Dell E5550 (LA-A911P Rev 1.0) - strange behavior
  • vtfe
    • Sep 2017
    • 35
    • france
    I have a Dell Latitude E5550. I don't know the history of the PC. The battery is missing. BTW I am not too sure the laptop will boot at all with mains but without a battery. Can someone confirm this laptop can boot without a battery attached?
    At the moment, here is the behavior:
    If I plug the charger and I have a USB led lamp plugged in, the lamp turns on steady (Happens with only one USB port out of 3). When I press the power button, nothing happens. USB lamp stays on, but nothing happens.
    If I unplug the CMOS 3V battery, the lamp in the USB port will turn on for a split second then off. Just then the power button LED will turn on for a split second. Then off. If I press the power button, the power button light will turn on for two seconds then off.
    Any idea? Short in the motherboard? Bad CMOS battery? Bad BIOS?
  • Mazorca
    • Jan 2017
    • 463
    Re: Dell E5550 (LA-A911P Rev 1.0) - strange behavior
    I have an E5550 and it does indeed turn on without battery, just the AC adapter. I think all laptops do this. Currently have the battery on order, this one has a sort of propietary cable from battery to motherboard. Dell part number NWD9K or 0NWD9K.
    • vtfe
      • Sep 2017
      • 35
      • france
      Thanks, Mazorca!
      • vtfe
        • Sep 2017
        • 35
        • france
        Now does anybody know what could be wrong with the motherboard?
        • vtfe
          • Sep 2017
          • 35
          • france
          Extra info: I have tested the CMOS battery when it is plugged into the motherboard - multimeter indicates 2.7V only.
          • Techtiger
            • Oct 2014
            • 1602
            • france
            dissemble the laptop first clean it remove HHD COMS inspect visually any burn SMD components change the BIOS battery for a new one hold down the power button fro 10 sec with out any power put back BIOS battery and power & check if the fan is spinning CPU getting worm do not assemble the laptop for the moment keep it out with out screen feedback do you know how to read the Schematic ?
            • vtfe
              • Sep 2017
              • 35
              • france
              Merci, Techtiger!
              I have had a close look at the mobo. 2 chips are missing in LI5 and LI6 (see pictures attached).
              According to the Schematics (attached) the parts are DLW21HN900HQ2L_4P.
              They are Chip Common Mode Choke Coils (datasheet is attached).
              I have no idea what these chips are (lol). Instead of replacing them, can I possibly bridge pads, just to see if the motherboard will boot?
              • Techtiger
                • Oct 2014
                • 1602
                • france
                Mr Bordeaux
                No worries those coils have not been included in this MB by the engineer , find out PQ700 it’s a 8pins Mosfet P-channel what is the voltage on pin 8 1 4 with 4 digits on multimeter 19.XX?
                Voltage on PR701 ? PU700 pin 1 2 28 6 5 24 be careful not to short pins when testing page 46 . Find out PL101 Pl102 what are the Voltage on those coils page 41 ?
                • vtfe
                  • Sep 2017
                  • 35
                  • france
                  Hello Techtiger,
                  I have looked for pictures of the motherboard and the coils are present on a factory motherboard (see picture attached). I definitely think they are missing on my motherboard. Having said that, I have no idea if the missing coils are responsible for the motherboard failure.
                  The USB port with the missing coils is the only one that will turn on a lamp led steadily. On the other two USB ports the lamp will only flash for a split second when charger is plugged in.
                  I suspect there is something wrong here and I would still like to bypass those coils if it's safe (jumper wire?).
                  Multimeter readings
                  Mosfet PQ700
                  Pin 1: 19.66V
                  Pin 4: 0V
                  Pin 8: 19.66V
                  PR701: 19.67V
                  PU700: too tiny. I'm not properly equipped (big multimeter probes and bad eyes) and I'd like not to test it right now for fear of shorting something. I will if it is absolutely necessary.
                  PL101: 3.31
                  PL102: 5V
                  Thanks again for your help
                  • Techtiger
                    • Oct 2014
                    • 1602
                    • france
                    Leave the Coils for the moment , PQ700 Gâte 0V pin 4 this is not correct test again if still 0V remove all power put the Multimeter continue to mood test pin 1 8 & 4 what are the reading feed back
                    Find out PU800 what are the voltage pin 1 2 7 is the IC getting worm keep you finger and see
                    • vtfe
                      • Sep 2017
                      • 35
                      • france
                      OK, I have tested PQ700 pin 4 again.
                      With CMOS battery plugged in-> 19.03V (the "original" battery, which is 2.72V)
                      No CMOS battery -> 0V
                      I tried with another CMOS battery (2.96V) plugged in but pin 4 -> 0V (???)
                      Another strange thing is that the power button only reacts when there is no CMOS battery at all or the 2.96V battery is plugged in.
                      • When mains is plugged the button led turns on briefly.
                      • A push on the button will light the led again shortly.
                      • A second push on the button, the led turns on for 2 seconds, then a faint click is heard in the middle of the mobo then the power button led turns off.
