Dead Sony VAIO Duo 13 (MBX-281)
  • damatg
    • Oct 2020
    • 6
    • Italia
    I just bought a dead Sony VAIO Duo 13 ... and I'm willing to restore it to its past glory!
    The device has been already opened, and a clear sign of this is a broken flat cable that connects the power switch and the charge led to the motherboard.
    Unfortunately this seems to be just one of the laptop's problems, here's my troubleshooting.
    I disconnected everything from the motherboard (even the main battery), except the fan.
    Charger's output is 10.5v. This voltage is present at the motherboard, and passes the first fuse.
    Voltage at the power button pin is 3.3v as soon as i attach the power supply.
    I checked the voltage at the various power inductors. It is 0v, but if I pull down to ground for some seconds the power button pin, I get 5.1v and 3.3v at two of the coils (tomorrow I'll try to contextualize with some pics).
    All other power inductors remain at 0v even after simulating the power button pressure. Nothing seems to get particularly hot in this case.
    If the main battery is connected to the motherboard, something interesting happens. One third power inductor goes to 8.5v. However, after simulating the power button pressure it becomes hot (battery pack rating is 7.5v), along with an adjacent mosfet and a couple of passive components (and battery charger IC, BQ-24735) on the other side of the board (tomorrow I'll try to contextualize with some pics).
    No power at the Winbond flash, no power at USB ports.
    Some questions for you people:
    1. Is it possible that this laptop can't be powered on without battery? Why the "getting hot" fault is showing only in this occasion?
    2. It seems a possible case of a shorted cap ... but why does it show up only if the battery is connected?
    3. Why 5.1v and 3.3v show up only after power switch is pressed? Even though somehow a low power 3.3v rail is always there, since it's always present at the power switch (is this a sign that the Super I/O chip is good?).
    4. Someone has a board diagram for this board?
    5. I checked some enable signals (I'll repeat the test tomorrow though) at voltage regulator TPS-51367 and it seems 0v ...
    I'll dedicate some more time to study it asap, please follow this thread and give me suggestions!
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: Dead Sony VAIO Duo 13 (MBX-281)
    what are the voltage's with battery & with out battery all pins of TPS-51367 BQ-24735
    for some plate forms you cant power the board with out battery ? Sony have a different Architecture the ALW come after PWRBTW LDO 3/5V must come 1st uplode a PIC of the olny the MB both side
    • damatg
      • Oct 2020
      • 6
      • Italia
      Hi, thank you for your reply!
      I further analyzed the situation.
      Today, with battery attached, the behavior of the motherboard was (somehow) a bit different.
      Infact, the "hot" components never become hot, and sometimes it was not necessary to simulate the power button to make 5V and 3.3V show up. When this was not the case, 5V and 3.3V were present right after the power cord was connected, and then went to 0V in some seconds.
      I checked the voltages at the two ICs (image attached).
      Basically TPS51367 is not powering on ... EN is 0V and VREF is 0V (well, this is actually not really exciting ...).
      BQ24735 seems fine, i think that ACOK is 0V just because it seems there's no pull up resistor.
      • PantherDave
        by PantherDave
        Hi all!
        05-29-2024, 02:01 PM
      • GLISIT
        by GLISIT
        01-16-2025, 02:29 PM
      • PopsCaps
        Sony Bravia KDL-40V2500 that will not power on
        by PopsCaps
        I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
        I do not hear any sound and I cannot see any backlight.
        I have tried disconnecting every cable on each board one at a time to see if anything changes.
        The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
        My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
        03-25-2025, 11:23 AM
        Sony VAIO SVF1541M1E Notebook Fit E Specification for Upgrade or Repair
        This specification for the Sony VAIO SVF1541M1E Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF1541M1E boardview and SVF1541M1E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony...
        09-06-2024, 05:27 AM
