Macbook 2008 A1728 820-2327 No greenlight No power
  • platinumsteel
    • May 2019
    • 234
    • Trinidad&Tobago
    Hi again guys I have a tricky one.Macbook 2008 No greenlight when i got it.I am using bench power supply at 16.5V to power it up. It draws 0.02 amps .First measurement I took was PPBUS_G3H and sometimes i get 12.26V and sometimes i get 8.25V.Today i got 12.26V and decided to take some measurements on the U7000 ISL and also the 1 wire circuit which is responsible for the green light. I am having a lot of trouble understanding this model 1 Wire circuit. Hoping you guys can point out what doesn't look right and feel free to point me in the right direction. Especially with the 1-Wire circuit. I have a donor board which i can use to replace components.
    These are the measurments I took of the 1-Wire
    U7000 results below
    (Replaced R7010 and R7011 on Pin 3 .Those resistors were bad)
    Pin 1=0v
    Pin 2=16.27v
    Pin 3=3.8v
    Pin 4=3.1v
    Pin 5=1.3v
    Pin 6=0v
    Pin 7 =1v
    Pin 8 =2v
    Pin 9 =0v
    Pin 10 = 3.4v
    Pin 11 = 3.4v
    Pin 12 = 3.4v
    Pin 13 = 0v
    Pin 14 = 3.3v
    Pin 15=0v
    Pin 16 = 12.23v
    Pin 17 = 12.23v
    Pin 18 = 12.26v
    Pin 19= 5v
    Pin 20= 5v
    Pin 21= 0.642V
    Pin22=0v
    Pin23= 12.26V
    Pin24 =13v
    Pin25 =16.56v
    Pin26 =0v
    Pin 27 =16v
    Pin 28 =16v
  • piernov
    • Jan 2016
    • 4436
    • France
    Re: Macbook 2008 A1728 820-2327 No greenlight No power
    Voltage on PP3V3_S5_SMC_AVCC, SMC_RESET_L, ADAPTER_SENSE, SYS_ONEWIRE?
    • platinumsteel
      • May 2019
      • 234
      • Trinidad&Tobago
      PP3V3_S5 = 0v
      (SMC_AVCC) <<not shown GND_SMC_AVCC =0v PP3V3_S5_SMC_AVCC=3.41V
      SMC_RESET_L =3.42v
      ADAPTER_SENSE =2.864V
      SYS_ONEWIRE = 2.863V
      I now noticed a good bit of corrosion around the SMC area..Not sure if it means anything.
      • piernov
        • Jan 2016
        • 4436
        • France
        Of course it does, this is liquid damage, the SMC isn't working right now… Clean the dirt and corrosion, fix traces if need be, reflow the SMC and look for other corroded area.
        • platinumsteel
          • May 2019
          • 234
          • Trinidad&Tobago
          Yo piernov you are great. Thanks a lot for leading me in the right direction. When you told me to check the voltage on SMC_AVCC i noticed the corrosion in that area as you see in the picture. So i cleaned it up..and checked R5070 resistance.R5070 belongs to SMC_ONOFF_L As you can see in picture below.I replaced it with one from donor board and plugged in and immediately got a green light.I was so excited i didn't even bother too see if i get fan spin..and needed to report back here.Cause had you not told me to check those areas i would of still be groping in the wrong places.lol Thanks a lot man.Only issue i have now is PPBUS_G3H is still saying 9V so the fight continues. But i'm so grateful to even get a greenlight.lol Will keep working on it.PP3V3_S5 is now 3.322V.
          • platinumsteel
            • May 2019
            • 234
            • Trinidad&Tobago
            Okay my friends. Machine is finally up and running now...Didn't go tru with the reflow of SMC.Today it gave me PPBUS_G3H 12.57V instead of 9V and i decided to try and power it up..Machine powered on and seems to be working fine. So thanks again Pier for the help on this one.It's really good not to give up on any machine that you think may not be able to be resurrected. lol
            • envym
              by envym
              Hi everyone!
              06-27-2025, 08:54 AM
            • tobeend
              Bypass mdm macbook m2 ventura
              by tobeend
              1. RESET MACOS WITH IPSW
              a. Power off MacBook, press and hold the power button to enter Recovery
              b. Open Disk Utility, remove Macintosh HD
              c. Reboot, connect to the network to Activate Mac.
              d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
              d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
              e. Release the other keys, but keep holding the Power key for another 10 seconds
              f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
              05-26-2023, 07:18 AM
            • SarcasticOP
              General question about MacBook power rails for repair.
              by SarcasticOP
              I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
              • PPBUS_G3H (12.6V-12.8V)
                • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
              • PP3V42_G3H (3.42V)
                • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
              • PPVRTC_G3H (3.3V)
                • This
              12-12-2024, 05:50 PM
            • obelix24
              A2941 Macbook air 15” - 5V 0a
              by obelix24
              I’m working on one macbook air 15” m2 that was water damaged.
              keyboard, lcd, microphone connectors were damaged so i’ve replaced all of them and without screen connected macbook worked fine. Keyboard &trackpad and also lid sensor was working fine.
              i’ve put macbook in shelf and order new screen so i can fully repair it.
              Now i got the screen and macbook stays at 5v 0a.
              i’ve tried if it’s not in DFU with another macbook but it’s not detected at all.
              i don’t have schematics so i don’t know where to start can someone help me?...
              03-27-2025, 01:19 PM
            • piernov
              NVidia bumpgate
              by piernov
              Just archiving everything related to bumpgate since most stuff has disappeared from Google. Maybe people will finally take the time to read some of it and stop shouting "reflow gpu" at every occasion but rather try to understand what the real issue is…
              Interesting parts about the failure analysis are "Why Nvidia's chips are defective" and "Why Nvidia's duff chips are due to shoddy engineering"
              May complete this post at a later date with more details.
              Basically issue is a combination of thermal dissipation of the chip with hotspot,...
              03-27-2021, 10:34 AM
