820-2132-A, A1229 blinking light on magsafe
  • lcdcaps1
    • Oct 2011
    • 322
    #41
    Re: 820-2132-A, A1229 blinking light on magsafe
    Originally posted by lcdcaps1
    I have tested the s0 rails for ohms
    and they are below
    PP5V_S0 2.245k ohm
    PPVCORE_S0_CPU 0.5 ohm
    PPVCORE_S0_NB_GFX 42.1 ohm
    PP3V3_S0 0.7k ohm
    PP1V8_S0 1.3k ohm
    PP1V5_S0 462 ohm
    PP1V25_S0 130 ohm
    PP1V05_S0 26.3 ohm
    PPVCORE_S0_NB_R 26.1 ohm
    PP0V9_S0 1.4k ohm
    Hi can someone help me please
    I don't know if the following is a real short or if it is meant to be so low
    On this model the cpu is T7800
    I put one multimeter leads on ground and other on pin 2 on the coil and get the following
    L7100 is 0.5 ohm
    L7101 is also 0.5 ohm
    Does this mean My cpu is dead
    • piernov
      • Jan 2016
      • 4439
      • France
      #42
      Yes that's a short to ground, it should be at least a few ohms.
      I've never seen a Core 2 Duo CPU get internally shorted though.
      • lcdcaps1
        • Oct 2011
        • 322
        #43
        what could be causing the short
        do i remove L7100 and L7101
        • lcdcaps1
          • Oct 2011
          • 322
          #44
          I was looking on the board view
          L7100 pin 1 goes to IMVP6_PHASE1 and Pin 2 goes to PPVCORE_S0_CPU
          I then looked at all the points it connects to regarding PPVCORE_S0_CPU
          I saw that it connects to R1100
          R1100 is 100 ohms but i measured mine and it is 000.4 ohms
          could this be bringing the ohm reading down on L7100
          • piernov
            • Jan 2016
            • 4439
            • France
            #45
            CPU_VCCSENSE_P is connected to PPVCORE_S0_CPU inside the CPU, so it's normal to measure 0 ohm between CPU_VCCSENSE_P and PPVCORE_S0_CPU.
            • lcdcaps1
              • Oct 2011
              • 322
              #46
              Hi
              do i have a short on L7100 and L7101
              • lcdcaps1
                • Oct 2011
                • 322
                #47
                Hi all
                Can My CPU be bad or can U7100 be bad
                Please will really appreciate the help from everyone
                Many Thanks
                • piernov
                  • Jan 2016
                  • 4439
                  • France
                  #48
                  Any components connected to both PPVCORE_S0_CPU and ground could be bad, including the CPU, the low-side MOSFETs of the buck converter, the buck controller the bypass capacitors, …
                  • lcdcaps1
                    • Oct 2011
                    • 322
                    #49
                    Hi what would be the quickest way to find out whats causing this
                    voltage injection could be risky, right ?
                    • piernov
                      • Jan 2016
                      • 4439
                      • France
                      #50
                      If you don't go above 1.3V it's fine.
                      • lcdcaps1
                        • Oct 2011
                        • 322
                        #51
                        What about amps
                        Where should I connect My positive wire
                        on the coil ?
                        Also should I remove the coils before doing this
                        • lcdcaps1
                          • Oct 2011
                          • 322
                          #52
                          Hi all
                          • lcdcaps1
                            • Oct 2011
                            • 322
                            #53
                            Hi, has anyone worked on this motherboard model before
                            Please
                            • lcdcaps1
                              • Oct 2011
                              • 322
                              #54
                              on another board
                              R1100 measures normal
                              • dellxps15
                                • Feb 2014
                                • 1598
                                • italy
                                #55
                                what cpu it has ? on all macbook with core duo on inductor cpu i have from 015 to 034 in diode mode values, so if u have 004 i think there is some problem with cpu itself.
                                try remove both cpu inductor and see wich side u have low value... if its cpu side maybe there is a problem with cpu.
