Jtag io programer smsc mec1404-nu-gp
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    Hi its my firstime how to program this SIO chip I needed to put a jtag connector but I cant find were is the pinouts for this pin
    BOARD VEGAS/TURIS SKL7KBL 15341-1 91N85
  • emestee
    • 228
    Re: Jtag io programer smsc mec1404-nu-gp
    Look at the right side of the schematic you posted. The JTAG pins are driven out to resistors that tie them to ground/VCCSTG. Remove these resistors and solder in JTAG lines.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      This sio programmes automatically on first boot as long as its blank ie, new. Its practically impossible to program this thru any kbc programmer. Best option is to erase it(if kbc not new) and allow it to program automatically on 1st boot. I myself has tested it on this very mb besides dell LA-D071P.
        • 21853
        There`s a thread where you previously mentioned this kbc as not programmable
        https://www.badcaps.net/forum/showthread.php?t=75649 .I made an edit to post number 6 .
        Theres a post by the great man himself sergey vertyanov explainig whats going on
        https://ascnb1.ru/forma1/viewtopic.php?f=231&t=139487
        1.1 Boot ROM
        Following the release of the EC_PROC_RESET# signal, the processor will start executing code in the Boot ROM. The
        Boot ROM executes the SPI Flash Loader, which downloads User Code from an external SPI Flash and stores it in the
        internal Code RAM. Upon completion, the Boot ROM jumps into the User Code and starts executing.
        • kalilinux25
          • Mar 2018
          • 2089
          • ZAMBOANGA SIBUGAY
          1.1 Boot ROM
          great help sir very thankful for the info, that I cant program this sio chip
          • fox01fox02
            • Oct 2015
            • 28
            • iran
            Perfect....
            • Whale linguini
              General Question(s) & Question About USB Jtag u-Link NT
              by Whale linguini
              I'm not sure if I am posting this in the right spot, I don't have any question or anything specific to one board. I am *kinda* starting out with this kind of work. I have been IT in one role or another for my job the last 30 years, and I am familiar enough with basic board stuff generally speaking. So, I dunno for example if someone told me to find a uart header, or flash some generic tsop8 something, etc I understand that kind of stuff. Point being, I'm not 100% clueless. I just don't have the specific knowledge when it comes to some of these more advanced repairs. I actually have spent the last...
              07-26-2024, 02:12 PM
            • coolshrimp
              T14s - MEC-1663 - Jtag - Pinout - Bios Password Removal
              by coolshrimp
              Here is all the info you should need to remove bios password from your same model or one with an MEC-Chip and also write back the config data
              See Diagram for Wiring.
              Use MEC-1633#ISP on your RT809h
              This is same Jtag pinout and method for T490S/X390
              (But your R/W 10K Resistor Location May In a Different Location)
              MEC-Chips Store Bios Password In a Secure Un-Editable Area
              Following steps clear that secure area to re-initialize itself to default (Blank)
              10-24-2022, 12:18 AM
            • novator2007
              Help with finding ThinkPad T460 JTAG Points
              by novator2007
              Hello All,
              I got a T460 with issue - No picture - Fan on full Speed and no Power LED Light.
              Bios already reflashed
              All standard voltage is present. CPU on emergeny(?) mode - max 30 c Grad.
              By Schematc & BRD View I have found few Debug/Jtag points.
              Just not sure which one is correct,
              1.There is some(under lack) Test points near CPU - Schematic Page 6
              2. J9 26p place for connector - Present: PCH_TMS/TDI/TDO/TCK/RSMRST
              3. J8 26p place for Connector - XDP_TMS/TDI/TDO/TCK/RSMRST
              I trying to find a correct...
              08-02-2022, 07:49 AM
            • kapuzta
              CH341A programer (Not responding) , Freeze
              by kapuzta
              Hello
              I took the bios from my motherboard - succesfully can read the data from bios chip (Saved backup file on my PC)
              Downloaded new bios bin here but i cant write that to the chip (I have tried Asprogrammer, Neoprogammer) as soon as i click "write ic" the programs goes "Not responding" state and hangs there.​
              04-11-2025, 07:09 AM
            • ktmmotocross
              How to use EV2400 clone battery programer?
              by ktmmotocross
              Hello.
              As someone suggest i bought this EV2400 clone battery programmer. Now i have one battery that need to check, but i cannot find topic with guide.
              So what program should i use and how to check that battery?
              05-29-2024, 12:00 AM
