ASUS UX510U won't Charge after Charging IC Replacement.
  • Sephir0th
    • Oct 2020
    • 1255
    Hello @all and i'm Glad to be Here.
    I have a Strange issue with the Laptop after Repairing it. The Prepossessor Just Killed the Board by replacing the Keyboard.The Charging IC BQ24780 was shorted on PIN28 and the 10 Ohms Resistor on this Rail was blown too.
    I can't explain how unbelieveble hard it was to solder a new IC. I Had issues all the Time to Connect the solder Joints with the IC, Just a mess. And i replaced it 4 Times. I felt Like an Idiot all the Time. And it is actually haunting me in my nightmares. Never Had Problems Like this while replacing a IC.
    Howewer, finally i managed it to be Sure, all Pins are soldered properly. The Laptop is working fine, recognize the Charge of the battery but is Not Charging.
    There is a Strange battery blink Code, 4x Flashing Green, that is Not described in any manual. And it blinks even If the Battery is disconnected. Maybe this behaviour gives Someone Here a hint.
    Yesterday i found a shorted High-Side mosfet with 50 Ohms between Source and Gate. I'm Sure it wasn't shorted at the beginning of my measurements. I replaced it, now have 200k Ohms beetween Source and Gate, but still have identical voltages on Gate und Source (11,58V). I believe this isn't okay. I have 0V on Gate of the low-side mosfet and 200K beetween Source and Gate. Between drain and Source/Gate i have MegaOhms in both Mosfets.
    Battery is already replaced. Maybe i'm working too Long on this Board. Any Idea Would be helpful.
    Thank you in advance and merry Christmas!
    FairRepair on YouTube
  • stingerchamp
    • Sep 2020
    • 425
    • Pakistan
    Re: ASUS UX510U won't Charge after Charging IC Replacement.
    Check voltage at battery connector pins
    With charge plugin only
    • Sephir0th
      • Oct 2020
      • 1255
      Without battery I have
      12,65V on +,
      3,274V on Clock and
      3,265V on Data.
      • stingerchamp
        • Sep 2020
        • 425
        • Pakistan
        Check same voltage data and clock at charger ic
        Check i-out voltage and with DSO check clock
        • Sephir0th
          • Oct 2020
          • 1255
          Jo
          Voltages of Clock and Data on IC Side are identical.
          You mean Input Voltages for Charging Controller? Everything seems fine, 19,14V VCC, 3,026V ACOK, 2,704V ACDET, 6,060V REGN. Actually around 24,8V in ACDRV and 12,4V in BATDRV (without battery).
          If you are asking to measure Clock with Oszillator, i have to Tell: No Oszillator available...
          No more Diagnose possible without?
          And sorry If i didn't Understand all what you wrote. I'm still a beginner and english isn't my native language.
          Greetings!
          Edit: i have attached the Boardview. Hopefully it will Help a Bit.
          • stingerchamp
            • Sep 2020
            • 425
            • Pakistan
            Can you share schematic
            I am outside using mobile phone 📱
            Is there any version for mobile ,boardview
            • Sephir0th
              • Oct 2020
              • 1255
              I am outside using mobile phone ��
              Sorry, afaik No schematic available and i was even not able to Open it with Android boardviewer. There is a repair Guide, but i Would say nothing helpful inside for this Case.
              Anyway No need to hurry. This repair already lasts sooo Long. So i'll be Happy If you or Someone Else Take a Look soon.
              Greetings
              • Sephir0th
                • Oct 2020
                • 1255
                Good evening,
                i have a datasheet and some measurements for you. I hope something obvious here.
