A1534 No power
  • mon2
    • Dec 2019
    • 13971
    A1534 No power
    Hi. Troubleshooting a macbook A1534 that will not power on. Computer appears to have some liquid (thin line) around the perimeter of the logic board and suspecting it is from the topside keyboard / trackpad area. No wet tag color sensors were triggered. Will review to clean it with an ultrasonic cleaner.
    So far, applied an external Apple type C power adapter which emits 14.5v (approx.) after USB negotiations.
    The current draw on the unit itself is oscillating between 30 mA and 0.6A.
    The CPU shield area is warm to the touch. Some of the tantalum caps are @ 52 C after a few minutes of on time using an IR thermometer gun. The rails related to these caps are operating fine @ 8.6 volts (C1031 & C1032).
    PP1V1_S0SW_SSD = 0 volts
    PPBUS_G3H @ 8.6 volts which matches the value on sheet 60 of 75 PDF.
    PPVIN_G3H_P3V3G3H @ 14.5 volts (same as input supplied by external power adapter) - but should be 8.6 volts (according to sheet 60).
    Confused as to the start / end of this PPVIN_G3H_P3V3G3H rail.
    From which feed does PPVIN_G3H_P3V3G3H get the 8.6 volts?
    If PPVIN_G3H_P3V3G3H = 14.5 rather than 8.6 volts, does this imply that U7100 (ISL95530HIZ) is damaged? From my understanding, U7100 is to use the PPVIN_G3H_P3V3G3H as a Vcc so is an input to this switcher?
    Please confirm. U7100 is quite expensive and may just conclude this motherboard to be not worth repairing.
    Welcome any suggestions on this repair.
    reference - downloaded the schematics & boardview brd file from this forum:
    macbook-pro-a1534-82000045a-j92-schematics
    Thanks!
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: A1534 No power
    Don't trust the voltage indications on the schematics, lots of them are wrong. If you get PP3V3_G3H, there's no reason to suspect having an issue on PPVIN_G3H_P3V3G3H.
    Additionally, if PPBUS_G3H is good (it is) and SMC_RESET_L is present, there's no reason to suspect U7100 at this point.
    As always, start by going down the list of power rails.
    This will probably end up having a dead CPU anyway.
    • mon2
      • Dec 2019
      • 13971
      Re: A1534 No power
      Thank you.
      Will continue to check the rest of the voltages today and post the details.
      At which stage can we confirm the CPU is dead?
      Would the USB type c contract negotiations still function without the CPU? Or the texas instruments type c controllers are autonomous?
      Thought that the CPU is the i2c bus master and then configures the type c slaves. Meaning the cpu is still alive.
      We are in talks but cannot justify the expense of a bga rework station yet from Seamark that could potentially remove and replace the cpu. Not an easy chore with just got air tools considering the high density of small parts near and underside of the cpu.
      Thanks so much for your advice!!
      • Der Schwede
        • Sep 2022
        • 21
        • Sweden
        I have same board and similar problem. Just that the rails has power just on PP5V_S4 the voltage is fluktuating.
        PPBUS_G3H Has 8,58v
        PP3V3_G3H Has 3,29v
        PPVRTC_G3H Has 3,,28v
        PP5V_G3H_LDO Has 4,98v
        P5VS4_PHASE 200 kohm 0v
        PP5V_S0 20 mohm 0,1v
        SMC_RESET_L Is not present
        PP1V1_S0SW_SSD 1,113v
        TP(1)PPIN_G3H_P3V3G3H 14,75v
        From where does PP5V_S4 Get voltage from
        What could make PP5V_S4 Fluktuating?
        Thanks in advance.​
        • mon2
          • Dec 2019
          • 13971
          What is the 820-**** number of your logic board? Is it 820-00045 or 820-00244 ?
          See attached. This rail is enabled by the signal P5V_S4_EN. Check its voltage to ground to see if it is cycling or not. Note that PP5V_S4 may be fluctuating if it believes there is an excessive load on this rail. Your resistance to ground is OK and is not a short BUT the current sense circuit could be providing for the incorrect current or FB measurements. For this reason, remove all power -> meter in the lowest resistance scale -> measure the resistance of the current sense path or FB voltage leg. One meter lead @ L7510, pin # 1 and other meter lead @ R7510, pin # 2 - to confirm that the FB resistor @ R7510 is of the correct value and is not defective.
          P5V_S4_EN will be difficult to probe since this signal STARTS under a BGA and ends under a BGA. Review the resistance of R7510 first.
          Update - sorry - meant R7510 = should be 10 ohms and is the FB resistor.
          Click image for larger version  Name:	A1534_review.png Views:	0 Size:	476.4 KB ID:	3168487
          • Der Schwede
            • Sep 2022
            • 21
            • Sweden
            Hello Mon2 The number is 820-00045
            • mon2
              • Dec 2019
              • 13971
              Ok - we are referencing the same schematic. Personally this is one of the boards I hate as the parts are incredibly small. Ironically, we are shifting to build products using 0201 with our machinery but it is different when you have the joy to service a finished product with such tiny parts. Hope your eyes are better than mine or at least have a good microscope.
              • Der Schwede
                • Sep 2022
                • 21
                • Sweden
                Yes, microskope i just got one crapy electronic which connects to latop. But i dont use it now.. :/
                L7510 pin 1 to R7510 in2 10ohms
                PP5V_S4_EN 0.2mv
                • mon2
                  • Dec 2019
                  • 13971
                  Great. Carefully check if this enable pin (P5V_S4_EN) with the power adapter connected is pulsing or not. Measure the voltage to ground of the same test point that you have found.
