HP G72 turning off randomly
  • Nightwalker
    • Oct 2012
    • 76
    • Greece
    Hello everyone!
    Laptop is a G72-b10sv. Had come again in the past with the common Ati 5470 gpu problem. Did a reflow and last about a year with every day of light use. Because of the simple use needed, i convert the board to UMA, transfering the two resistors(RI55 to RI51 and RI53 to RI56 and clearing the jumper PJ19. Also replace the thermal paste and the thermal pad on HM55.
    Install a new ssd and begun the windows installation from scratch, all went as it should, install everything and after an hour the first turn off occurs.
    After that, it turns off completely randomly, some times not even past the windows screen without turning off, others can stay on for 3 hours, others for some minutes. Trying with other known good ram, replace the cpu with same one (P6100), update the bios to final, temps are excellent. After i suspect the HM55, did a reflow there, but nothing change.
    I saw that many others have the same problems with this board (pm_i_hpc_s mv_mb_v3). Its the same for G62(15.6) and G72(17.3) laptops but noone has an answer to what is causing this.
    Anyone have an idea what is the root of the problem?
    Thanks for your time
  • Nightwalker
    • Oct 2012
    • 76
    • Greece
    Re: HP G72 turning off randomly
    Problem solved! Was the ME region on BIOS that need clearing!
    I dont know if i allowed to post an external link but
    i use a tool "Easy Intel Clean Me Region" and "Intel ME Firmware Database"
      • 21899
      The tool has been posted before and its not recommended for newer machines. Congrats on the fix .
      • retrorepair2
        • Feb 2023
        • 92
        Sorry to resurrect such an old thread but I'm wondering if this may be my issue with a GL703GM. Do you have to program the bios IC directly or can you use the ez flash tool in the bios? I know the update on Asus website doesn't include the ME region so wasn't sure if their tools can even flash to it.
        • Olvin1
          Acer nitro 5 an517-52 reflow/rebal CPU
          by Olvin1
          I’m kindly asking for help and advice regarding a reflow procedure for my laptop — Acer Nitro 5 AN517-52, which is equipped with an Intel Core i7-10750H processor.
          I own an ACHI IR 6500 infrared rework station and would greatly appreciate:
          • A detailed temperature profile for reflowing this specific CPU
          • Step-by-step guidance for a safe and effective reflow process
          • Tips on what to watch out for during the procedure
          If the reflow doesn’t resolve the issue, I’m also considering BGA reballing of...
          08-01-2025, 01:59 PM
        • tony359
          Reflow equipment
          by tony359
          Hello all,
          I am experimenting a bit with reflowing larger components - ideally I'd like to reflow a PS4 APU or a GPU for example.
          I know it's impossible to reflow such large components with just hot air so I bought a pre-heating plate, T-8280 classic Chinese machine, which seems to be working fine besides it's a little slow, which shouldn't be a big deal.
          Now, my hot air station is a Aoyue 852A++ and I feel it's a bit weak when used with larger nozzle. I tried reflowing a laptop chipset using one of those large, rectangular, nozzles and I failed miserably,...
          12-25-2021, 01:29 PM
        • thedigi321
          I have an LG 50PN4500-UA turns off and on randomly with 2 flashes before turning on
          by thedigi321
          showing power does nothing randomly turns on with 2 flashes: https://youtu.be/ZHME8GthErc
          Hello all I have an issue with my tv. I have had it for about 5-6 months because when I moved apartments the previous owner left the tv. and I got it for free it is a plasma tv and looks nice enough. an issue that started to happen was that it would kick off randomly but I could still turn it on well about a month or so I assumed the power button went out so I got a universal remote and programmed all lg codes and nothing just the solid red standby light so fast forward to a week ago...
          12-18-2019, 10:00 PM
        • Jeryswan
          LC-52LE81OUN Sharp Aquos turning off randomly.
          by Jeryswan
          I had a customer bring in their tv that shuts off randomly. The model # is LC-52LE81OUN. Aside from the television shutting off whenever it wants there doesn't appear to be any more symptoms. Any suggestions would be very much appreciated.
          11-12-2020, 05:25 PM
        • tvguy12012012120
          by tvguy12012012120
          02-07-2025, 05:13 PM
