No Power MacBook Pro 13" A1706 Touchbar 2016
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 674
    Need a little help here. Plugged in USB C tester. Getting 20V and 0.06Amp.
    Starts at 5.00+Volts then jumps to a steady 20V but no Amps jump. I looked for power rails and G3H is present. Tested 1V0 Rails at PP1V0_SUS and I am not getting Voltage at all points. This is the first rail I am testing and nothing is showing. Tested the board for heat and there is no heat emitting from the CPU. Dead CPU atm. Can someone pinpoint me what area I should be testing! Any help would be appreciated thanks!
    sigpic
    MEOWING IN THE IMPOSSIBLE UNIVERSE!
  • ammarben
    • May 2013
    • 63
    • algeria
    Re: No Power MacBook Pro 13" A1706 Touchbar 2016
    test 3v3 present in bios chip U2890
    test 3.3v in power button
    • Stephen
      Meow Meow MEOW!
      • Apr 2020
      • 674
      Thank you! WIll keep you posted!
      sigpic
      • SarcasticOP
        General question about MacBook power rails for repair.
        by SarcasticOP
        I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
        • PPBUS_G3H (12.6V-12.8V)
          • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
        • PP3V42_G3H (3.42V)
          • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
        • PPVRTC_G3H (3.3V)
          • This
        12-12-2024, 05:50 PM
      • PantherDave
        by PantherDave
        Hi all!
        05-29-2024, 02:01 PM
      • GLISIT
        by GLISIT
        01-16-2025, 02:29 PM
      • waakye
        2016 MacBook Pro 13 inch Touchbar no power
        by waakye
        Hi folks,
        Got this MacBook pro 13 inch for dirt cheap because the seller said it doesn't turn on. Upon opening the laptop, and investigating the screen connector mainly the camera and backlight cable, it seems that the backlight cable was somehow repaired because there is an electrical tape on it. I am suspecting that it was a flex gate repair that went south.
        My question is that what components be damaged if a flexgate repair was not done right.
        Thanks for all for chiming in.
        10-09-2023, 03:41 PM
