HP ENVY 15 no power
  • nassih
    • Oct 2015
    • 280
    • morocco
    HP ENVY 15 no power
    hello everyone
    its my second thread about this laptop
    I will wish that someone can inform me of these voltage values:
    PU12: pin1=1.6v pin7=8.6v(5vpcu).you can look in schematic
    you can take a look at the schematic above
  • emestee
    • 228
    Re: HP ENVY 15 no power
    1.6v is too low. The chip will not start switching. Check everything to the left of the EN signal.
    There should not be 8.6V on the LDO output. Unfortunately there's no datasheet for this specific chip. The LDO output is used for the battery/adapter LEDs in the charger circuit, as well as for the ODT circuit on sheet 13.
    My first guess would be the IC is damaged, but since this is exotic, you would want to rule out other sources first.
    • nassih
      • Oct 2015
      • 280
      • morocco
      indeed LDO should have a value of 5v because in the other side pu11 LDO is 3v and EN=0v
      • nassih
        • Oct 2015
        • 280
        • morocco
        PU12 is replaced too
        • nassih
          • Oct 2015
          • 280
          • morocco
          I noticed that before I replaced the pu11 SY8208b with SY8208C incorrectly i think
          • nassih
            • Oct 2015
            • 280
            • morocco
            SY8208b is 3 regulator, SY8208C is 5v regulator
            • emestee
              • 228
              If PU12 is pulled out, what would be the voltage on the enable signal?
              • nassih
                • Oct 2015
                • 280
                • morocco
                PU12 pulled out EN pin is 0v
                PU11 EN pin is 0v too
                • emestee
                  • 228
                  Check with an oscilloscope if possible.
                  • nassih
                    • Oct 2015
                    • 280
                    • morocco
                    on other motherboard same DC/DC +3VS5/+5VS5 PU11 & PU12 pin1 EN is 0V,LDO is coming when power button is pressed 3V,5V on coil PL21 & PL20
                    • nassih
                      • Oct 2015
                      • 280
                      • morocco
                      is not available in my workshop
                      • stingerchamp
                        • Sep 2020
                        • 425
                        • Pakistan
                        If you look at pu11 3vpcu there is a voltage divider attached to pin 7 ,what is voltage on pin7 and there is a npn transistor controlling sy8208cen
                        what is voltage on pin 1 ,2,3
                        Pu12 enable has s5_on signal is generated or not
                        • nassih
                          • Oct 2015
                          • 280
                          • morocco
                          I will inform you when I will be at my workstore
                          tanks
                          • nassih
                            • Oct 2015
                            • 280
                            • morocco
                            PU11 pin7 is 4.8v i thik
                            • stingerchamp
                              • Sep 2020
                              • 425
                              • Pakistan
                              Confirm it please
                              Voltage at r228 10 kilo ohm resistor on both ends as it is s5_on signal to generate enable signal for ic 3volt
                              and is npn transistor available at motherboard check schematic page sy8208c pq40
                              • stingerchamp
                                • Sep 2020
                                • 425
                                • Pakistan
                                If vin 19v then at pin 7 of pu11 we must have 4.391volts
                                • nassih
                                  • Oct 2015
                                  • 280
                                  • morocco
                                  hi im sorry for the delay
                                  yes u are ok for PU11 pin7 its 4.374V
                                  • nassih
                                    • Oct 2015
                                    • 280
                                    • morocco
                                    R228 i have 3.2v in on side without pressing power button and 0.089v in other side pin 100 of U11 ITE. but 3.3V is coming when i press power button
                                    • nassih
                                      • Oct 2015
                                      • 280
                                      • morocco
                                      PS :all voltages coming when power button pressed coming and disappear immediately
                                      • stingerchamp
                                        • Sep 2020
                                        • 425
                                        • Pakistan
                                        Is pq40 available?
                                        If s5_on is coming at pu12 pin it means pu12 ready to generate voltage at coil
                                        Do you get voltage at coil after power button pl20 coil
                                        Also mentioned check pq40 pin 1,2,3 its npn so need high voltage at gate which will ground sy8208c enable
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • themosttogain
                                          HP Envy 13-BA1565na with intermittent power button
                                          by themosttogain
                                          Hope someone can give me some suggestions on this because i'm at my wits end with it...
                                          I have an Envy 13-BA1565na here with an Intel Core i7 i7-1165G7 CPU (board is a LA-J475P Rev 1.0) which has an intermittent power button issue. The power button is integrated into the keyboard, and I have ruled out the keyboard, BIOS and battery as being the issue.
                                          Basically, on mains power, the power button works fairly well. The first time you come to it after leving it sitting (either on charge or not on charge), it might take 2 or 3 presses of the button, but then the laptop boots...
                                          07-12-2024, 03:03 AM
                                          03-31-2024, 02:12 PM
