Dell bios modification
  • dylen
    • May 2017
    • 173
    • Mauritius
    Hi, is there a way to modify a dell bios manually or via a utility so as to rename the laptop model and service tag in a reprogramed bios so as to be as the original one. Thanks, waiting for your reply.
  • peste
    • 13581
    • ROMANIA
    Re: Dell bios modification
    use the HxD program, enter the original bios and the one you want to modify in program, tick the DMI region o both bios and copy-paste.
    • mikeybass
      by mikeybass
      04-23-2025, 04:30 PM
    • capoplays
      Help with BIOS update on Dell G15 5515 after chip replacement
      by capoplays
      Hey everyone,
      I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
      The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
      When I check the BIOS using the F12 menu Flash...
      10-24-2025, 06:53 AM
    • Akhlz001
      by Akhlz001
      09-20-2025, 07:15 PM
    • Sathsul
      Dell Latitude 5431 issues with dumping bios
      by Sathsul
      So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
      The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
      However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
      Yesterday, 07:49 AM
    • jhanra
      by jhanra
      11-02-2024, 04:19 AM
