Macbook Air 2015 no backlight
  • mon2
    • Dec 2019
    • 14663
    Re: Macbook Air 2015 no backlight
    Yes, the charge pump ic for the backlight could be defective. It took us 3 attempts to get it right for the soldering.
    Suggest to use sticky flux for the site along with kapton tape to protect any nearby parts you do not want to fly away.
    Use 400-500c hot air temps but low air pressure so parts for not fly away. Personally like 20-30 setting on our 860 on our unit from Best tools. Amazing hot air tool.
    When you think you have it right, power up without the lvds cable.
    Check the voltage out on the lvds connector. From memory, it should be 25v or higher if soldered correctly.
    Download the data sheet and review the schematic from Texas instruments. It is the same typical design used by Apple. This is very helpful to understand how this backlight device works.
    The good thing is that the part is cheap. Available from Arrow electronics.
    From memory, I recall the Apple schematic having a value for the voltage rail expected from this backlight controller if working correctly.
    What value do you see?
    As noted, our effort took 3 attempts to get it right but we did this without a microscope. Still on my wish list of purchases. Debating between desktop vs. mono style. The optics appear to be higher for desktop like used by Hussein at Northwest repair. About $1k usd for that setup.
    • vieuxchoub
      • Oct 2017
      • 34
      • france
      HI, friends!!!!
      I have reordered 10 new LP8550 IC, from Aliexpress, from a good reputation seller. My 5 first LP8550 have all being soldered without success... I solder with a Quick 861DW hot air station, with a low air blow (at 30) to avoid others components to fly away... At first, I had fixed my temperature at 500°C, as usual, then 420°C, then 280°C, considering that this LP8550 is small and contains a heat sensitive mosfet. I use a *10 magnifying microscope that I have bought 220 euros to my local electronics dealer and which gives a clear view of the chip alignement... Looking from the side, the microscope shows good contact of the bga balls under the IC with the board. Of course, I use tacky flux, from Chipquick, which usually works well.... To sum up, I do not understand this failure to repair this backlight......
      • piernov
        • Jan 2016
        • 4439
        • France
        Don't buy from Aliexpress when you can get the chip from real distributors like Mouser…
        • vieuxchoub
          • Oct 2017
          • 34
          • france
          Thanks for the advice, Piernov!!! I have a real admiration for your knowledge and all the valuable teachings you give us. Mouser has expensive shipping fees.... Would you advise another real distributor with cheaper shipping????
          • vieuxchoub
            • Oct 2017
            • 34
            • france
            On Texas Instruments datasheet of the LP8550, the peak solder temperature is mentionned to be 260C, when we solder at 500, 420, 400 or even 280C, we are far above the TI recommendations.........
            • vieuxchoub
              • Oct 2017
              • 34
              • france
              #26
              I have found ARROW, to be an official TI official distributor, with free shipping and I have been able to order 10 original LP8550 for 22 euros, comparated to 14,50 with Ali...
              • mon2
                • Dec 2019
                • 14663
                What are the values for the attached sections of the backlight circuit?
                • vieuxchoub
                  • Oct 2017
                  • 34
                  • france
                  #28
                  Hi!!!!
                  My PPVIN S0SW LCDBKLT FET line shows 8.5v....
                  I have not measured EDP BKLT EN neither BKLT PLT BST L, because if I get those 8.5V, the mosfets work correctly and it seems that I get no boost which should be LP8550 fault.....
                  • mon2
                    • Dec 2019
                    • 14663
                    What are the readings on the left side of the mosfet?
                    According to the schematic, should be about 12v.
                    • piernov
                      • Jan 2016
                      • 4439
                      • France
                      #30
                      Never trust voltage indications in schematics.
                      • mon2
                        • Dec 2019
                        • 14663
                        This voltage is important.
                        What are voltages on Q7706,
                        Pin 3 ?
                        Pin 4 ?
                        The left side is PPBUS_G3H. If 8v6, that is too low.
                        Believe to have the same logic board at the office.
                        Will confirm the same asap.
                        • piernov
                          • Jan 2016
                          • 4439
                          • France
                          #32
                          PPBUS_G3H is always 8.4/8.6V on MacBook Air.
                          • MobileXT
                            • Oct 2012
                            • 214
                            Originally posted by vieuxchoub
                            Could it be that my LP8550 ICs are defective???? I have changed it again this morning twice, at 280°C, with a very good look of the bga balls soldering under the microscope....
                            I rechecked the continuity of the SW and FB lines, with voltages of 8.3v of the FB line and 8.5v of the SW line.....
                            I do not understand what could be the problem...
                            It could be one of the DATA line problem if your Backlight voltage is 40V but if you have 8V then LP8550.
                            • vieuxchoub
                              • Oct 2017
                              • 34
                              • france
                              #34
                              Dear friends!!
                              Thank you for all your answers....
                              I have measured the voltage at Q7706: pin3=2,82v and pin4= 8,55v but I had the surprise to measure 19,6v, for the first time after the backlight diode and at pin 3 and 4 of the LVDS connector. I have reassembled the Macbook: the result is better but not good. I get backlight but just on the right half of the screen and this backlight is slightly blincking....