                                • lcdcaps1
                                  • Oct 2011
                                  • 322
                                  #56
                                  Hi
                                  Thanks for the reply
                                  The cpu is T7800
                                  I have lifted the coils
                                  L7100 and L7101
                                  The short to ground is on the cpu side
                                  On L7100 pin 1 is 3.9k ohms and pin 2 is 0.5 ohms
                                  on L7101 pin 1 is9k 9.4k ohms and pin 2 is 0.7 ohms
                                  • lcdcaps1
                                    • Oct 2011
                                    • 322
                                    #57
                                    Hi
                                    I have an adjustable power supply (MAISHENG MS3010D) and trying to get the voltage injection to work
                                    I have lifted the coils to isolate the cpu
                                    I set voltage to 0.30v but when i short the leads i cannot get it to do current limiting
                                    so the c.c light does not light but the current shows 0.10A
                                    Can someone help me with this
                                    Many Thanks
                                    i connect positive lead to PPVCORE_S0_CPU and other lead to ground
                                    • piernov
                                      • Jan 2016
                                      • 4439
                                      • France
                                      #58
                                      Increase voltage to 1.2V. With 0.7 ohms to ground that should generate 1.7A of current and 2W of heat.
                                      • lcdcaps1
                                        • Oct 2011
                                        • 322
                                        #59
                                        I cant see any sign of damaged component
                                        • YasaCh
                                          Sony kdl 40p5500 red light keeps blinking 3 times
                                          by YasaCh
                                          Hello...
                                          my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
                                          i opened the back cover no sign of damage on the powery suply or motherboard
                                          when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
                                          another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
                                          07-07-2025, 11:53 AM
                                        • Fergal22
                                          Samsung UE40F5300AK blinking red light
                                          by Fergal22
                                          I have the above tv that just shows a red light blinking twice 5 times, i have taken the back off and all the capacitors seem ok,
                                          When i disconnect the mainboard from the PSU all the led's light up blinking fast but as soon as i reconnect the mainboard back to the power supply i get the red light blinking again twice 5 times,
                                          I have attached pictures of the Mainboard, PSU and a small video (zipped) showing what happens when i disconnect the lead from the psu
                                          Any help would be appreciated...
                                          02-02-2023, 09:19 AM
                                        • matty24
                                          Samsung UE50MU6172 - red light blinking
                                          by matty24
                                          Hello. I have problem with Samsung UE50MU6172.
                                          TV won't turn on, red standby light is blinking.
                                          Power supply BN44-00807A is fine. I replaced it with the new one.​
                                          Main board BN41-02568B (BN94-12530E)
                                          I've read a dump (W25Q40CL). Can someone check it od fix it for me?...
                                          03-02-2025, 08:57 AM
                                        • norbiszoke
                                          Samsung 50AU7172, only blinking red light
                                          by norbiszoke
                                          We have this set here in our shop that is not ginving sign of life besides red light that is blinking one time after pressing the button and nothing more... After detaching the mainboard from the PSU (this set has separate board thank god?! or not...) the backlight comes on. After reattaching nothing besides red light.... Can anyone from the forum help me here? Thank you in advance. Here's a link with images of the mainboard and the memory IC's that are on it.
                                          Regards, Norbert!...
                                          04-17-2024, 06:54 AM
                                        • huzo
                                          HP 470 G5 blinking amber light no power
                                          by huzo
                                          The board is daox8cmb6eo and i can't find no boardview or schematics on the forum or anywhere...
                                          So i plug in the charger, amber light starts blinking ,there is 3.3V and 5V present, and 2.4V on the power button,board doesn't turn on, no shorts...
                                          I've tried flashing the bios...
                                          interesting thing is the battery was around 7,8V, and it's 11.1V battery, the mosfet near the battery is open, but not charging,i desoldered it,tested it and it's fine ,but the amber light kept going on the charger so i charged the battery with power supply and got it to about 10.5V...
                                          06-08-2023, 04:08 PM