                      I checked PU800 but it is not warm. The chip is so tiny, I'd rather not take the risk to short it while probing it. Unless it is absolutely necessary.
                      • Techtiger
                        • Oct 2014
                        • 1602
                        • france
                        [QUOTE=vtfe;993695]OK, I have tested PQ700 pin 4 again.
                        Another strange thing is that the power button only reacts when there is no CMOS battery at all or the 2.96V battery is plugged in.[LIST]
                        it's not clear for me PQ700 pin 4 voltage is 0V when the BIOS batt insert ? & if no BIOS batt you have 19V on pin 4 of PQ700 ?
                        near the BIOS batt there is a DIODE PD3 test the voltage with bios battry & with out bios batt all 3 pins & find out if it's short or not
                        remove all power put the Multimeter continue to mood test pin PQ700 1 8 & 4 what are the reading feed back
                        • vtfe
                          • Sep 2017
                          • 35
                          • france
                          I have 19V on PQ700 pin 4 when BIOS battery is inserted. But then power button shows no sign of life.
                          If no BIOS battery is plugged in, I have 0V on PQ700 pin 4. But power button led will light when pressed.
                          PD3 without BIOS battery: Pin 1, 3.13V // Pin 2, 0.08V // Pin 3, 3.30V
                          PD3 with BIOS battery: Pin 1, 3.13V // Pin 2, 2.97V // Pin 3, 3.30V
                          PQ700 pins 1 8 & 4 with power removed: multimeter reads "open line"
                          Just to be sure, this is the "beep mode", right? I have tested all of the pins separately with ground -> open line for each pin. Then I have tested the pins with one another 1 & 4, 1 & 8, 4 & 8. Still "open line". Is that what you needed?
                          • lapfix
                            • Mar 2020
                            • 2721
                            • my workshop
                            Back to this one , i have 0V too at the gate of pq700 , 0v at pin 7 of pu800 , pin1 =19v and pin 2=9v
                            the lap come to me with a short to ground (pc716)...after removing all work fine , but after some test the lap turn on , 186 amp than off, no display
                            can i conclude that pu 800 is faulty than try to bypass ( i find 2differents way )
                            or i must do some other test
                            thank you
                            • Bowline
                              by Bowline
                              06-11-2025, 10:13 AM
                            • re1nhold
                              Bios needed, Dell E5550, Tag FSFB262, Zam80 La-911P Rev.1
                              by re1nhold
                              Hello Guys
                              I'm currently fixing two different Dell latitudes,
                              I need a E5550 BIOS - SERVICE TAG is: FSFB262
                              So far I flashed about 6 BIOS from this forum already,
                              none worked,
                              only fan spin ~3s, LCD black, keyboard LED on/off ok,
                              I tried manual extraction with scripts for ages so to speak. VM is untried yet.
                              This laptop is not burnt, it seems to just have a corrupted BIOS.
                              I extra baught ram. This has to work friends.
                              Do you generate it this way in Windows in CMD?:
                              Code:
                              E5550A24.exe /writeromfile C:\bios.fd
                              07-18-2025, 09:18 AM
                            • Eradicatus
                              Dell Latitude E5550 - Strange Internal LCD (BIOS?) Issue
                              by Eradicatus
                              I have a problem with my Dell Latitude E5550 laptop, in particular with its display.
                              This laptop has been sat under my desk (unused) for quite a while and I wanted to reinstall Windows and use it for some ad-hoc testing.
                              However, I am struggling with the display, which is playing up.
                              1) When the laptop is left switched off, after switching it back on the internal LCD does not work. No images are displayed at all - no DELL logo on POST, no messages, no Windows desktop. But I can hear that Windows starts up correctly, so no issues with the rest of the system - must be...
                              04-20-2022, 02:40 AM
                            • lapfix
                              Dell Latitude E5550 LA-A911P no complete power on !
                              by lapfix
                              First the lap come witth a short to GND , it was a faulty capacitator : PC716
                              After desoldered , the lap works fine...but after some tries not power on.
                              Power supply reach 0.159amp for 1 minute than off...no short to GND at all coils .
                              All the voltages at PM TABLE are finded , try another bios same behaviour !
                              PS id is oK ; i try with an original charger same behaviour too...
                              PQ700 a P-channel is ok , but his gate is not correct..0.001v...
                              Pin 5/8 = 19v
                              Pin1/3 = 19 v
                              Pin 4 = 0.001v...not correct.
                              Pu 800 =
                              Pin...
                              07-29-2024, 06:05 AM
                            • MMH3
                              Dell Optiplex 5050 SFF - strange behavior and service_mode jumper not working anymore
                              by MMH3
                              i have many 5050sff. all of them, and how i experienced over many years for all about 250 DELLs goin through my hands, are fully flashable and can be serviced in any way when the service_mode jumper is set.
                              Never ever i experienced problems with that.
                              Now i have one 5050sff machine, where this jumper isnt working at all.
                              I do not get the normal messge that the jumper is set when booting and a short test with FPT just confirms this. Everything is locked -->> EVEN for reading !?
                              The history of the machine is that i used it in my office...
                              03-23-2025, 09:28 PM
