Dead 820-01598 - voltages present but no boot
    Hi guys,
    820-01598 missing PPVCCEDRAM_S0_CPU after LD.
    The board is totally clean and I get 1.8V at ALL_SYS_PWRGD. The CPU heats up and I can see PPVCC_CPU_PH1 at 0.7V, also PPVCCGT_CPU_PH1 is at 0.77V.
    Magsafe without batt connected at 20V/0.460A. Is the CPU dead or am I missing something?
    thanks in advance.
    Re: Dead 820-01598 - voltages present but no boot
    Hey! I am having a similar issue.
    CPU heats only heats up a little.
    1.8v at ALL_SYS_PWRGD.
    Not getting anything at PPVCC_CPU_PH1 or PPVCCGT_CPU_PH1.
    Did you find a solution or is it still on the shelf?
    Cheers!
      I have the exact same issue. All large coils have correct voltage except L7702 (PPVCCEDRAM_S0_REG_R). There is no short on that rail. 1.8v on all_sys_pwrgd. I replaced Q7702 and U7710 with no change.
        What's PPVCCGT_CPU_PH1? I have 0 volts (without short) but it's working (but warm i think).
          https://logi.wiki/index.php/User:Pie..._I_solve_it.3F
