MacBook Pro 15-Inch "Core i7" 2.2 Mid-2015 A1398 LCD PROBLEM
  • mantza
    • Sep 2020
    • 36
    • GREECE
    hello, a customer brought me this laptop, a1398 2015, and the lcd shows horizontal lines and sometimes the image crashes. I tried with another lcd cable but no luck, with another lcd assembly it works fine. Anyone knows if this could be repaired? Or at least if anyone can tell me what it is. Is it from the lcd flexes, is it from pressure? It does not have any dents on the screen or liquid damage. I have seen similar lines in a a1502 before and it was also lcd problem.
    thanks
    https://ibb.co/q7MJvTb
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 674
    Re: MacBook Pro 15-Inch "Core i7" 2.2 Mid-2015 A1398 LCD PROBLEM
    LCD issues in these models tend to not be repairable HOWEVER, you can repair them if you know how to remove the LCD Digitizer and buy the LCD kit to do so. In most cases the Digitizer is failing on this LCD. I would suggest buying a USED one since the market is very short on these LCD at the moment. If your working LCD works then you pinpointed the issue.
    Also if the LCD just didnt turn on at all and wasn't cracked and your LCD worked, Louis Rossmann shows you how to repair a resistor on the LCD to get it working again. Just food for thought!
    sigpic
    MEOWING IN THE IMPOSSIBLE UNIVERSE!
    • piernov
      • Jan 2016
      • 4439
      • France
      These aren't touchscreen, there's no digitizer.
      • Stephen
        Meow Meow MEOW!
        • Apr 2020
        • 674
        Sorry correction I meant the LCD itself. Replace the internal LCD component not the housing. That is the only solution I can think of
        sigpic
        • piernov
          • Jan 2016
          • 4439
          • France
          The bare LCD panel won't be much cheaper than a full assembly but it'll be very difficult to replace, you risk breaking it and you have a higher chance of getting a low quality panel than buying a used assembly from a trustworthy supplier.
          This LCD is the most expensive but that's how it is. Getting it replaced by Apple may even be a better solution at this point…
          • mantza
            • Sep 2020
            • 36
            • GREECE
            thank you for the responses, i know about the Louis video, its a capacitor he replaces, i hoped maybe there's something like that for this problem and we can fix these. Also the one i have does not seem to be the same, it has a shield over the components in the back of the lcd board. I also thought about replacing the connector on the lcd but i dont think thats the issue. I have already informed the client he needs to replace the whole assembly, of course im not gonna try and replace those ridiculously fragile and expensive lcd panels. Also i think apple only services devices for 5 years so i dont think they even replace these screens any more.
            thanks again
            • rounin
              MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
              by rounin
              I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
              🛠 Original Issue
              The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
              ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
              04-19-2025, 01:18 AM
            • psdavid65
              Macbook Air A1466 820-3437-B Booting Problem
              by psdavid65
              I received a 2013 Macbook Air A1466 820-3437-B motherboard with serial number C02L6GQ9FSV8 that came in WITHOUT a bios chip. I got a new bios chip and reprogrammed it. Macbook now powers on but doesn't boot the SSD. I've flashed a ton of bios but still same problem. Windows installation works with this Macbook but never a mac installation. Unfortunately, since I didn't receive this macbook with a bios chip, I don't have the original bios. What can I do now?...
              06-20-2024, 12:27 AM
            • Skrndelj
              Apple Macbook Air M1 A2337 Trackpad problem
              by Skrndelj
              Hello all,
              I am repairing a Macbook A2337 and i have a problem
              The Macbook is stuck in restore as someone before me tried a DFU restore and bricked the device, now i can't do a restore as AC2 throws error 1 which is related to the trackpad.
              When i turn on the device i get the trackpad click for a few moments and then nothing, i tried 7 trackpads and 7 trackpad flats, i know all 7 are functioning okay, especially one as i use it for testing and DFU restore.
              I inspected the whole board and everything seems fine.
              Can anyone help me as i didn't fiddle with trackpad...
              06-11-2024, 04:26 AM
            • sdogs
              Macbook Air 2020 A2179 820-01958 battery problem?
              by sdogs
              I have a MacBook Air A2179 in my hands that had power problems (5V to the USB-C port intermittently).
              After a first inspection I could see that the D3302 protection IC was burnt out, so I replaced it but the problem was not solved, it seems like intermittent 5v input.
              I then replaced the two u3200s (CD3217B12ACE) and now I have stable 20 volts and the macbook has turned back on.
              Unfortunately I have a further problem, it works very slowly and the fan runs at maximum and if I disconnect the charger it turns off, it's as if the battery was disconnected.
              02-08-2024, 08:00 AM
              Apple MacBook Pro 15'' A1398 051-00330 820-00138 Schematic & Board View
              Apple MacBook Pro 15'' A1398 X435 051-00330 820-00138 Schematic & Board View
              A1398 main board resistance measurements (user submitted no further details)...
              10-01-2024, 06:58 AM
