A2289 Board 820-01987-A Dead?
  • momoomar
    • Jan 2021
    • denmark
    Re: A2289 Board 820-01987-A Dead?
    Hey dbteckos. Sorry for the late answer since then I have bought another 820-01987 board and here with no signs of corrosion or other damage but it takes 200mA and 20V dont know why yet.. the old board are stock on DFU mode now and it only takes 80-96mA 20V
    I measured the testpoint (beside J8401) for both board diode mode = Old board : 1.788 new board : 1.700
    Here are some other measurements for old and new board
    Ny board
    L7270 = 14.30 ohm
    L7210 = 4.30 ohm
    L7220 = 4.30 ohm
    L7410 = 3.93 ohm
    L7420 = 3.93 ohm
    L7702 = 43.3 ohm
    L7030 = 2.68 Mohm
    F7000 = 50 kohm both sides
    L8102 = 27.33 ohm
    L8100 = 0.46 kohm
    L7690 = 1.6 Mohm
    L7670 = 5.9 kohm
    L8410 = 1.10 Mohm
    Old board
    L7270 = 13.7 ohm
    L7210 = 2.50 ohm
    L7220 = 2.50 ohm
    L7410 = 3.66 ohm
    L7420 = 3.51 ohm
    L7702 = 24.3 ohm
    L7030 = 2.26 Mohm
    F7000 = 1.6 Mohm both sides
    L8102 = 56.2 ohm
    L8100 = 0.33 kohm
    L7690 = 0.44 Mohm
    L7670 = 0.40 Mohm
    L8410 = 1.10 Mohm
    • Stephen
      Meow Meow MEOW!
      • Apr 2020
      • 667
      Originally posted by dbteckos
      I have an ultrasonic cleaner, I will try. What temperature and time settings do you recommend ?
      Sorry just noticed this!
      Temp for Ultrasonic cleaner for Logic board should be
      66C
      and timer needs to be 4 mins per cleaning cycle. You need to clean the board two times. One side for 4 mins, then flip it and clean for another 4 mins. Total of 8 mins of cleaning time.
      After that you need to throw the board into a tub of 99% Isoproply Alchohol.
      Make sure your Ultrasonic cleaner is using Distilled water and on top of that make sure you are using EC Cleaner from Branson. I would hope you are using a Crest Ultrasonic cleaner as well. Hope this helps!
      sigpic
      MEOWING IN THE IMPOSSIBLE UNIVERSE!
      • elektrosha
        • Mar 2012
        Had pretty similar (if not the same) issue as Kudeta. After doing throughout visual inspection for the 3rd time I discovered shorted capacitor C8103 and shot 0Ohm resistor R8154 next to it. After replacing both - logicboard is back to life. Hope it will help someone.
        • Deluccia
          • Aug 2017
          • 46
          • uk
          I have a very similar issue myself.
          Have a A2289 board that "boots" without battery at 20v 0.5A with trackpad, warm CPU and fan spin.
          No display nor Touch Bar. Had liquid damage around U7420 and Q7065 mostly.
          I wish there was a definitive check list of rails to test in order to determine what can irrefutably diagnose a major component failure.
          I find I am good at locating offending components but I struggle to know if I'm always looking in the right places in terms of what is essential to be live and what isn't.
          I will update my findings here this week
          • jasonr2000
            MacBook Pro A2289 No Power
            by jasonr2000
            hi guys I have a 2020 MacBook Pro A2289 it has the i5 CPU and is now acting as if its dead,
            when I plug in the charger cable with a volt meter thing connected as well its drawing 20.3v and 1.11A
            if I press the power button nothing happens.
            but if I hold the power button for 7 seconds or more the voltmeter drops all the amps down to 0.00A but voltage stays the same.
            any ideas where I can check ??
            from what I can gather it must be charging the battery at 1.11A as nothing happens when the power button is pressed. I can successfully...
            03-08-2025, 10:22 AM
          • Fisher8865
            MacBook Pro A1990 stuck at 5v .592 amps
            by Fisher8865
            Hi guys
            I have a MacBook Pro A1990 that takes 4.9 Volts and .592 to .615 amps on one port. The other port on the left side power cycles with about the same amount of volts an amps but quickly power cycles. The same thing happens on the other side but opposite. So on the left side the bottom port stays on and on the right side it's the top one. I think it is a CD3215 chip but I am not sure how to test it or where to get one. I have checked for voltage at ppbus_g3h and it has 12.6 V which is also on fuses f7000 and f7001 I checked pp1v2_s3 and it has 1.2 V then...
            05-30-2024, 07:36 PM
          • Stephen
            MacBook Air 13" A2179 2020. 5Volts .250 amps issue
            by Stephen
            Customer came in with shorted USB C chips, replaced and the chips are now responding beautifully HOWEVER, I am only getting 5Volts .25 amps (sometimes .243 amps) I see that the T2 chip is turning on, but I am not seeing any voltage at the SSD rails for example,
            PP5VG3S_EN is not present which would somewhat indicate a PMIC U7800 issue, but I checked the voltage on the PMIC and that is present and not shorted. I tested for PP5V_G3S and those rails are not present.
            ISL9240HI is present, I am also getting 12.30 volts at PPBUS_G3H so no shorts there. Both CD3217 chips were successfully...
            02-18-2025, 05:54 PM
          • alexruehr
            A2289 - 820-01987 - Dead?
            by alexruehr
            Hey guys, just troubleshooting a MacBook Pro A2289 with the 820-01987 logic board.
            No fan spin, no booting, device not getting detected by the Apple Configurator.
            Did a few basic things, the board gets to 20V USB supply according to my USB tester, F7000 fuse seem to be ok and not blown.
            Board draws about 0.5A for about 10 seconds, after that it goes down to 0V. Found an n channel FET (Q4830) in the backlight supply(?) that could to be blown (pictures below), not quite sure about that, but t assume that should not be relevant, because I was testing the board...
            08-23-2024, 06:26 PM
          • baglaivlad
            MacBook Pro A2289 (820-01987-A) No boot/image, but boots to DFU
            by baglaivlad
            Hi everyone. Just a reminder I am not a professional repair technician, fixing Apple electronics is my hobby.
            Recently got my hands on MacBook Pro A2289 with interesting behavior. Pristine condition, no water damage, no visual issues whatsoever. It has no image, no CapsLock, no life except the fan is spinning. But it is able to boot into DFU and recognized by another MacBook. I tried to revive and restore the laptop, but the process ends when the MacBook usually should show an Apple logo with a progress bar. I assume the main power lines and T2 are working. It seems like the Intel...
            01-09-2024, 09:55 PM
