voltage fluctuates around 2.9v on the bios chip, there is instead of 3.3v, I also changed the bios chip and it is still the same without the bios chip there is 3.3v. I couldn't find the schematic anywhere
                                  • mon2
                                    • Dec 2019
                                    • 14725
                                    Remove all power -> meter in resistance mode -> check the resistance to ground of the bios pin (Vcc).
                                    If the voltage is dropping AFTER the bios is placed then there is a fault with the BIOS chip. Are you replacing with 100% same component? Check the solder connections. Some fault is causing this voltage rail to be lower.
                                    With the bios installed, is the logic board working properly?
                                    What is the part number of the original bios chip ?
                                    What is the part number of the bios chip that is causing this voltage rail to be lower?
                                    • PantherDave
                                      by PantherDave
                                      Hi all!
                                      I'm trying to troubleshoot a Microsoft Surface Pro (5th gen) model 1796 that won't power on. Motherboard model is M1007506-015. My priority is retrieving data, but the SSD is integrated so it looks like if I can't repair it it'll need to go to a data recovery company. I've done a little basic board repair before, but nothing this advanced until now. So please forgive my ignorance in advance. πŸ˜…
                                      05-29-2024, 02:01 PM
                                    • GLISIT
                                      by GLISIT
                                      01-16-2025, 02:29 PM
                                    • ShadowAi
                                      ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
                                      by ShadowAi
                                      Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
                                      Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
                                      After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
                                      03-15-2024, 10:46 AM
                                    • meraklinetx
                                      Asus Z97-a power cycle, no boot no cpu voltage
                                      by meraklinetx
                                      Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                                      05-10-2023, 06:08 AM
                                    • conghuyms
                                      Request for Help – ASUS G531GW Rev 1.6 – No Power On
                                      by conghuyms
                                      I need your support with an ASUS G531GW Rev 1.6 laptop.
                                      When I plug in the charger, the battery charging LED turns on, but the board does not power on when pressing the power button.
                                      Here’s what I’ve checked so far:
                                      • Motherboard has been removed for inspection.
                                      • 3V and 5V always-on rails are present (3V/5V_ALW).
                                      • 1.8V and 1.09V at the PCH are present.
                                      • I don’t have the boardview/schematic, so troubleshooting is limited.
                                      • I tried checking the power button signal from the
                                      07-20-2025, 09:14 PM
