Need help 820-00923 no backlight Newbie here
  • alontest
    • Aug 2018
    • 25
    • nowhere
    Hello there, newbie here
    Have a MacBook pro to repair with no backlight. Thought that it was a faulty screen, so tested with good known working screen but still no backlight. There are no liquid signs at all on the board, the board looks clean as new.
    So started tracing all power rails and spot that PPVIN_S0SW_LCDBKLT was missing after Q8400 so found and replaced faulty capacitor C8473 and that fixed this rail but still have no backlight.
    Started investigating further and spot that U8400 LCDBKLT_FET_DRV is 0V and it can't open Q8401. So is it a U8400 faulty or the issue could be somewhere else ?
    These are the readings from U8400:
    LCDBKLT_SW - 0.12V
    GND_BKLT_SGND - 0V
    LCDBKLT_FET_DRV - 0V
    PP5V_S0_BKLT_D - 5.13V
    ISNS_LCDBKLT_N - 13.03V
    ISNS_LCDBKLT_P - 13.03V
    BKLT_SD - 9.32V
    BKLT_PWM_KEYB - 0v
    BKLT_SCL - 4.61V
    BKLT_SDA - 4.52V
    BKLT_EN_R - 3.34V
    PP5V_S0_BKLT_A - 5.13V
    BKLT_SENSE_OUT - 0V
    LCDBKLT_FB - 11.19V
    GND_BKLT_SGND - 0V
    Any suggestions would be more than welcome.
    P.S. The MacBook starts and works perfectly just no backlight, I can see Apple logo and so on.
  • MobileXT
    • Oct 2012
    • 214
    Re: Need help 820-00923 no backlight Newbie here
    Did you check for shorted on the backlight power rail?
    • alontest
      • Aug 2018
      • 25
      • nowhere
      Fixed it, the problem was faulty Q8400
      • triplefour
        by triplefour
        09-13-2023, 10:43 PM
      • DanPoka
        by DanPoka
        02-15-2025, 05:05 AM
      • cheebster
        iPad Pro 12.9 5th Gen Backlight Issue
        by cheebster
        Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
        Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
        Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
        The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
        Anyone...
        05-20-2025, 09:17 AM
      • canadaboy25
        LG Flatron 24EN33TA No Backlight When Cold
        by canadaboy25
        I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
        I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...
        03-07-2023, 12:23 AM
      • gabrielA7
        Macbook pro A1706 / Backlight flex cable compatibility
        by gabrielA7
        Hey guys!!
        I’ve got a question here!
        I have a MacBook Pro A1706 that needs the backlight cable replacement — the well-known issue — but the problem is that the code on my original cable is 821-00571-A, and the one I have on hand to install is 821-01229-A.
        Well, I asked ChatGPT about it, and the guy told me they’re not compatible and it could even burn the backlight circuit!!
        Here’s what the bot told me:
        I said to him: “I’m going to install the 821-01229-A.”
        ChatGPT replied:
        Understood — but before you solder or install the 821-01229-A,
        11-11-2025, 03:26 PM