                              What could it be??? Corroded LVDS connector???
                              Thanks a lot again for your help
                              • vieuxchoub
                                • Oct 2017
                                • 34
                                • france
                                #35
                                I have a post on Louis Rossmann forum of a guy having the half dim screen after soldering a backlight driver, like me... And like him, I had some problem in the led return lines: ISEN1, ISEN2 and ISEN3 were around 0.58v in diode mode measured at the resistors while ISEN4, ISEN5 and ISEN6 were OL...
                                I have tried to reflow my LP8550 and ISEN6 is at 0.58V now, while ISEN4 and 5 stays OL despite their balls under LP8550 viewed from the side under the microscope seem to attached..... Probably, my Chinese LP8550 is somehow defective. Maybe the backlight could work correctly with only ISEN 1, 2, 3 and 6 connected but it seems safer to change again this damned LP8550 with one genuine from ARROW that I am waiting for.....
                                • mon2
                                  • Dec 2019
                                  • 14663
                                  @vieuxchoub, I think it is very good news on your discovery so far. Sounds like you will have this working soon.
                                  Do you purchase a lot of goods from Arrow? We do, and have a good shipping
                                  status with them and believe we can (drop)ship for free to Europe. We are in Canada. Let us know if you need any help on the sourcing of the same backlight driver IC. We order this from them all of the time. Great support for them to offer this level of service.
                                  • Constantinos
                                    Macbook Air Early 2015 820-00165 No Backlight
                                    by Constantinos
                                    Hello everyone.
                                    I am trying to repair a friend's macbook air.
                                    The initial problems were that there was nothing on the display.
                                    The board was water damaged.
                                    After disassembly, I noticed that the fuse was still ok but there was a burned capacitor.
                                    After cleaning the entire board with IPA and replacing the capacitor (L8304 on schematics), I now have the picture without backlight.
                                    The macbook boots and everything works, except for the backlight
                                    There was considerable water damage around the u7701 chip
                                    I haven't repaired macbooks before, but after watching...
                                    07-16-2023, 01:58 PM
                                  • Comp_Pro
                                    No Backlight Macbook A1990 820-01041
                                    by Comp_Pro
                                    Hello all,
                                    Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                                    Tests performed:
                                    There is no backlight even with a good screen.
                                    Backlight IC is receiving the correct support voltages.
                                    Fuse F8400 ok
                                    Current sense resistor R8400 ok
                                    Backlight IC is receiving 3.3V on enable pin.
                                    Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                                    Backlight IC receiving 5V from PP5V_G3S
                                    Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                                    I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                                    05-06-2024, 10:23 PM
                                  • Constantinos
                                    Macbook Pro A2442 820-02098 No image but has backlight
                                    by Constantinos
                                    Hi all
                                    I have a Macbook Pro A2442 with the 820-02098 from a friend which has no picture on the display, however, the backlight works.
                                    He was streaming a football match on a questionable site, then the site crashed, and the problem emerged.
                                    Initially, he sent it to apple, who quoted him £1323.95 to replace the display, lid angle sensor and top case.
                                    Obviously, he decided against this and gave it to me so that I could have a crack at it.
                                    From initial diagnostics, I connected to an external monitor, I first tried with a HP 22W monitor, and I booted into the boot menu...
                                    08-24-2024, 09:48 AM
                                  • francescoranchi
                                    MacBook Pro A1909 LCD (no backlight)
                                    by francescoranchi
                                    Hello Everyone,
                                    I'm looking at purchasing a used LCD from ebay for my macbook A1990 2018 15inch which LCD I cracked. Since new / used but working displays cost around 500$ , I found a Grade A+ LCD display for A1990 which has a good price of 110$ but has no backlight.
                                    I would need just to make sure that what I know/my reasoning is correct:
                                    - No backlight means flexgate issue, therefore changingthe flexcable would be enough (I can microsolder to fix the flexgate problem, done it a few times already)
                                    - Seller confirmed its a LCD issue, and not an issue with the...
                                    12-04-2023, 06:46 AM
                                  • tommy97
                                    Apple MacBook A2337 - No backlight
                                    by tommy97
                                    Hi guys, I've got MacBook Air a2337 with no backlight. Once while testing it displayed with the backlight, however after restart problem come back.
                                    The laptop was tested with fully working screen.
                                    PP5v_BKLT_A/B 5V
                                    PP5v_BKLT_D 5V
                                    PP5V_S2 5V
                                    PP5V_SW_LCD 0.4V
                                    P5VS2_PWR_EN 1.8V
                                    P5VS2_BST_R 8V
                                    P5VS2_SW 5V
                                    PPBUS_5VS2_VIN 5V
                                    PPVOUT_LCDBKLT - Doesn't short 0V
                                    FP800 - Both sides 12v
                                    BKLT_EN_R & BL_PWR_EN - around 1.8v
                                    LP800 0.014V On both sides (should be 12? / no short)
                                    UC300 & UP800 Replaced...
                                    12-02-2024, 08:26 AM
