LC-52LE81OUN Sharp Aquos turning off randomly.
  • Jeryswan
    • Mar 2020
    • 39
    I had a customer bring in their tv that shuts off randomly. The model # is LC-52LE81OUN. Aside from the television shutting off whenever it wants there doesn't appear to be any more symptoms. Any suggestions would be very much appreciated.
    Re: LC-52LE81OUN Sharp Aquos turning off randomly.
    You should post this in TV section and also provide the pictures of the whole backside of the TV showing all the boards so we can see what we are dealing with.
      • 20666
      Thread moved to TV forum .
      • scubacamper
        Sharp Aquos LC-70C6400U Half Screen Dark
        by scubacamper
        I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
        Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
        when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
        05-03-2025, 12:19 PM
      • jonah1024
        Sharp Aquos LC-40UG7252E LCD TV burn in?
        by jonah1024
        Hello!
        I'm a few days old into this TV screens repair universe so please bear with me.
        Recently, and all of a sudden my 40” 4K Sharp Aquos LCD TV turned on with colors all smudged in some places on the screen that remain like that even without any kind of video source. I do have image but the colors are smudged/tinted/ washed out in patches as per defects. This to me looks similar to burn in but I’m shore this is not an OLED.
        - I did the classic unplug and hold power button to discharge the caps but it didn't help.
        - I did a factory reset as well...
        07-16-2024, 04:23 AM
      • klassic
        Sharp Aquos LC-60LE635E three blinks
        by klassic
        Hi community,
        I will describe my problem with a TV in those short following terms to be the most precise :
        What i have :
        power board DPS-162KP-1
        main logic board QPWBXF733WJN2
        symptoms :
        white led light logo at startup,
        after 2 minutes, blinking 3 times a row, repeating
        no backlight (and apparently no picture, checked panel with flashlight)
        no startup sound
        powerboard investigations :
        1-2 PNL : 0v
        3-4 GND
        5-6-7-8 UR : 13.15v
        9-10-11-12...
        10-24-2023, 01:39 PM
      • dmcabs
        SHARP LC-60LE640X display flashing white noise patches and totally dropping out randomly
        by dmcabs
        Hey guys,
        I have a SHARP LC-60LE640X TV that has suddenly developed an intermittent fault of flashing white noise patches (appears like an Analog tuner off signal) and then totally dropping out.
        This model I believe is also known as LC-60LE600U or LC-60LE640U in other regions.
        FYI, a long time ago I was a component level repair tech for all consumer electronics and IT equipment.
        I'm a bit rusty but still have ability to dig right down.
        I measured all power supply lines and checked them for AC ripple voltage. Noting any lines that exceeded about...
        09-21-2024, 11:09 AM
      • foxyUK
        Sharp Aquos LC-32LE600E, No 12v as no PNL_POW
        by foxyUK
        Can anyone help me diagnose this? Almost not worth bothering with, but it has 'sentimental value' for the owner. I'm no TV technician, but dabble a bit.
        The TV has standby power but no reaction at all to switching on or reboot steps, No flashing lights or response to menu button. All voltages on the power board are correct apart from missing voltage on pin 12 of CN7003.
        There is 13 v on U7053 but no 3v signal to switch it on. I don't really understand whether the 3v should come from U7401 in the standby control area, or (as suggested elsewhere) from the mainboard via pin 12....
        10-22-2024, 10:27 AM
