Hp 450 dead
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Hp 450 dead
    MODEL:HP PAVILLION 450
    PCB:INVENTEC HARVEY 6050A2493101
    PROBLEM: TOTAL DEAD, NO DC JACK LIGHT.
    Here is what i've found out.
    01.Q6010-Source 19V,gate-24V,Drain 19V
    02.charging IC BQ24728 measurements:
    ACN/ACP-19V
    cmsrc-19V
    ACDRV-24V
    ACPRES-2.9V(??)
    ACDET-2.62V
    SDA/SCL-3V
    REGN-6V
    R6024 has 3V Pull up ok on one side but on ther side connected to Charging ic's ACOK pin is 2.9V . The resistor is measured out of circuit 10K.
    ADP_ID is ok at 0.58V measured on D6015. Other end of diode is stable 3V.
    KBC pin 70-0.58V. I've measured PIN 71/72/73/35 and they are all ok as per schematics.
    3V/5V LDO present.
    Offline Consumption is 0.012 Amps at the beginning and then jumps to 0.023A but nothing is warming up though a slight increase in temperature can be filled near TPS 51123 IC. Resistance on 3/5V coil is correct as per working m/b.
    All the fets like Q6011/Q6012/Q6000/Q6001/Q6100/Q6101/Q6150/Q6151 are ok .
    Parts replaced:
    01.BQ24728-NEW
    02.IT8517-NEW
    03.TPS 51123-NEW
    04.Both eprom flashed with known good bios.
    What can be wrong here?? Any ideas??
    Status-all the same-dead with no dc jack light.
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: Hp 450 dead
    is the RTC_RTCRST# section ok ? try with a another DC jack , Q103 R14 voltage is ok ?
      • 21137
      Re: Hp 450 dead
      Did you replace the ITE with the same part number HXA/HXS .Check voltage on R802 pin 1
      • piernov
        • Jan 2016
        • 4437
        • France
        Re: Hp 450 dead
        EN_3V_5V present or missing?
        Check resistance to ground on 3V/5V LDO as well.
        Also check voltage on EC pin 14 and make sure 3.3V makes its way to VSTBY pins.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Re: Hp 450 dead
          RTC section is ok. Q103/R14 voltage is not ok and i've already observed. R14 is 5V on one side and 0V on ac led side. Dc jack i've replaced.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Re: Hp 450 dead
            ITE replacement with same part number for sure. R802 is not populated on mb though on pads i've 3.3v on one side and 0V on the other side(which is connected to R769)
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              Re: Hp 450 dead
              EN_3V_5V present. Resistance on LDO line is ok compared to working mb. EC pin14 is 2.94V. VSTBY pins(L516) have 3.3V.
              • piernov
                • Jan 2016
                • 4437
                • France
                Re: Hp 450 dead
                If EN_3V_5V is high then U6100 should produce VRP5V0A and VRP3V3A.
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  Re: Hp 450 dead
                  In this platform, VRP5VOA & VRP3V3A comes after turning on only. EN_3V_5V is definitely high and stable.
                  • piernov
                    • Jan 2016
                    • 4437
                    • France
                    Re: Hp 450 dead
                    EN_3V_5V is ENC signal for TPS51123.
                    According to datasheet, ENC: "Channel 1 and Channel 2 enable input. Pull up to the voltage ranging 3.3-V to 5-V to turn on both switcher channels. Short to ground to shutdown them."
                    According to Table 3 of datasheet, all the voltage regulator outputs are turned on when EN0 isn't tied to ground and ENC is high. EN0 is ok since you at least get LDO outputs (if EN0 was tied to ground it would disable LDO). ENC is high. Therefore the buck output should be present.
                    Additionally, according to schematics, AC_LED# power comes from P5V0A through R14
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      Re: Hp 450 dead
                      I agree with you theoritically as with the conditions mentioned, there should be output on coils. But exactly that's not the case on this platform. I've a working mb of same platform and there is no voltage on 3v/5v coil though ac led on dc jack glows. The voltage on coils appear only after turn on. Schematic doesnt mention it as suspend voltage also adding to more confusion. I've checked voltage/resistance on each and evry pin of TPS51123/BQ728 and there is no difference on any of the pins except BQ728 ACOK pin which is at 2.9V and the other side of pullup resistor is stable 3.3V.
                      If there is no more ideas , then i think i need to give up on this case as i'm still not able to understand the root cause of the problem. Customer is not in hurry though.
                      • piernov
                        • Jan 2016
                        • 4437
                        • France
                        Re: Hp 450 dead
                        Maybe the schematic is wrong and something is pulling TRIP1/TRIP2 of the TPS51123 to ground. And maybe the LED is powered by the 5V LDO instead.
                        So ADP_PRES is 3.3 on the other board? And it was 2.9V as well before replacing EC and charger IC on this board?
                          • 21137
                          Re: Hp 450 dead
                          Can you check Pin 18 ENC EN_3V_5V on both boards ,and R6997,R6998 if present. On page 4 of the tps datasheet theres a chart with the VO and VIN standby current in mA and μA ,what does pin 18 have on both boards before and after pressing the power button.
                          • double_DD
                            How can I be sure that my EC chip is dead?
                            by double_DD
                            As the title suggests, how can I be sure that my EC chip is really dead?
                            I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                            Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                            03-12-2025, 07:47 AM
                          • disorder
                            ps5 edm-033 dead after hdmi/usb ports destroyed
                            by disorder
                            hello guys,
                            i need help to repair a edm-033 ps2
                            history : as always hdmi port and usb ports destroyed after unplugged
                            after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                            so i changed it
                            now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                            but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                            i don't see any projection of liquid metal on pcb.
                            01-14-2025, 12:48 PM
                          • zunasthegreat
                            Chieftec GPS-450-AA with dead 20N60C3
                            by zunasthegreat
                            Hello everyone hope all doing well!
                            I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                            09-01-2024, 07:12 PM
                          • Beton
                            Finding a dead short component
                            by Beton
                            Hi guys!
                            I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                            So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                            I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                            I have a bench PSU and if I try to inject voltage the voltage...
                            12-10-2021, 01:05 PM
                          • Rav_tangle
                            MacBook Pro 2011 turns on with keyboard light , screen dead
                            by Rav_tangle
                            Hi all , thanks for having me & I think this has been asked before but my case seems a bit odd.
                            I have a MacBook Pro , board 820-2915a and it turns on , chimes etc etc , keyboard lights up, fans spins , can turn caps lock on/off but screen is dead.
                            Iv tried the resets , shine torch through back logo , nothing , it seems the screen has no power. If I plug charger , it charges but if I disconnect battery it displays green light but won't turn on. Iv tried screen on with another board & it works & seems I'm not getting any voltage at pin 2 , next to ground pin .
                            is this...
                            05-31-2024, 04:09 PM
