day31amb6c0 no 3.3V
  • nassih
    • Oct 2015
    • 276
    • morocco
    day31amb6c0 no 3.3V
    hello everybody i need a datasheet for this ic sy8208b its a controller 3.3v
    tanks
    • 20571
    Re: need SY8208B datasheet
    The datasheet isn`t available only a pinout from a motherboard schematic. Check carefully for the difference in pin 3 between the pinout and SY8208A datasheet - http://www.datasheetcafe.com/sy8208b...sheet-silergy/
    • stingerchamp
      • Sep 2020
      • 425
      • Pakistan
      You can check en pin voltage to confirm if your 3.3volt ic is safe or need to replace
      En pin should have above 1.5 volt to work
      • nassih
        • Oct 2015
        • 276
        • morocco
        tanks for reply i have the schematic of the motherboard day31amb6c0
        the problem of this laptop was the BQ24738H after the replacement I have the charge indicator, but the motherboard no power on, I have 5v on the coil pl21 and not 3.3v on the coil pl 20.
        • nassih
          • Oct 2015
          • 276
          • morocco
          • stingerchamp
            • Sep 2020
            • 425
            • Pakistan
            Ad_id pin voltage?
            Do you get ldo out 3 volt?
            KBC pin 100 is s5_on signal for en1 pin so we have voltage divider at en1. En will enable ic if voltage above 1.5 volt. Check coil impedance should be above 300 ohm.
            • stingerchamp
              • Sep 2020
              • 425
              • Pakistan
              Adding above check voltage at pu11
              Pin 1, 7, 6,8
              S5_on is coming if at pl 21 you have 5 volts
              Just to make sure supply is always or suspend?
              • nassih
                • Oct 2015
                • 276
                • morocco
                voltage at PU11:
                1:0.016v
                2:0v
                3:0v
                4:0v
                5:3.3v
                6:2.9v
                7:5.2v
                8:19v
                9:gnd
                10:0v
                • nassih
                  • Oct 2015
                  • 276
                  • morocco
                  no shorted to ground pl21 have 310ohm
                  • nassih
                    • Oct 2015
                    • 276
                    • morocco
                    yes sir,i have suggested on think :when i push power button i have all voltage coils except pl 21 0v and bios chip i have 5v.
                    its strange no!
                    • nassih
                      • Oct 2015
                      • 276
                      • morocco
                      pl21: 0.310 diod mode positive in the ground
                      • stingerchamp
                        • Sep 2020
                        • 425
                        • Pakistan
                        I told you en1 should be above 1.5 volt to work
                        Ldo is out 3 volt
                        Did you check KBC pin 100 for s5_on pin voltage?
                        First we have to make sure s5_on is coming then we check for below
                        What is bios chip I'd,
                        Do you have oscilloscope?
                        If not then locate crystal at motherboard it is just like a power diode with frequency written nearby like 20mhz etc.
                        Voltage should be 1.5 at crystal when check multimeter.
                        What is voltage on rtc cell ,must be above 2.8 volts.
                        • nassih
                          • Oct 2015
                          • 276
                          • morocco
                          KBC pin 100: 0v
                          bios 25B64BS
                          i don't have oscilloscope.
                          tell me plz sir what voltage i have to measure in pl21 because when i push power button i measure 5v not 3.3v its normal?
                          • stingerchamp
                            • Sep 2020
                            • 425
                            • Pakistan
                            Not normal 5 volt is there because en2 is giving 5 output which is internally shorted to pl 21 output connected pin .
                            S5_on is not coming from KBC that is strange
                            Check ad_id voltage and try replacing adapter
                            Bios Vol for this chip is 3.3volt
                            What is voltage on pl 20 coil ?
                            Check pin 11 of KBC ,you can check c350 cap which is connected to pin 11 of KBC. It will tell Io vcc is good or not
                            If pin 11 has 5 or 0 volt it means we need to replace 3.3 Vol ic.
                              • 20571
                              You have those 2 coils mixed up .
                              its strange no!
                              Are you sure, measure again. Take a picture of PU11 and 12 and measure again all voltages and resistance to ground on all pins.
                              • nassih
                                • Oct 2015
                                • 276
                                • morocco
                                Re: day31amb6c0 no 3.3V
                                hi everyone. I made a bad manipulation we are trying to take measurements on the ic pu12 I touch the pin 1 with the ground. this line comes from sio S5_ON pin 100. now I have no charger indicator.
