Macbook Pro PLT_RESET_L issue
  • Francisco.s
    • 686
    • Spain
    Hi! have an 820-3536-A, that PLT_RESET_L is not present. (0.0v)
    All voltages for cpu are present, but cpu temperature is low. (about 35º c)
    Fan is spinning and it rotates faster when left power-on for more than 60, 80 seconds, but cpu temperature keeps low.
    Power consumption is also very low, no more than 350 mA.
    As PLT_RESET_L is not present, there's no chime and no usb activity.
    Voltages for cpu present and ok:
    PPVCC_S0_CPU
    PP1V05_S0
    PP3V3_S0
    PP3V3_SUS
    PP3V3_S5
    PP1V35_S3_CPUDDR
    What signal (other than PLT_RESET_L) can make this mobo not work?
    It is cpu damaged?
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: Macbook Pro PLT_RESET_L issue
    https://logi.wiki/index.php/Bootup_S..._and_Broadwell
    • Francisco.s
      • 686
      • Spain
      Thanks piernov for this good piece of information.
      I will estudie it an post new voltages and signals readings.
      Best regards.
      • Francisco.s
        • 686
        • Spain
        I Have found the circuit that cause the problem.
        Thanks to the diagrams in the excelente link, I could find that some signals feeds by the PP1V05_S0 rail, had no the correct level.
        CPU_VIDSCLK signal reading was only 0.6 volts, and the pull-up resistance R7279 had 0.6 volts in both terminals, that confused me because one of R7279 terminals is connected to PP1V05_S0.
        PP1V05_S0 was present in many points of the board, like in L7630, R7640 and many more, but in C1801 and some other components near it, voltage readings were almost half the voltage from PP1V05_S0.
        Seems that resistance of PP1V05_S0 rail is not the well designed, because C1801 was in short-circuit, (lets say very low resistance) but not enough to activate the short-circuit protection of U7600.
        Once C1801 capacitor was removed, the problem was solved and now there is chime and boots osx correctly.
        Many thanks for your help.
        • rounin
          MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
          by rounin
          🛠 Original Issue
          ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
          04-19-2025, 01:18 AM
        • pcbmaniac
          MacBook A1278 (3115) No PPBUS_G3H Issue
          by pcbmaniac
          Subject: Help Needed: MacBook A1278 (3115) No PPBUS_G3H Issue
          I'm working on a MacBook A1278 with the 3115 logic board and facing an issue with no PPBUS_G3H voltage. Here's what I've checked so far:
          1. U7000 Measurements:
            • Pin 3 has 0V, even though R7012 shows 16.5V from PPDCIN_S5_CHGR.
          2. Resistors:
            • I measured R7010 and R7011 with one leg disconnected, and both tested OK.
          Based on these findings, I believe U7000 needs to be replaced. However, I have a related question:
          • If I also decide to replace the SMC, do I need to order it pre-programmed,
          12-02-2024, 04:12 PM
        • sofles
          Macbook a1707 2017 model 820-00928 GPU issue
          by sofles
          Hello there
          I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
          I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
          11-21-2024, 05:25 AM
        • Stephen
          A2141 MacBook Pro 16" lid sensor issue.
          by Stephen
          Just like the title states. I have been confused at this point. Computer won't turn on when lid angle sensor is plugged in, when unplugged it turns on immediately, however I have tried 4 different lid angle sensors all OEM and calibrated without issue. I even pulled one from a donor computer and still nothing. I know the M1 Pro sensors are married to the board however I do know the 2019 intel are not as long as they came from a donor LCD etc. What I do not get is why is the lid angle sensor forcing the computer to not turn on, another issue I see when the lid angle sensor is disconnected...
          11-01-2024, 03:45 PM
        • Gueric
          MacBook Pro 2019 820-01700 Speaker amp issue.
          by Gueric
          I have this MacBook Pro on my bench that I have already fixed, hard short on a SSD rail, but it also has another issue. the right speaker sound is either earrape, muffled or absent. Left one works perfect. I have tried replacing it, nothing changed so I'm pretty sure the issue is either motherboard related or maybe software but I doubt that.
          I don't how to troubleshoot speakers. Any help would be very much appreciated.
          A refurbisher and a repair shop have already been inside the laptop but I'm pretty sure none of them tried to do any soldering on the board.
          05-19-2025, 03:08 AM
