Macbook Air 2015 no backlight
  • vieuxchoub
    • Oct 2017
    • 34
    • france
    Dear friends from badcaps.net!!
    May I request some piece of advice for a Macbook Air 2015 820-00165 motherboard, waterdamaged, with no backlight....
    I have cleaned the board in the ultrasonic bath, then investigate its electronics. The Macbook boots up, chimes, displays the log in screen and, after cleaning the keyboard is responsive. There is no backlight and its circuit voltage, measured at the connector, diode and output capacitors is 8.20v. The BKL EN resistor R7731 was burnt and desoldered. I have replaced it and the BKL EN line shows 2.8v... but the backlight output is always at 8,20v. The fuse, the diode are good. The vin is at 5.20v. The grounds are good. All the voltages around the backlight IC are good: SCLK, SDA at 3.3v except the PWM which is between 0.9 and 1.5v. I have changed the backlight IC, LP8550, new and original three times with still the same result: no backlight and still, 8.5v on its line....
    What can I do more or should I change the board?????
    Thanks for your advices!!!
  • zpi
    • Feb 2018
    • 132
    • Lithuania
    Re: Macbook Air 2015 no backlight
    Did you cheked LVDS socket?
    Also remove LP8550, and check feedback and boost pads continuity to other side of board on Coil. After liquid damage often test points are eaten away for Boost and Feedpack Via's.
    • vieuxchoub
      • Oct 2017
      • 34
      • france
      Hi ZPI
      I have forgotten to say that I have checked the feedback line continuity which was good... I had 8.2v on the track leading to the A5 pad of the backlight IC when AC and screen plugged in. The LVDS socket was slightly oxydized but not seriously, not burnt....
      I have read that the PWM line comes straight from the CPU and is responsible for dimming but also activation of the backlight IC and that its supposed voltage should be 3.3v....
      • zpi
        • Feb 2018
        • 132
        • Lithuania
        PWM line is signal line, your multimeter cant measure it correctly. But you can short bklt_en with pwm to be sure if you want. But 1.5 on pwm looks ok to me.
        You need to check not only Feedback continuity, also check U7701 PIN 6,7 continuity to L7701 PIN 2.
        If you have image on screen, it eliminates bad LVDS connector, because if connector was bad, you still would get 30-50v on output.
        • piernov
          • Jan 2016
          • 4435
          • France
          Also confirm SMC_LID is high, and make sure there are no missing components around LED driver IC.
          • vieuxchoub
            • Oct 2017
            • 34
            • france
            OK, thanks for the advices... I will check tomorrow the continuity of U7701 pin 6,7 and coil L7701
            May I ask to Piernov, my French colleague, what is SMC LID??? High??? I confirm that there are no missing components, resistors, either capacitors around U7701....
            • zpi
              • Feb 2018
              • 132
              • Lithuania
              SMC_LID has to be 3.4v, it is magnetic sensor on your magsafe board. When your Lid is closed it pulls down 3.4v to 0v, and backlight disappears. So yes, SMC_LID has to be high, but i think if SMC_LID is low, you should not have BKLT_EN, no ? Or jus PWM will go low?
              Just in case, measure smc_lid rail, to be sure.
              • vieuxchoub
                • Oct 2017
                • 34
                • france
                Dear friends
                SMC_LID is at 3,36v, measured at pin 1 of the keyboard-trackpad connector J4800 when the lid is open, at 0 when the lid is closed... which seems correct
                BKLT_EN is at 2,79v measured at the divider resistor R7731 which seems also correct
                I have checked the continuity between pads 6,7 of U7701 and pin 2 of the coil L7701. The voltage on the track close to pads 6,7 of U7701 is at 8,5v
                But I still have no backlight
                Thanks for your answers
                • dellxps15
                  • Feb 2014
                  • 1588
                  • italy
                  i had fixed some backlight macbook air, and if i remember good, when u have 8 volt on diode, it mean lp8550 is not working properly.
                  check A5 pad if it is in good condition
                  • zpi
                    • Feb 2018
                    • 132
                    • Lithuania
                    You did not check continuity, you just cheked voltage ? You have to remove lp8550, and check how many ohms from pad 6 and 7 to L7701. Put probe dirrectlt on pad, also check feedback pad to diode in ohms.
                    • dellxps15
                      • Feb 2014
                      • 1588
                      • italy
                      on that video is well focused on ur problem, and after lp8550 was replaced he replaced the diode.
                      https://www.youtube.com/watch?v=-7_paJiwMO8
                      • vieuxchoub
                        • Oct 2017
                        • 34
                        • france
                        Hi zpi!!!!
                        I have scraped the solder mask on the mm closest to pins 6 and 7 of U7701 and my microscope showed that this track is continuous with pin 6 ball, I have checked the continuity with pin 2 of L7701 and got the bip, then I have checked the voltage of pins 6 and 7 , on the copper just close, and measured 8,5v....
                        This board went first to a professionnal shop in Greece: Computer Systems, in Thessaloniki, they changed the fuse which was good and the U7701 ( with a chip where nothing was written on..) and were unable to make the backlight work again.... They have sent it back unrepaired. Then, I have decided to check by myself. I have found no voltage on BKLT EN which I have fixed but this stupid board refuses always to light up its backilght.....
                        The diode is definitively good and let the 8,5V go to the led screen...
                        I have measured pins 3 and 4 of the lvds connector and I get 0.565V....
                        • vieuxchoub
                          • Oct 2017
                          • 34
                          • france
                          In diode mode......