                                pl20:0v
                                pl21:0v
                                pu12 voltages:
                                1:0.084v
                                2:0v
                                3:0v
                                4:0v
                                5:3.3v
                                6:2.8v
                                7:5v
                                8:19v
                                9:gnd
                                10:0v
                                my question is how can i check if sio is ok or not
                                plz help
                                • stingerchamp
                                  • Sep 2020
                                  • 425
                                  • Pakistan
                                  No need to worry ,excess voltage is bad for Io but here you have given zero volt to en1 which turned off 3.3 voltage ic and your KBC is getting power from 3 voltage chip
                                  Here we have to replace 3volt ic and your problem will get resolved
                                  • nassih
                                    • Oct 2015
                                    • 276
                                    • morocco
                                    hi everyone
                                    after replacing PR185,PR112 i have a adapter indicator ok,but still not working yet.with original adapter i have no voltages on pl20,pl21 even when i push power button.but with power supply i have 5v on pl21 and 0v on pl20 and i can see a consummation of 780ma also when i push power button; i have voltage on all coil except PL14:0.11v with strange voltage on bios chip 5v not 3.3v
                                    • stingerchamp
                                      • Sep 2020
                                      • 425
                                      • Pakistan
                                      Replace 3 volt chip asap
                                        • 20571
                                        hi everyone
                                        Why would you have 5V on PL21 it should be 3.3V .Check the part number on PU11 ,it should be SY8208B ,not C
                                          MSI Gaming GP62 8RD-052XRU World of Tanks Notebook GP Specification for Upgrade or Repair
                                          This specification for the MSI Gaming GP62 8RD-052XRU World of Tanks Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GP62 8RD-052XRU World of Tanks boardview and GP62 8RD-052XRU World of Tanks schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-06-2024, 05:00 PM
                                          MSI Gaming GP62 8RD-050RU World of Tanks Notebook GP Specification for Upgrade or Repair
                                          This specification for the MSI Gaming GP62 8RD-050RU World of Tanks Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GP62 8RD-050RU World of Tanks boardview and GP62 8RD-050RU World of Tanks schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-06-2024, 08:40 AM
                                        • pickledegg
                                          Dell Inspiron 7501 / Vostro 7500 (2020) - eDP connector pinout/panel compatibility question
                                          by pickledegg
                                          Hello. I have an Inspiron 7501 here, it's the same as a Vostro 7500 in some markets (no clue). I was looking to replace the LCD, the panels included with these models are terrible.
                                          I have the schematic and it is a 4 lane eDP port on the board but the pinout seems quite weird, my question is if anyone recognises this weird pinout and knows of any other Dell models that may use it or even any compatible panel models. I have the 40-40pin cable that was used for the models with touch but do not need touch capability, was just looking for a better quality screen and higher refresh to actually...
                                          10-02-2024, 04:54 PM
                                        • maleksa
                                          Korg Kross2 Service Manual and LCD pinout
                                          by maleksa
                                          The LCD on my Korg KROSS2 keyboard is cracked and needs to be replaced.
                                          However, the cost of a replacement LCD is almost the same as the price of a second hand Korg KROSS!
                                          Does anyone have a copy of Korg KROSS2 Service Manual? I want to see the PINOUT for the LCD connection. Perhaps I can find a compatible LCD screen and not have to spend a fortune on an original replacement LCD.
                                          From what I can gather, the LCD screen is a COG with serial interface (SPI). Is there any way I can ascertain (perhaps with the use of a multimeter or oscilloscope) the PINOUT by...
                                          10-11-2024, 05:54 AM
                                        • AlexVG
                                          SAMSUNG UE65HU8500 ONE CONNECT pinout connector request
                                          by AlexVG
                                          I came across with
                                          SAMSUNG UE65HU8500
                                          ONE CONNECT BN41-02135
                                          Chassis GOLF_UHD_1MP_JACK
                                          TV can not recognise ONE CONNECT box, so I need to know the pinout of the CN 3301 connector.
                                          Moreover, on the main is written A5V. However, cable connected this pin to the GND.
                                          Maybe somebody have an experience with the same issues?
                                          I need your help.
                                          Thank you....
                                          06-08-2025, 06:49 AM