                PQ8901 (1st DC-IN MOSFET)
                S --> D 3,5 MegaOhms
                S --> G 1,1 MegaOhms
                D --> G 1,0 MegaOhms
                PQ8902 (2nd DC-IN MOSFET)
                S --> D 14,0 MegaOhms
                S --> G 6,2 MegaOhms
                D --> G 3,8 MegaOhms
                PQL8901 (LowSide Battery MOSFET)
                S --> D 2,6 MegaOhms
                S --> G 2,9 MegaOhms
                D --> G 213 KiloOhms
                PQL8901 (HighSide Battery MOSFET)
                S --> D 5,0 MegaOhms
                S --> G 2,0 MegaOhms
                D --> G 153 KiloOhms
                PQL8903 (Battery-to-Sys MOSFET)
                S --> D 53 KiloOhms
                S --> G 3,5 MegaOhms
                D --> G 2,5 MegaOhms
                Charger IC - Texas Instruments BQ24780S
                Voltages with Adapter only // with Adapter & Battery
                Pin 01 - ACN: 19,94V // 19,94V
                Pin 02 - ACP: 19,94V // 19,94V
                Pin 03 - CMSRC: 19,38V // 19,37V
                Pin 04 - ACDRV: 24,94V // 24,88V
                Pin 05 - ACOK: 3,027V // 3,026V
                Pin 06 - ACDET: 2,705V // 2,705V
                Pin 07 - IADP: 129mV // 128mV (194 KiloOhms to GND)
                Pin 08 - IDCHG: 11mV // 11mV (191 KiloOhms to GND)
                Pin 09 - PMON: 126mV // 126mV (10 KiloOhms to GND)
                Pin 10 - PROCHOT: 5,184V // 5,187
                Pin 11 - SDA: 3,264V // jumping beetween 3,23 and 3,26V
                Pin 12 - SCL: 3,273V // jumping beetween 3,23 and 3,27V
                Pin 13 - CMPIN: 2,071V // 2,089V
                Pin 14 - CMPOUT: 1,960V // 1,970V
                Pin 15 - BATPRES: 0,5mV // 0,4mV (9,9 KiloOhms to GND)
                Pin 16 - TB_STAT: 3,373V // 3,373V
                Pin 17 - BATSRC: 12,65V // 11,58V
                Pin 18 - BATDRV: 12,63V // 11,57V
                Pin 19 - SRN: 12,64V // 11,58V
                Pin 20 - SRP: 12,64V // 11,58V
                Pin 21 - ILIM: 1,172V // 1,171V
                Pin 22 - GND: GND // GND
                Pin 23 - LODRV: 46,7mV // 0,1mV (209 KiloOhms to GND)
                Pin 24 - REGN: 6,057V // 6,062V
                Pin 25 - BTST: 17,49V // 11,30V
                Pin 26 - HIDRV: 12,84V // 11,58V
                Pin 27 - PHASE: 12,66V // 11,58V
                Pin 28 - VCC 19,17V // 19,27V
                Checked all resistors around the IC and all seems okay except PR8919 with 69 KiloOhms instead of 100 KiloOhms and PR8921 with 80 KiloOhms instead of 180 KiloOhms. No Cap short to ground.
                Battery-Connecter
                Pin 1-3 - BAT: 12,65V // 11,58V
                Pin 4 - DAT CLK: 3,274V // 3,274V
                Pin 5 - DAT BAT: 3,265V // 3,265V
                Pin 6-8 - GND: GND // GND
                Thank You in advance!
                EDIT: Doublechecked IDCHG ang got new measurements.
                • stingerchamp
                  • Sep 2020
                  • 425
                  • Pakistan
                  Pin 01 - ACN: 19,94V // 19,94V. _ok
                  Pin 02 - ACP: 19,94V // 19,94V. -ok
                  Pin 03 - CMSRC: 19,38V // 19,37V. _ok
                  Pin 04 - ACDRV: 24,94V // 24,88V -ok
                  Pin 05 - ACOK: 3,027V // 3,026V. -ok
                  Pin 06 - ACDET: 2,705V // 2,705V. -seems ok check voltage divider
                  Pin 07 - IADP: 129mV // 128mV (194 KiloOhms to GND). Not ok
                  Not ok
                  Not normal
                  Prochat is active on low so ok
                  Data signal need DSO but value ok
                  clock signal need DSO but value ok
                  Pin13 cMPIN: 2,071V // 2,089V ok
                  Pin 14 - CMPOUT: 1,960V // 1,970V ok
                  Problem when battery not plugin it should go high
                  You plug or not it is same which is an issue
                  Problem
                  active on low,
                  high means boost mode is off
                  Batdrv is shorted to batdrv , batdrv should be 6v above batsrc to turn on power via battery
                  Problem
                  Vilm= 20 multiple (vsrp-vsrn)
                  Check voltage divider resistor resistance
                  Pin 24 - REGN: 6,057V // 6,062V ok
                  Pin 25 - BTST: 17,49V // 11,30V ok
                  Pin 26 - HIDRV: 12,84V // 11,58V ok
                  Pin 27 - PHASE: 12,66V // 11,58V need DSO
                  Pin 28 - VCC 19,17V // 19,27V ok
                  Check page 19 pin 10 prochat is active on low
                  You plug or not plug , nchannel mosfet is off means battery is present all the time
                  It should go down when battery removed
                  Batpress active on low, it is also not changing
                  If those high value resistor are connected to charging ic
                  Replace them and check
                  Need DSO for frequency check phase pin
                  • Sephir0th
                    • Oct 2020
                    • 1255
                    Sorry, but Would you again explain for me what you have found. My thought was, PROCHOT is o.k. as you mentioned before. I Understand it Like protection function for Adapter and battery, If the CPU consumes too much Power. And in this Case PROCHOT Goes Low.
