Dell E5550 no power up
  • Andreasbest
    • Aug 2014
    • 1196
    • Hellas ( Greece )
    Hello!
    I received a E5550 today with shortcircuit in DC input (charger went off when plugged in)
    I found shorted cap ( PC714 ) removed it, not replace it and short went off, charger remain lit but still no power on laptop (led power on for only 0.5 sec)
    Then i noticed another short on cap PC5 but the cap is good, not shorted so i assumed PQ6 is shorted but schematics confused me.
    They state PQ6A and PQ6B (page 40) but on boardview and board it self i only see PQ6.
    What am i missing?
    Thank you!
  • mon2
    • 14660
    Re: Dell E5550 no power up
    PQ6A and PQ6B = 2 x mosfets inside a single package (ie. Dual mosfets inside the package).
    • Andreasbest
      • Aug 2014
      • 1196
      • Hellas ( Greece )
      So basically it's the same component?
      Ok thank you!
      • Andreasbest
        • Aug 2014
        • 1196
        • Hellas ( Greece )
        Ok i repaired it, PQ4 was shorted causing short to whole line.
        Thank yoU!
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • im_trying
          Dell Latitude 5310 2 in 1 Laptop does not power on, shorted capacitor replaced but not solved
          by im_trying
          Laptop does not power on but has a fix white light on power button, when connected to power.
          I found, while trying to diagnose, a hot spot in the motherboard and found it to be a shorted capacitor (see photo below) on the 2.5v (2D5V_S3 on schematics). After replacing it with one from a donor board, still, the board does not turn on...
          The usb-c meter reads upon connection 20.1v and 0.00a, with some occasional flashes to 0.03amps. After 10/15 seconds circa, it goes to 5.2v and draws an almost constant 0.07amps. (same behaviour as before)
          To my fingers, nothing seems...
          05-08-2025, 12:01 PM
        • PantherDave
          by PantherDave
          Hi all!
          I'm trying to troubleshoot a Microsoft Surface Pro (5th gen) model 1796 that won't power on. Motherboard model is M1007506-015. My priority is retrieving data, but the SSD is integrated so it looks like if I can't repair it it'll need to go to a data recovery company. I've done a little basic board repair before, but nothing this advanced until now. So please forgive my ignorance in advance. ๐Ÿ˜…
          05-29-2024, 02:01 PM
        • guizmo1967
          Dell Latitude 5501 LA-H181P shorted power rail
          by guizmo1967
          This is my problem:
          Laptop: Dell Latitude 5501
          Motherboard: EDC51 LA-H181P
          I have two power rails shorted to ground, +1.0V_PRIM and +3.3V_ALW_PCH. I removed solder on PJP302, +1.05VALWP (pad1) not shorted but +1.0V_PRIM (pad2) shorted.
          I also cleaned PJP38, pad1 not shorted, pad2 (+3.3V_ALW_PCH) shorted to ground.
          I measure the resistance of all the coils on the motherboard and they all were not shorted to ground except coil PL301 before I removed the solder on PJP302.
          I injected +1.05V - 2A...
          07-25-2023, 06:56 PM
        • Mark01
          Dell Optiplex 7490 AIO - red power led after flash
          by Mark01
          Hi guys,
          This is my first post! ๐Ÿš€
          I have no idea what Iโ€™m doing, but Iโ€™m learning by trial and error.
          Iโ€™m currently working on a Dell Optiplex AIO 7490โ€”one of a bunch of AIOs that mysteriously failed to POST just a few days after the warranty expired. The original issue was that the PC worked fine until it was rebooted, after which it got stuck on a black screen (no backlight), with fans spinning at normal speed and a solid white power LED. Forcing it off by holding the power button would just cause it to switch on automatically and get stuck again on...
          07-04-2025, 12:54 PM
