dell 7720 dual N mosfet keep burn, cpu VCC Core
  • casti3l
    • Mar 2014
    • 95
    • romania
    hello, i need help, i recived this laptop with a short, after a few min i identify the problem PQ43, i replaced the mosfet with normal N mosfet and laptop work for few day, after burned again. Now i tried many types of mosfet's, now it burn after a few min.
    In this moment i replaced PQ45, PQ44, PQ43 with BSC0924NDI, same thing 10 min working fine then die. PQ43 keep burn.
  • zpi
    • Feb 2018
    • 132
    • Lithuania
    Re: dell 7720 dual N mosfet keep burn, cpu VCC Core
    Hello, i think you should change PQ43 and PU10 at the same time. PU10 drives PQ43 so it can be culprit.
    • piernov
      • Jan 2016
      • 4437
      • France
      You have to use the same MOSFETs as what was on the board originally and replace the controller at the same time indeed as @zpi said.
      • casti3l
        • Mar 2014
        • 95
        • romania
        thank you, i will try to find identical mosfet, and also replace PU10. I will replay after that.
        • zpi
          • Feb 2018
          • 132
          • Lithuania
          @piernov, why they have to be same as originally on board? Can't they be different, just with same or better specs? I think you can, but have to make sure you look closely at datasheets.
          • emestee
            • 228
            They can be if you understand what the important parameters are in a given circuit. Sadly, we cannot expect that everyone who does this kind of thing understands deeply how e.g. MOSFETs work internally, and what physical properties have side effects that are meaningful for the operation of the boards. Frankly, I don't claim that I do. Experience shows that even the board engineers often don't, and that's how you end up with boards which have the same burned out transistors in the same place every time. So very often you get an answer that is technically correct, but errs on the safe side. "Better" in a load bearing circuit is different from "better" in a switching power supply.
            • piernov
              • Jan 2016
              • 4437
              • France
              Yes you could replace them with a different part number but there are a lot of parameters to be taken into account so it may not be easy to find a matching one. Also they must have the same part number across all phases in a multiphase buck converter.
              Some parameters to take into account:
              — Package and pinout (must be the same of course)
              — Vgs and Vds breakdown voltage (must be same or higher)
              — Id current rating (must be same or higher)
              — Rdson resistance (must be same or lower)
              — Ci input capacitance (similar or lower)
              — Qg total gate charge (similar or lower)
              — Tdon turn-on delay time (similar or lower)
              — Tdoff turn-off delay time (similar or lower)
              — Body diode forward voltage (similar or lower)
              Vds is a hard requirement but it's rarely a problem, you just have to make sure it's at least 30V.
              MOSFETs with higher current rating often have a lower Rdson, that's a good thing (less losses when turned on), but they conversely are often slower and harder to drive (higher input capacitance/total gate charge and slower turn-on/off delay times), so you can't got crazy on the current rating because it'll be counterproductive: the MOSFET will be much less efficient when switching and the MOSFET driver will have a hard time driving it.
              Some MOSFETs (very often the low-side on synchronous buck converters) have a schottky-type body diode, that has a lower voltage drop than a "regular" body diode. (otherwise it'd be less efficient)
              Thermal characteristics also play a small role in this so it's better to have a MOSFET with low thermal resistance overall. (this is often dictated by the package, but there are still variations)
              These are especially critical in multiphase buck converters like CPU VCore and GPU VCore since the MOSFETs are stressed a lot, these buck converters must suddenly deliver dozens of amps when there's a load spike. Even up to a few hundred amps on high-performance desktop parts.
              • zpi
                • Feb 2018
                • 132
                • Lithuania
                Thanks for good explanation
                • Jane
                  How do you test MOSFET in laptops ?
                  by Jane
                  I tried to use this method:
                  Testing an N-channel MOSFET:
                  Step 1: Discharge the Gate (turn off the MOSFET)
                  Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                  Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                  Step 2: Charge the Gate (turn on the MOSFET)
                  Now, place the red probe on the Gate (G) and the black probe on the
                  09-27-2024, 03:31 AM
                • DoOm86
                  Dual mosfet replacement help
                  by DoOm86
                  Hello.
                  I have a notebook with a shorted mosfet, it's a E6930 GA8125.
                  It seems to be a 30V dual asymmetric N-channel AlphaMos.
                  Luckily the notebook is working, so I just need to find a good replacement for this mosfet.
                  And here is where I need help!
                  It's the first time I have to replace this kind of mosfet, I checked on mouse and I found this: (mouser No) = 512-FDPC5030SG.
                  I need your help to be sure is a good replacement or there is another with better compatibility, since I can't find the same exact (just from China).
                  Thanks!...
                  10-31-2023, 12:03 PM
                • Nooy
                  VGA MOSfet permanently shorted and loss of MOSfet pad
                  by Nooy
                  Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
                  I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
                  02-14-2024, 02:26 AM
                  HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point EliteDesk 800 i7-7700T Specification for Upgrade or Repair
                  This specification for the HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point boardview and EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information....
                  09-12-2024, 02:00 PM
                • ktmmotocross
                  HP 16-a0023nc DAG3JCMBCE0 need to identify memory power controller ic after mosfet burn
                  by ktmmotocross
                  Hello.
                  Have this HP 16-a0023nc DAG3JCMBCE0 that have burned mosfet on i think memory power. both memory modules shorted. after remove mosfets i measure 10ohm on that line which is low so after remove ic i have normal reading. But i cannot identify this ic. can...
                  02-01-2024, 03:54 AM
