Dell E5550 Charget goes off when plugged (shortcircuit?)
  • Andreasbest
    • Aug 2014
    • 1153
    • Hellas ( Greece )
    Hello!
    Today i received a Dell E5550 with the symptom i descrive in top.
    When i plug the charger to laptop, the led goes off and i must replug it in 220V mains to get it back on, then it goes off again when plugged on laptop etc.
    Seems like a shortcircuit but i need some help
    Thank you in advance!
    (pictures of motherboard and schematic attached)
  • Vesko356
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    Re: Dell E5550 Charget goes off when plugged (shortcircuit?)
    First check five pointed in red rectangle capacitors for short. Also PQ4, but most probably some of those five caps is in short.
    Become a Badcaps supporter
    Thanks to all supporters.​
    • Andreasbest
      • Aug 2014
      • 1153
      • Hellas ( Greece )
      Thank you for reply, checking now
      • Andreasbest
        • Aug 2014
        • 1153
        • Hellas ( Greece )
        Hello Vesko and thank you for your reply again.
        The capacitor in photo was indeed short, do you know the value of it to replace it?
        Thank you!
        • Vesko356
          VIP Moderator
          • Aug 2018
          • 4386
          • Bulgaria 🇧🇬
          Thank you!
          Don't worry will be fine like that, there is no need to replace it, but for the peace of mind you can replace the cap with the ceramic 10uF 0805 25V one.
          And check PQ4 - it's a AON7401 P-Channel mosfet, often after a shorted capacitor in 19V power rail, there is a problem with it as well, so just check it too.
          • Andreasbest
            • Aug 2014
            • 1153
            • Hellas ( Greece )
            Yes indeed it's short too.
            Must order some now.
            You think the rest circuit will be ok?
            • Vesko356
              VIP Moderator
              • Aug 2018
              • 4386
              • Bulgaria 🇧🇬
              I have many 7408, can i use these?
              No you can't 7408 is 18A, 7401 is 35A, so you must find 7401.
              Yes, everything will be OK, just replace 7401 and the board is ready to go.
              • dellxps15
                • Feb 2014
                • 1588
                • italy
                remove pr701 and see wich side is shorted.
                • Vesko356
                  VIP Moderator
                  • Aug 2018
                  • 4386
                  • Bulgaria 🇧🇬
                  Short to ground is fixed (was found). Mosfet itself is shorted (drain source gate), removing pr701 doesn't change nothing. Read carefully
                  • dellxps15
                    • Feb 2014
                    • 1588
                    • italy
                    ok so he removed pq4 and none of the 8 pin is shorted annymore.
                    • Andreasbest
                      • Aug 2014
                      • 1153
                      • Hellas ( Greece )
                      Can't find 7401 in reasonable price in EU
                      Does any of you have one? I'll pay with Paypal.
                      • dellxps15
                        • Feb 2014
                        • 1588
                        • italy
                        i see in spain 2.99+1.5 shipment. ofcourse if u buy them from digi or cina ull get more more cheaper, but only if u need more component.
                          • 20731
                          https://www.ebay.com/itm/10pcs-74O1-...p/192683660203
                          Never had any problems with the seller,always good parts,no fakes.
                          • Andreasbest
                            • Aug 2014
                            • 1153
                            • Hellas ( Greece )
                            I know but it will take forever to arrive.
                            I'll buy from EU this time.
                            • Shinju
                              Razor Blade Steath 13" RZ09-01963 plugged in Not Charging (new battery)
                              by Shinju
                              Hey All!
                              Long time forum member here with a problematic laptop issue!
                              I got a RZ09-0196 with a bloated battery (still worked and charged fine) I pulled the old cell pack out and installed a new cell pack in its place.
                              The laptop would not power on with the new battery installed without the power supply being plugged in.
                              When booting into Win10 (all up to date BTW) I saw the battery icon with 49% plugged in not charging.
                              TL;Dr version, old battery worked, charged but was bloated, installed a new non OEM replacement, laptop/windows...
                              10-20-2021, 04:58 PM
                            • zwect
                              Asus Rog GL502VM Rev 2.0 - Power button LED on as soon as plugged in but no video or fans
                              by zwect
                              I have this Asus ROG laptop (the 1060 + 6700HQ variant) which lights up the power button's LED when i plug the charger in but does nothing else. Opening up there are no signs of any burnt or corroded components, i've checked the resistance of both CPU and GPU's cores on the caps underside them, the CPU's VCCCORE's caps read 1.2ohm and the GPU's NVVDD read about 0.5 to 0.6ohm. I then tried to check any voltages while the laptop is plugged in (without any of the removable parts) and the GPU's core voltage instantly goes to 0.8v when plugged then getting slowly warm, the PCH does so too (not so warm...
                              05-31-2024, 06:23 PM
                            • Andreasbest
                              Dell E5550 no power up
                              by Andreasbest
                              Hello!
                              I received a E5550 today with shortcircuit in DC input (charger went off when plugged in)
                              I found shorted cap ( PC714 ) removed it, not replace it and short went off, charger remain lit but still no power on laptop (led power on for only 0.5 sec)
                              Then i noticed another short on cap PC5 but the cap is good, not shorted so i assumed PQ6 is shorted but schematics confused me.
                              They state PQ6A and PQ6B (page 40) but on boardview and board it self i only see PQ6.
                              What am i missing?
                              Thank you!...
                              06-28-2022, 03:09 PM
                            • re1nhold
                              Bios needed, Dell E5550, Tag FSFB262, Zam80 La-911P Rev.1
                              by re1nhold
                              Hello Guys
                              I'm currently fixing two different Dell latitudes,
                              I need a E5550 BIOS - SERVICE TAG is: FSFB262
                              So far I flashed about 6 BIOS from this forum already,
                              none worked,
                              only fan spin ~3s, LCD black, keyboard LED on/off ok,
                              I tried manual extraction with scripts for ages so to speak. VM is untried yet.
                              This laptop is not burnt, it seems to just have a corrupted BIOS.
                              I extra baught ram. This has to work friends.
                              Do you generate it this way in Windows in CMD?:
                              Code:
                              E5550A24.exe /writeromfile C:\bios.fd
                              07-18-2025, 09:18 AM
                            • pluggedDan
                              MacBook Pro A1706 charge stuck at 5v when battery is plugged in
                              by pluggedDan
                              I have an A1706 that was liquid damaged, the logic board turns on and works when the battery connector is not plugged in, but when the battery is plugged in, the computer is stuck on 5v @ 30-40 Mah, and USB-C meter will reboot every 5 sec or so, pressing and holding down the power button will make the USB-C meter to stop boot looping, and if you keep holding it, fan will quickly spin up and turn off.
                              when the battery is unplugged and plug in the charger then plug in the battery it will stay on 20V and 1.6A-2.6A but when you unplug the charger, the computer...
                              10-29-2023, 02:41 PM
