Sony DA0HK5MB6F0 MBX-269 problem
  • kahlenberg
    • Jan 2014
    • 7
    • Österreich
    I have a DA0HK5MB6F0 MBX-269 motherboard and it is not working. I have schematics and I checked all power supplies and found out that 1.05V 15A PS controlled by PU105 was not working. I checked MOSFETS PQ252 & PQ253 and PQ253 was damaged. I replaced it but still PU105 is not producing 1.05V.
    When I press power button, 3 LEDS LED_NUM1, LED_CAP1, LED_SCR1 are lighting and orange LED D13 (SATA_ACT) is lightning for 2-3 seconds. Then it powers down again.
    On screen there is nothing.
    What is the problem? I don't have any EEPROM programmer.
    If I replace KU1 NPCE885L, can it work?
    If yes, where can I find it?
    Thanks.
  • emestee
    • Dec 2019
    • 228
    • Bulgaria
    Re: Sony DA0HK5MB6F0 MBX-269 problem
    The power down is probably the result of protection kicking in. This suggests that the KBC code is executing.
    First figure out what's wrong with the 1.05 rail. Check its output resistance, the enable signals, gate drive oscillation, TONSEL signals etc.
    • kahlenberg
      • Jan 2014
      • 7
      • Österreich
      Thanks for answer.
      There is only one enable signal at PU105, pin 15. When I press power button enable signal is 3V. TON signal (pin 16) is 1V. Power supply for IC is 5V at pin 2.
      Output resistance is around 12 ohm. I measured it at PC493.
      Can I measure gate frequencies with multimeter? Is it DC and square wave?
      • kahlenberg
        • Jan 2014
        • 7
        • Österreich
        Ok, I was able to measure (or not measure) gate frequencies. My multimeter has also frequency measurement mode. When I measure other MOSFETs' gate, I can read some frequencies.
        When I measure gates of PQ252 & PQ253, there is no signal.
        So, that means PU105 is damaged?
        Where can I find it?
        • emestee
          • Dec 2019
          • 228
          • Bulgaria
          Urgh, I had to write this comment three times because the comment is glitching.
          The presence of TONSEL, both VDD inputs and the enable signal will make the chip attempt to start driving the gates. The problem is you can't really verify this without an oscilloscope. The protections will kick in really quick and the multimeter sampling wont be fast enough to catch it.
          You can replace the chip, but I'd suggest prior to that replace the high side mosfet just to be sure, and also test the components in the feedback circuits. I'm also curious if PR498 and PR499 are present on the board.
          • kahlenberg
            • Jan 2014
            • 7
            • Österreich
            High-side MOSFET seems to be ok. All componnets in the feedback circuits seem also to be ok. I can not find PR498 and PR499 in vicinity of PU105.
            I downloaded also .brd file but I can not open it in Eagle v9 or v6.
            I am getting "Error: line 1, column 1: Start tag expected."
            So, I really can not find the resistors
            Edit:
            Hmm, it seems that PC496 is not present. I don't know, maybe I removed it with hot-gun while replacing PQ253.
            What is this TONSEL signal? PC496 and PR374 build a RC oscillator?
            • stingerchamp
              • Sep 2020
              • 425
              • Pakistan
              .brd file open in openboardview.org
              • emestee
                • Dec 2019
                • 228
                • Bulgaria
                TONSEL sets the frequency at which the IC will drive the gate, basically.
                The resistor is to set the frequency, the capacitor is to dampen the fluctuations of the VIN line. The oscillator is internal to the chip. Without the cap the circuit will probably work but will lose some stability.
                • kahlenberg
                  • Jan 2014
                  • 7
                  • Österreich
                  Thanks for suggesting openboardview.org
                  Board looks like a little bit different but I could find PR498 and PR499. They both are on the board.
                  • stingerchamp
                    • Sep 2020
                    • 425
                    • Pakistan
                    Glad it worked 😊
                    • udai
                      • Oct 2014
                      • 6
                      • india
                      sir i have problem with da0hk5mb6f0 ... with low power button voltge .. showing only .5v.,
                      3v 5v ok , ac ok, dsw 3.3 v ok, rtc ok, still same even changed io , what makes 3.3 in power button . their is no pull up down ressistor found in it
                      pl help
                      • Chrissygizmo
                        Sony KD-55XG9505 lines on screen problem
                        by Chrissygizmo
                        Hello again everyone,
                        This is my latest mission, to try getting this Sony tv back to normal working order…
                        I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
                        02-19-2025, 11:31 AM
                      • crackedprint
                        Sony HCD-HX80R Amplifier Volume Control Problem
                        by crackedprint
                        I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
                        I have tried a Cold Reset as per the service manual.
                        I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
                        I have looked all the way through the service manual and tried many online...
                        01-21-2025, 12:18 PM
                      • retrorepair
                        SONY KDL-40P3600 Picture Problem
                        by retrorepair
                        Hello gurus, hope you can assist me...
                        I have a Sony KDL.40P3600, with an issue on the left side of the screen (pictures attached).
                        I think the problem is the panel, but before send it to trash, i would like to get a second opinion.
                        Thanks in advance.
                        10-11-2024, 05:12 PM
                      • YasaCh
                        sony kd-49xf9005 4 red blinking problem
                        by YasaCh
                        Sony KD-49XF9005 it power up to android boot screen and turns off immediately with continuously 4 red blinks ...
                        05-05-2025, 08:40 AM
                      • theone111
                        by theone111
                        3. Problem: TV shuts down
                        07-22-2024, 10:36 AM