                    Maybe you can clarify it for me If i Understand it wrong.
                    I noticed that too. The Charging Circuit seems to believe there is a battery plugged all the Time, even If the Battery is unplugged. Very weird.
                    I'll Check Pin 17/18/mosfet again and the Resistors too.
                    Many thanks for your Feedback!
                    • stingerchamp
                      • Sep 2020
                      • 425
                      • Pakistan
                      First those resistors which you measure have high resistance replace them
                      Second oscilloscope is mandatory to check clock and data, SDA and scl
                      Check resistance of SDA resistor and scl resistor pin 11 and pin 12 resistors should be ok till battery connector
                      Both should be exact 100 ohm resistor
                      Resistor resistance increase due to which clock and data does not communicate with KBC
                      To check it we need oscilloscope
                      Prochat goes high for 10ms to signal battery plugin or removed
                      10ms small time so again need oscilloscope to check
                      • piernov
                        • Jan 2016
                        • 4435
                        • France
                        If battery percentage is reported properly, charging circuit SMBUS shouldn't be the problem.
                        • Sephir0th
                          • Oct 2020
                          • 1255
                          Yes, it Shows correct percentage in BIOS, 60% charged at the beginning of the repair attempt and it is fully working from battery too. Actually it is 54% charged.
                          i have never Tried to load a OS, should i? Maybe It's Worth a try to flash the BIOS due to compatibility issues?
                          Now It's Family time, so i can't proceed with the repair until evening (5 - 6 hours) and start to replace the Resistors (i believe they are on ILIM Rail)
                          Greetings!
                          • stingerchamp
                            • Sep 2020
                            • 425
                            • Pakistan
                            Battery charging percentage will not increase until you get correct date
                            • Sephir0th
                              • Oct 2020
                              • 1255
                              OMG, i didn't know that. Are you Sure? But why? Whence do the Laptop know the difference? I tried to Charge the Laptop for half an hour while in bios.
                              Anyway i try it this way, Set time and Date and Boot in Windows 10. Maybe we know more after.
                              • Sephir0th
                                • Oct 2020
                                • 1255
                                Holy cow, i just installed Windows 10, The Battery LED now stays Orange and it is Charging! I can't believe and feel one more time Like an Idiot. What a waste Of time...
                                I Hope you'll forgive me. Thank you Guys!
                                • stingerchamp
                                  • Sep 2020
                                  • 425
                                  • Pakistan
                                  Congratulations 👏
                                  Next time you face same issue
                                  Go to device manager and delete battery manager or battery driver , it will automatically install at next restart
                                  • Sephir0th
                                    • Oct 2020
                                    • 1255
                                    OK, unfortunately we cheered to soon...
                                    So YES, it was Charging, BUT it charges Only if i Plug the Adapter First and the Battery after. Immediately after i unplug the Adapter, i get the orange Battery LED blink Code, that is telling me, the Laptop is in Battery-Mode and it has less than 10% battery left. But it blinks even If the Battery is Fully charged. Additionally Windows is saying, the Adapter is plugged, even If i unplug it. (The plugged Symbol disappears for one second in the Moment, i unplug the Adapter)
                                    It's the Same with a replacement battery. I Tried to uninstall the Windows battery Driver with No success. So obviously Something Goes wrong or isn't working on the Board after i unplug the Adapter.
                                    So i need some Further assistance to troubleshoot this new behaviour... and i'll come Back later with new measurements from the Charging Controller in Charging and non-charging condition, If there comes No Idea from the Community before.
                                    Thank you in advance!
