HP ZS050 LA-A994P, charging light, power led on for 1 second when power button pres
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: HP ZS050 LA-A994P, charging light, power led on for 1 second when power button pr
    As per post#10, bios have 1.8V as claimed by the person who started this thread. As far as your case is concerned, what is the mb marking?? A lot of newer mb has DSW feature and 3v will be generated after power on only.
    • Sephir0th
      • Oct 2020
      • 1282
      Ah, just overlooked that. i had in mind, he has no 3VALW and schematics are telling the 1.8VALW were generated after 3VALW. So i still wonder how is it possible, to have 1.8VALW...
      However, thank you for responding so fast! And concerning my case: This has time. i'll open a thread when i got stuck...
      Greetings
      FairRepair on YouTube
      • MobileXT
        • Oct 2012
        • 199
        Thanks! I will request a BIOS Ver.2 at BIOS section.
        • MobileXT
          • Oct 2012
          • 199
          Greetings
          It was so weird because the first time I measured the voltage at PU301 I don't get nothing. When I check again this morning now I have the voltage output for 3VALWP and 5VALWP still don't have images on the screen so I'm guessing that the BIOS could be corrupted.
          • MobileXT
            • Oct 2012
            • 199
            After downloaded the BIOS from the BIOS section. I removed the BIOS chip on the motherboard to back-up the data but unfortunately my SOFI SP8 wouldn't detected the WINDBOND 25Q64F Can replaced the BIOS with a Micron N25Q064A and program the HP LA-A994P Ver.2 BIOS?
            • sopik78
              • Nov 2013
              • 517
              • Czech Republic
              #26
              No, it won't work. Micron N25Q064A needs +3V power supply.
              You probably need 1.8V adapter, like this for my EZP2010
              • MobileXT
                • Oct 2012
                • 199
                I do have the EZP2010 but I'm getting hard time to install the drivers I did 4 laptop and two desktop they are window 7 and windows 10 and no luck for me to install the driver.
                • sopik78
                  • Nov 2013
                  • 517
                  • Czech Republic
                  #28
                  Send PM for drivers, with EZP2010 may be you don't need adapter for 1.8V.
                  • Anethra
                    • Dec 2018
                    • 70
                    • Turkey
                    #29
                    i want to say a few things about la-a994 and la-a996 these models bioses can corrupt easly. Most of the things I've encountered so far have been bios failure. and when i used bios from internet no screen. my suggestion is that first of all, you need to study the problem by using the bios you downloaded from the original website on these models. and if you need ec i added attechment. have a good day.
                    https://www.badcaps.net/forum/showthread.php?p=1018549
                    Last edited by SMDFlea; 01-26-2021, 09:20 AM. Reason: EC moved to a new thread in bios requests section
                    • MobileXT
                      • Oct 2012
                      • 199
                      I agree that my case is a BIOS problem turn on turn off turn turn off same behavior like the MacBook Pro if the EFI corrupted.
                      • MobileXT
                        • Oct 2012
                        • 199
                        I manage to install the drivers for my EZP2010 programmer I did Backup the original BIOS and flash the one I downloaded here and I have the same behavior turn on turn off turn on turn off. I have all the power rail what else need to be check. RTC power? Clock signal?
                        • MobileXT
                          • Oct 2012
                          • 199
                          Where is VR_ON generated? is this signal from U44?
                          • PantherDave
                            by PantherDave
                            Hi all!
                            05-29-2024, 02:01 PM
                          • ipatch
                            troubleshooting microsoft surface pro 4 no power no led charge light
                            by ipatch
                            hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                            10-05-2023, 11:59 AM
                          • russpall
                            LG 39ln540v - red light flashes twice, no power to LED driver?
                            by russpall
                            Hi there,
                            I've got a 39" LG 39LN540V that's just spontaneously stopped working! The symptoms are - when I plug it in, the red light will flash on twice, then go out, there's no visible picture, and I couldn't see anything using a torch on the panel either. If I press the power button (either remote or on TV), the red light comes on continuously. If I press power again, the red light flashes twice.
                            The TV is using a power board EAX64905301. I've attached a diagram of the power output, I've tested the voltages with a multimeter and I'm getting the following:
                            08-27-2024, 01:07 PM
                            by sam_sam_sam
                            03-31-2024, 02:12 PM
                            Laptop computer that went completely dead no boot no power light no hard drive light
                            by sam_sam_sam
                            See pictures for type of laptop computer
                            I checked switching power supply brick 19.2 volts multi meter only
                            No booting without switching power supply connected
                            Checked switching power supply with an (28 volt ) incandescent light bulb it lights then hooked up the switching power supply again now the laptop and boots like normal
                            What the heck is going on here...
                            04-04-2025, 04:58 AM
