Asus X554LD
  • digitelos
    • Oct 2015
    • 20
    • Portugal
    Asus X554LD
    Hi, i have a pc Asus X554LD and when battery running out the screen flashes and sometimes screen stops but i still can move mouse, but got no actions at all.
    Any sugestions?
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Asus X554LD
    Does it work fine on ac power.Problem only in battery mode?? If yes, then change the coil in the backlit circuit of your screen.
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
    • FallenOne008
      Asus G712L No Screen Backlight
      by FallenOne008
      Hi everyone, hope all is well. I have run into a problem where my backlight screen is no longer working.
      The original screen was beginning to show signs of faultiness. I believe it was part of the inverter board that was going bad. The backlight for the screen was still functional at this point. Well one night as I was tinkering with the laptop, my idiot self forgot to disconnect the battery from the motherboard. I attempted to reconnect the EDP cable onto the motherboard, and as you might guess, I saw a nice spark from the cable and the port. Don't worry, I'm still kicking myself...
      03-31-2025, 08:27 PM
    • reformatt
      by reformatt
      07-31-2025, 08:37 PM
    • krige
      asus g750js ms1130c (203) turns on nothing on the screen
      by krige
      hi all i was wondering if you could help me troubleshoot this laptop. i bought the motherboard off eBay. it is used. i fitted the motherboard into the housing of the gaming casing and turned it on. nothing shows up on the screen. i checked the connectors and no missing connectors. i also removed the graphics card and nothing on the screen. i even reflashed the bios but still nothing on the screen. can it be a corrupt bios? i even used the HDMI port but it also shows nothing on screen. could this be broken screen or a dead ec chip?...
      03-22-2024, 04:59 AM
    • Technodoc
      ASUS G614JZ G634J-PMV-VGT Rog Strix need some bios help, laptop black screen
      by Technodoc
      Asus laptop G614JZ-N3012W Rog Strix with i7
      Mainboard G634J-PMV-VGT
      6050A3441302-MB-A01
      2023-02-10
      Power button works okay....power light goes on
      Red "bottom" leds go on
      Charging led works
      Fans do not spin, capslock key does nothing, screen stays black
      I would like to program the bios again, to rule out a corrupted bios.
      However I run into a size error
      The bios chip is a Winbond 25R256JVEN
      Used my Xgecu T-48 to read the bioschip (using select chip as type XM25QH256B @WSON8, read somewhere...
      02-24-2025, 04:46 AM
