RX 5600 XT, all voltages present but doesn't post
  • LozinMust
    • Apr 2023
    • 24
    • Portugal
    Hello guys.
    I have an RX 5600 XT that was missing vddci, all other voltages were present. The output of the LDO regulator was low (~0.4V) and it was getting hot. I didn't have the same exact IC so I replaced the faulty uP1230 by a GS7162. After this, the voltage on the vddci coil was 1.1V, still the card won't post. Does anyone have any suggestions on what could be at fault? This is my first attempt at fixing AMD cards, so I might be overlooking something.
    I leave the photos of the PCB with the voltages and resistances here: https://imgur.com/a/yrD7GWK
  • LozinMust
    • Apr 2023
    • 24
    • Portugal
    After digging in further, I found out that the reference clock lines are reading a short to ground. I guess I already know the answer, but is there anything that can be done in this case or is it a dead core?
      AMD Radeon RX 5600 XT (5600XT) Schematic & Board View
      The Radeon RX 5600 XT is a performance-segment graphics card by AMD, launched on January 21st, 2020. Built on the 7 nm process, and based on the Navi 10 graphics processor, in its Navi 10 XLE variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX 5600 XT. The Navi 10 graphics processor is an average sized chip with a die area of 251 mm² and 10,300 million transistors. Unlike the fully unlocked Radeon RX 5700 XT, which uses the same GPU but has all 2560 shaders enabled, AMD has disabled...
      10-01-2024, 10:42 AM
    • Kambi13
      HP 15S-fq2006np all voltages present but wont boot up
      by Kambi13
      Hi there, I have an hp 15S-fq2006np that had some liquid damage. After cleaning and replaced some resistors and capacitors, the laptop returned to life.
      Worked fine. Fresh Thermal paste, ran some stress tests. Prime95 ran for 6 hours straight. Everything seemed ok.
      After a couple of hours costumer was playing a game and suddendly the screen went off. Now pressing power button, the power light comes on, all voltages are present but no fan spin, and nothing on screen
      CPU doesn't get warm. Changed ram sticks also, but still the same.
      Could it be a messed bios? He said...
      05-22-2023, 12:27 PM
    • javieromex
      Dell G15 5511 LA-K452P won't turn on
      by javieromex
      Hello, any help will be apprecited!
      • Model: Dell G15 5511
      • MB: LA-K452P
      • Issue: Won't turn on at all, no leds, no keyboard light, no fan spin, nothing happens when pressing power button. NOTHING.
      • Customer reported it was turned off and left plugged in during the night and thats it...
      • No signs of liquid damage or burned components.
      Link to Schematics -> https://www.badcaps.net/forum/troubl...la-k452p-gdp50
      I have checked so far:
      04-17-2025, 12:44 PM
    • reessi
      Macbook Pro 13" - A1989 - 820-00850-A - No Power Issue
      by reessi
      This Macbook does not turn on:
      The power button is ripped, I received it like this and the machine was working fine with a ripped power button as boots when plugged in.
      Current state:
      When plugged in the USB meter goes to 20v /~0.5 gradually increasing to 0.7a charging for 10s then resets charging but remains at 20v, current draw drops to around ~40/50mah then restarts a second later looping.. all 4 ports are the same.
      The touchpad responds (vibrating when pressed) but also is cycling on and then off.
      PP3V_G3S...
      08-19-2025, 09:17 AM
    • rex98
      JS47A/JS57A/JS77A NM-E531 onboard ram disable
      by rex98
      hi i have this laptop IdeaPad 3 15ABA7 this is the boardview https://www.badcaps.net/forum/troubl...90#post3740490
      nm-e531 i tried all kinds of bios editing and it doesn't work. it doesn't have schematic but it has boardview with board ID details in it.
      maybe you could help me how to shift these resistors to disable its onboard ram.
      this is is the presents and not presents...
      10-07-2025, 03:39 AM
