MacBook Pro A2289 No Power
  • jasonr2000
    Advance Tech
    • Nov 2013
    • 222
    • Computers, Cars,
    hi guys I have a 2020 MacBook Pro A2289 it has the i5 CPU and is now acting as if its dead,
    when I plug in the charger cable with a volt meter thing connected as well its drawing 20.3v and 1.11A
    if I press the power button nothing happens.
    but if I hold the power button for 7 seconds or more the voltmeter drops all the amps down to 0.00A but voltage stays the same.
    any ideas where I can check ??
    from what I can gather it must be charging the battery at 1.11A as nothing happens when the power button is pressed. I can successfully reset the SMC with the key combo as again the amp draw goes to 0.00A
    thanks for any help.
    cheers
    jason
    Samsung UE46D6530
    Samsung BD-F7500
    Samsung HT-ES6200
  • mon2
    • 16217
    Measure the voltage to ground of PPBUS_G3H @ fuse F7000 (both sides). What is the voltage? Is it stable?
    Is the current draw of 1.11A immediate upon applying the power or does it climb to this value?
    Since you have 20v, the USB-C power delivery chips are ok and working.
    • jasonr2000
      Advance Tech
      • Nov 2013
      • 222
      • Computers, Cars,
      hi thanks for the reply and ive checked both sides of the fuse F7000 and its 12.6v stable both sides.
      and no the current draw starts of at about 0.32 and goes up slowly to just over 1A
      thanks
      Samsung UE46D6530
      Samsung BD-F7500
      Samsung HT-ES6200
      • mon2
        • 16217
        With 12v6, T2 has booted.
        Attempt a DFU.
        https://logi.wiki/index.php/DFU_Mode_Restore_(Macs)
        • jasonr2000
          Advance Tech
          • Nov 2013
          • 222
          • Computers, Cars,
          Attempt a DFU.
          I just tried a dfu and now its powered on to a flashing folder with a question mark..
          now I didn't think of that at first..
          Samsung UE46D6530
          Samsung BD-F7500
          Samsung HT-ES6200
          • SarcasticOP
            General question about MacBook power rails for repair.
            by SarcasticOP
            I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
            • PPBUS_G3H (12.6V-12.8V)
              • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
            • PP3V42_G3H (3.42V)
              • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
            • PPVRTC_G3H (3.3V)
              • This
            12-12-2024, 05:50 PM
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • megacap
            MacBook Pro Retina 15.4-inch (2018) A1990 820-01041 No charge, no power after letting battery die and not using for a bit
            by megacap
            So I this MacBook Pro Retina 15.4-inch (2018) A1990 laptop that suddenly will not charge or start. It was working fine before. It would charge and was starting up normally from sleep. The only thing abnormal is that it seemed to be getting battery health warnings. Maybe a precursor of what was to come. Let it sit in sleep mode for about a week. Now it seems completely dead. Seems like no power at all. No lights, no fans, no screen, no touchpad clicks. Battery charger, which is apple 87w, doesn't get hot at all when plugged in. Charger will charge an iphone just fine though....
            06-05-2026, 12:38 PM
          • PantherDave
            by PantherDave
            Hi all!
            05-29-2024, 02:01 PM
          • GLISIT
            by GLISIT
            01-16-2025, 02:29 PM