                  • Der Schwede
                    • Sep 2022
                    • 21
                    • Sweden
                    No, not fluktuating but only 0,2mv
                    Is that mean that i have a problem in u7400? I Have an sparearts board due i bought 2 same A1534 with about same issue. But i dont know if the u7400 chip is good from the another board.. And i dont have bga balling equippment, so i hope its not an issue with the u7400 chip.
                    • mon2
                      • Dec 2019
                      • 13971
                      Not at my desk but this is an active high enable pin. If a logic ‘1’ then the mentioned missing power rail will enable. On this note, the missing power rail should be 0 volts or very close to it and not turning on / off. Since the enable is a logic ‘0’, this local power rail should be off.
                      wait on other comments but the fault may be a corrupt bios. Bios reflashing may be required but do check if the bios has a voltage that is stable to boot the board. Would you have flash programming tools? You must back up the current flash first. Check its power rails and also the Spi lines for a voltage.
                      • Der Schwede
                        • Sep 2022
                        • 21
                        • Sweden
                        Yes, I got progrmming tools. And board was booting untill Apple logo ant then went off.
                        SPI_MLBROM_CS_L 0V
                        SPI_MLB_IO<3> 2mv
                        SPI_MLB_MISO unstable 4,6-6mv
                        SPI_MLB_CLK 0,2mv
                        SPI_MLB_IO<2> 0,7mv
                        SPI_MLB_MOSI 1,6mv
                        • Der Schwede
                          • Sep 2022
                          • 21
                          • Sweden
                          PP3v3_S5 Have 3.3v
                          I have been looking around how to connect the bios chip. The chip is very small and they use a connector to the board and with the connector they read/programm the bios chip.
                          I dont have this connector, can it be soldered of the board and read it or do I need to solder kables to the board?
                          But i dont think my programmers support this efi/bios chip from the A1534 board.. I got the CH341A with 1,8v modd and an EZP2023+. The EZP2023+ suport 24/25/26/93/95 series chips and i dont know which type chip the EFI/Bios chip is from the A1534 board.
                          EDIT.....
                          I read on the net that its possible to read but there is an write protection on the chip. And i read It could get rid of the protecton with some efipassword eliminator! Im little stuck right now.
                          If i somehow manage to read the chip i will not be able to write on it anyhow.
                          EDIT 2....
                          I found a connector which fits on the CH341A programmer and others also. I need to buy one of those. SPI Rom EFI Ribbon Cable Hirose 12 Connector Service A1534
                          • MisterAIL
                            PS5 digital / No Power / No Beep / Good power supply
                            by MisterAIL
                            Brought a non functionnal PS5. Apparently only a bad PSU...
                            No beep, nothing.
                            After some tests i found this :
                            - PSU is fine (12 volts stable)
                            - 12 volts line is shorted
                            - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
                            - By the way, nothing change. No signal, no power, no beep.
                            Mesuring all rails with my workbench psu (12 volts input)
                            - 0.00 amp drawing
                            - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
                            03-12-2024, 03:24 PM
                          • BTubbs200
                            Dead Dell Latitude 5420 not receiving 20 volts from USB-C charger
                            by BTubbs200
                            Dell Latitude 5420 P137G
                            Board: LA-K491P REV A01
                            I have received this laptop which was described as "does not power on or accept charge." Battery shows no sign of charging when charger is plugged in, nor does the board show any signs of life when battery is unplugged and charger is plugged in. No light from the LED at all or any other indications of activity.
                            Board seems to have no shorts, all power rails are fine and show high resistance.
                            When charger is plugged in, voltage is present in 3.3V rail but absent in others....
                            01-24-2025, 08:15 PM
                            MPJA 10 AMP @ 0 to 30 Volts Switching Power Supply Cap Fault
                            by sam_sam_sam
                            I have this 10 amp 0 to 30 volt switching power supply that decided to have a 630 milliamperes draw on it at 0 volts
                            I open it up to find non brands name capacitors in it
                            I am not sure how this switching power supply is set up
                            Could someone please explain how this power supply works
                            Here is the capacitor ESR results
                            (1) 47uf@50 volts 0.46
                            (2) 47uf@50 volts 0.45
                            New 47uf@50 volts 0.35
                            (1) 100uf@25 volts 0.34
                            (2) 100uf@25 volts 0.35
                            New 120uf@50 volts 0.08
                            (1) 220@25 volts 0.13...
                            10-21-2018, 10:02 AM
                          • stefanbs
                            Fit 820-00244-А board in Apple Macbook A1534 2017 820-00687-А
                            by stefanbs
                            The laptop is Apple Macbook A1534 2017 with board 820-00687-А. The USB-C tester shows no voltage, there is 820-00244-А board available. I looked at both schematics, all connector signals seem to be the same. Did someone try to fit 820-00244-А board in A1534 2017?
                            05-11-2025, 01:08 AM
                            I am looking for a transformer secondary of 60 volts @ 30 amp
                            by sam_sam_sam
                            The primary voltage is 480 single phase the second voltage needed is 60 volts
                            Now it could be 30 volts 0 volts 30 volts preferred
                            Or it could be 60 volts 0 volts 60 volts and just use one side of
                            Output amp need to be at least 30
                            Dose anyone know where I can find one
                            This is what is the device I am working on
                            The problem with this one is that it is over heating and smelling like it is over heating
                            When it has a load on it...
                            07-01-2020, 08:14 PM