                          • zpi
                            • Feb 2018
                            • 132
                            • Lithuania
                            Have you cheked continuity from pin 6,7 (or scrapped off via near) to L7701?
                            • vieuxchoub
                              • Oct 2017
                              • 34
                              • france
                              Yes, dear zpi friend, I have checked the continuity between the copper near pins 6 and 7 of U7701and L7701 and it bipped very clearly
                              I will remove my last soldered U7701 and check again . I will resolder a new LP8550, just in case
                              • vieuxchoub
                                • Oct 2017
                                • 34
                                • france
                                Good morning, friends!!!
                                I have removed U7701 and the pads either A5 of feedback and A6, A7 of SW look good and are in continuity with L7701, on the other side of the board.... I have resoldered a new U7701 with no luck..... I had my Quick hot air set at 420°C (blowing for a short time). I will try another time another chip with my Quick hot air at a lower temperature, 350°C, just in case that a too high temp could spoil the chip.....
                                Any other idea????
                                • zpi
                                  • Feb 2018
                                  • 132
                                  • Lithuania
                                  R7753 and R7757 check voltages on pins2.
                                  Also next time checking continuity, better do in in ohms mode, then you can see even if continuity is not very good (like 5-10ohms).
                                  • vieuxchoub
                                    • Oct 2017
                                    • 34
                                    • france
                                    R7757 and R7753 have 3.3V on each pins. They are 0 ohms resistors in good continuity on my board...
                                    • vieuxchoub
                                      • Oct 2017
                                      • 34
                                      • france
                                      Could it be that my LP8550 ICs are defective???? I have changed it again this morning twice, at 280°C, with a very good look of the bga balls soldering under the microscope....
                                      I rechecked the continuity of the SW and FB lines, with voltages of 8.3v of the FB line and 8.5v of the SW line.....
                                      I do not understand what could be the problem...
                                      • mon2
                                        • 13938
                                        Updated with a new post...
                                        • Constantinos
                                          Macbook Air Early 2015 820-00165 No Backlight
                                          by Constantinos
                                          Hello everyone.
                                          I am trying to repair a friend's macbook air.
                                          The initial problems were that there was nothing on the display.
                                          The board was water damaged.
                                          After disassembly, I noticed that the fuse was still ok but there was a burned capacitor.
                                          After cleaning the entire board with IPA and replacing the capacitor (L8304 on schematics), I now have the picture without backlight.
                                          The macbook boots and everything works, except for the backlight
                                          There was considerable water damage around the u7701 chip
                                          I haven't repaired macbooks before, but after watching...
                                          07-16-2023, 01:58 PM
                                        • Comp_Pro
                                          No Backlight Macbook A1990 820-01041
                                          by Comp_Pro
                                          Hello all,
                                          Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                                          Tests performed:
                                          There is no backlight even with a good screen.
                                          Backlight IC is receiving the correct support voltages.
                                          Fuse F8400 ok
                                          Current sense resistor R8400 ok
                                          Backlight IC is receiving 3.3V on enable pin.
                                          Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                                          Backlight IC receiving 5V from PP5V_G3S
                                          Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                                          I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                                          05-06-2024, 10:23 PM
                                        • Constantinos
                                          Macbook Pro A2442 820-02098 No image but has backlight
                                          by Constantinos
                                          Hi all
                                          I have a Macbook Pro A2442 with the 820-02098 from a friend which has no picture on the display, however, the backlight works.
                                          He was streaming a football match on a questionable site, then the site crashed, and the problem emerged.
                                          Initially, he sent it to apple, who quoted him £1323.95 to replace the display, lid angle sensor and top case.
                                          Obviously, he decided against this and gave it to me so that I could have a crack at it.
                                          From initial diagnostics, I connected to an external monitor, I first tried with a HP 22W monitor, and I booted into the boot menu...
                                          08-24-2024, 09:48 AM
                                        • francescoranchi
                                          MacBook Pro A1909 LCD (no backlight)
                                          by francescoranchi
                                          Hello Everyone,
                                          I'm looking at purchasing a used LCD from ebay for my macbook A1990 2018 15inch which LCD I cracked. Since new / used but working displays cost around 500$ , I found a Grade A+ LCD display for A1990 which has a good price of 110$ but has no backlight.
                                          I would need just to make sure that what I know/my reasoning is correct:
                                          - No backlight means flexgate issue, therefore changingthe flexcable would be enough (I can microsolder to fix the flexgate problem, done it a few times already)
                                          - Seller confirmed its a LCD issue, and not an issue with the...
                                          12-04-2023, 06:46 AM
                                        • tommy97
                                          Apple MacBook A2337 - No backlight
                                          by tommy97
                                          Hi guys, I've got MacBook Air a2337 with no backlight. Once while testing it displayed with the backlight, however after restart problem come back.
                                          The laptop was tested with fully working screen.
                                          PP5v_BKLT_A/B 5V
                                          PP5v_BKLT_D 5V
                                          PP5V_S2 5V
                                          PP5V_SW_LCD 0.4V
                                          P5VS2_PWR_EN 1.8V
                                          P5VS2_BST_R 8V
                                          P5VS2_SW 5V
                                          PPBUS_5VS2_VIN 5V
                                          PPVOUT_LCDBKLT - Doesn't short 0V
                                          FP800 - Both sides 12v
                                          BKLT_EN_R & BL_PWR_EN - around 1.8v
                                          LP800 0.014V On both sides (should be 12? / no short)
                                          UC300 & UP800 Replaced...
                                          12-02-2024, 08:26 AM
