Macbook Air 2020 A2179 820-01958 battery problem?
  • sdogs
    • Feb 2016
    • 90
    • Italy
    I have a MacBook Air A2179 in my hands that had power problems (5V to the USB-C port intermittently).
    After a first inspection I could see that the D3302 protection IC was burnt out, so I replaced it but the problem was not solved, it seems like intermittent 5v input.
    I then replaced the two u3200s (CD3217B12ACE) and now I have stable 20 volts and the macbook has turned back on.
    Unfortunately I have a further problem, it works very slowly and the fan runs at maximum and if I disconnect the charger it turns off, it's as if the battery was disconnected.
    I measured the voltage at the battery connector (j6950) and I have 12v at pin 1 and 2 (PPVBAT_G3H_CONN), 3.3V at pin 3 and 4 (SMBUS 3V3_BATT_SCL E SDA) and 0v at pin 5 (SYS_DETECT_L)
    Maybe the battery is dead? Did it discharge too much?
    I've done some other checks and everything seems normal, or am I doing something wrong?
  • mon2
    • 14694
    If you have a slow CPU and high fan speed, you have a sensor fault. The sensor faults are often linked to a non-working I2C / SMBUS line. These are party lines where multiple slave devices are addressed by unique addresses inside each sensor. If anyone pulls down the line, the entire network of devices will fail to operate. Locate each I2C / SMBUS on the board and verify their voltage to ground for each SCL / SDA line. If this is not practical, remove all power (no battery) and check each SCL / SDA line using DIODE mode on your meter.
    Red meter probe to ground; black meter probe to the I2C line to test. Do also review again the ESD protected battery lines but with out the battery using diode mode. The trackpad features some of these sensors as well.
    • sdogs
      • Feb 2016
      • 90
      • Italy
      when I received the macbook it didn't charge but it worked normally only with the remaining battery charge. I waited for the components to arrive which I then replaced and now it has this problem. If the sensors had been faulty he would have had the same problem, could it be the battery that stopped working?
      • mon2
        • 14694
        Try a PRAM reset since the battery area was the region of repair. Your SMBUS lines for the battery are ok if at 3v3 for each SCL and SDA line.
        MacBook Air SMC and PRAM reset - Apple Community
        • sdogs
          • Feb 2016
          • 90
          • Italy
          unfortunately the SMC reset did not give the results I was hoping for, today I should receive a new battery to test, I hope it works.
          The only thing that I didn't understand well and would like to understand, the SYS_DETECT_L signal should be the communication between battery and logic, is this correct?​
          • mon2
            • 14694
            No. This is just an active low (since suffix is _L) signal to inform to the charger IC that a battery is present.
            The communication is over the 2 smbus (i2c) lines which are scl and sda.
            • sdogs
              • Feb 2016
              • 90
              • Italy
              Thank you so much for your help, you help me understand and I am very grateful ;-)
              Am I referring to this part of the diagram?​
Name:	Schema I2c scl e sda.png
              • mon2
                • 14694
                The posted schematic is just one network of i2c pins. This segment swings to 1v8. There are others onboard. Confirm that each is operational. You can confirm by checking the voltage of each scl and sda line or by removing all power and check the same lines in diode mode. Red meter probe to ground. Black to the pin to test.
                The track pad has a few sensors so be sure the cable is properly seated. If a sensor is not detected, the fan spin will be high and the cpu will be throttled.
                • sdogs
                  • Feb 2016
                  • 90
                  • Italy
                  Thanks Mon2, your help is always precious ;-)
                  Yesterday I tried a new, non-original but good quality battery and the MacBook works!!!
                  The problem related to the sensors seemed strange to me, when they entrusted it to me it only worked on battery power.
                  In summary, I replaced both U3200 and D3302 and the logic was resurrected!!!​
                  • cheebster
                    Macbook Air 2020 A2179 Internet Recovery and Battery Issues
                    by cheebster
                    Hello, i have a batch of 10 Macbook Pros A2179 bought from a Costco return wholesaler.
                    The 10 of them show the exact same behavior;
                    They auto power on, to internet recovery spinning globe, fans to 100%.
                    Power consumption on USB-C port is 0.43a, shuts down as soon as unplugged. Battery doesn't charge at all. However, it boots to 20V on the Ampmeter.
                    Based on their iBridge versions (4.x and 5.x) these were shelfed for a long time.
                    All of them power on the same way; 100% fans, shut down as soon as they are unplugged. Removing...
                    10-09-2024, 06:23 AM
                  • Bowline
                    by Bowline
                    06-11-2025, 10:13 AM
                  • thuygsm
                    Macbook Air 2020 A2179 820-01958 (5V to the USB-C port unstable)
                    by thuygsm
                    I have a MacBook Air A2179 in my hands that had power problems (5V to the USB-C port unstable).
                    I noticed there is liquid at U3200 and U3100 and have replaced them.
                    PP1V5_UPC_X_LDO_CORE : 1.575V
                    PP3V3_UPC_X_LDO : 3.280V
                    PP3V3_G3H_RTC: constantly fluctuating from 0.5V to 3.284V
                    I have isolated R6979,
                    Pin 1: 3.280V stable
                    Pin 2: 0.447 (diode)
                    PPBUS_G3H: 12.28V (with R6979 isolated)
                    PPBUS_G3H: fluctuates 5V -> 4V -> 6V -> 12.28V(when R6979 is present), and repeats in a loop
                    What should I do next?
                    10-29-2025, 06:02 AM
                  • CAPTGENE
                    A2179 Macbook Air turns ON and works normally with a battery but it is not charging
                    by CAPTGENE
                    I have similar a similar issue. My A2179 Macbook Air turns ON and works normally with a battery but it is not charging. With the USC-C alone it takes 20V but only 100mA, PPBUS is 12.3Volts, and wont turn ON.
                    I replaced U7000 twice with the same result. not charging!
                    Whats should I check or replace?
                    02-20-2025, 02:58 AM
                  • gboone
                    820-00850 2019 MacBook Pro 13" Touch Bar (A1989) mysterious battery drain
                    by gboone
                    Hi, I was given this laptop by my uncle who said:
                    • It would occasionally shutdown if not plugged in
                    • battery had been replaced
                    • touchbar would "strobe"
                    I disconnected touch bar components and strobing and sudden shutdowns were fixed. Recent updates were installed to the OS.
                    After fully charging the battery, with bluetooth disabled, no LAN cable and only wifi enabled, the laptop stayed on (screen on) for about 6-8 hours. Allowing screen to turn off while not in use, and it went for over a day.
                    BUT
                    When powered off, it would at some point have a...
                    01-27-2025, 09:12 AM