                                    • Sephir0th
                                      • Oct 2020
                                      • 1255
                                      Good evening,
                                      now i have the time, to do the measurements. But Before, i have to tell something what i've found out and had already done:
                                      I found out, i can reproduce the following to get the Laptop charge:
                                      a) Unplug all, Plug the adapter first (Laptops does autostart) and the Battery after. It charges the battery
                                      b) Let the Battery completely discharge, till i'm not able to power it on one more time. Press the Power Button for 60 seconds. Plug the Adapter after (The Laptop does autostart). It charges the battery.
                                      Additionally i flashed the bios with cleaned ME, just to be sure. But nothing of the behaviour changed.
                                      So here are the values...
                                      So where are the obvious differences?
                                      1. The overall voltage dropped a little bit. Could be normal, because it is charging the battery right now.
                                      2. I have different voltages on the Gates for the charging mosfets
                                      3. The readings from SDA/SCL are much more stable.
                                      4. in my opinion are the readings from IADP, IDCHG, PMON and BTST conspicuous
                                      Any idea? TY in advance! =)
                                      • stingerchamp
                                        • Sep 2020
                                        • 425
                                        • Pakistan
                                        You just found the solution
                                        I hope I am right
                                        Vcc should be same as battery voltage when with battery only
                                        All voltages are ok , your charging ic working but
                                        Two points to check
                                        First external
                                        Second internal
                                        External check. ,. In battery mode only voltage is passing from battery to the CLR side from blocking mosfet or third mosfet in DC in line
                                        Because In battery mode vcc of charging ic is battery voltage for functioning of laptop obviously not charging function lol
                                        Vcc is missing
                                        Secondly when no adapter plugin third mosfet if n channel at CLR side should have battery voltage
                                        At SDA and scl battery connector there are 100 ohm resistor attached to these , check there resistance value should be 100ohm fixed , if DSO available you can check signal
                                        First confirm this then we look at low drive drive zero
                                        • ipatch
                                          troubleshooting microsoft surface pro 4 no power no led charge light
                                          by ipatch
                                          hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                                          10-05-2023, 11:59 AM
                                        • tofik
                                          MOSFET equivalent K8A60DA
                                          by tofik
                                          Hello guys,
                                          I have a shorted MOSFET K8A60DA with the following characteristics:
                                          Type Designator: TK8A60DA
                                          Marking Code: K8A60DA
                                          Type of Transistor: MOSFET
                                          Type of Control Channel: N -Channel
                                          Maximum Power Dissipation (Pd): 45 W
                                          Maximum Drain-Source Voltage |Vds|: 600 V
                                          Maximum Gate-Source Voltage |Vgs|: 30 V
                                          Maximum Gate-Threshold Voltage |Vgs(th)|: 4 V
                                          Maximum Drain Current |Id|: 7.5 A
                                          Maximum Junction Temperature (Tj): 150 °C
                                          Total Gate Charge (Qg): 20 nC
                                          Rise Time (tr): 25 nS
                                          Drain-Source
                                          07-19-2023, 05:18 AM
                                        • ruletero
                                          Acer a515-43 low battery charge voltage
                                          by ruletero
                                          Hi
                                          Acer A515-43
                                          LA-H801P
                                          Fail: Does not charge battery, has low voltaje on connector.
                                          Laptop didn't want to turn on, only charge led blinked.
                                          I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                                          I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                                          Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                                          10-24-2022, 02:31 PM
                                        • Klevjetack
                                          Charge a L19D3PDA battery externally from the laptop
                                          by Klevjetack
                                          Is there a way to externally charge a L19D3PDA battery from the laptop. I have a broken charging port on my laptop and am trying to find a way to charge the battery for it. I have been doing some research and I have found that there is a module, TP4056, that can be used to charge Li-ion batteries. It says it is used to charge single cell Li-ion batteries. The L19D3PDA battery is a three cell battery. Is it possible to use the module to charge my battery and it would just be very slow? Or would that be a bad idea. Is there a different kind of module I can use to charge my Li-ion three cell battery?...
                                          03-05-2024, 07:26 AM
                                        • razenxd
                                          How can I charge that battery pack?
                                          by razenxd
                                          it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
                                          At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
                                          Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
                                          Now, I have noticed a few things.
                                          The "dead" battery, while connected to charger and NOT Charging will...
                                          12-05-2024, 06:11 AM
