820-2132-A, A1229 blinking light on magsafe
  • lcdcaps1
    • Oct 2011
    • 322
    Hi
    All
    I have an old Macbook pro, A1229 (820-2132-A)
    I can't remember why this stopped working before and what i did to troubleshoot it before
    It's been many years but today I wanted to look at it again
    I checked over the board and can't see any burnt marks or anything looking out of place
    I started troubleshooting the voltage rails but when I plug in My Magsafe (Original, 85w charger) and I use My tweezers to short the power on pads to turn on, the magsafe charger starts blinking
    I don't know if this is a problem with the left I/O board or the logic board
    I don't have a spare Left I/O board and don't really want to burn cash to getting one, instead would really like to repair the Left I/O Board.
    Can anyone help me please to diagnose this
    I can't see anything wrong visually with the Left I/O board
    I will really appreciate it very much
    Many Thanks
    Kind Regards
  • piernov
    • Jan 2016
    • 4437
    • France
    Re: 820-2132-A, A1229 blinking light on magsafe
    Go through the list of power rails and measure voltage when off, voltage after pressing power button and resistance to ground.
    • lcdcaps1
      • Oct 2011
      • 322
      Hi
      Thanks for the reply
      I was about to do that but I just want to rule out if it is a bad IO board
      I don't have a spare one
      How can i do that
      anyone had any experience with these please
      • piernov
        • Jan 2016
        • 4437
        • France
        You can't trivially rule it out. It's a pretty complex one on this machine. It contains the discrete circuit for 1-wire protection and its own 3V/5V regulator for audio and USB circuits (on the LIO board as well), and they could be part of the problem as well.
        • lcdcaps1
          • Oct 2011
          • 322
          Hi
          Yes I saw that
          I saw a video online where a macbook DC in board was repaired, although it was newer than this one
          But I saw another one where the DC voltage was leaking onto to the data line
          • lcdcaps1
            • Oct 2011
            • 322
            Hi i have an update
            I have a green light on the charger and I have been following the voltages
            I have checked so far
            PP18V5_G3H_CHGR
            I have voltage on CHGR_EN
            I have voltage on PPDCIN_G3H
            I have PP3V42_G3H
            • lcdcaps1
              • Oct 2011
              • 322
              I have gone through all the power rails and below are voltages
              PP18V5_DCIN 16.42v
              PP18V5_G3H_CHGR 16.42v
              U7900, CHGR_EN 4.8V
              PPDCIN_G3H 15.41v
              U7800, VIN 15.22v
              U7800, SHDN 15.22v
              PP3V42_G3H 3.4v
              PPBUS_G3H 12.59v
              PPDCIN_G3H 15.41v
              PP3V42_G3H 3.4v
              PP5V_S5 0v
              PP5V_S3 0v
              PP5V_S0 0v
              PPVCORE_S0_CPU 0v
              PPVCORE_S0_NB_GFX 0v
              PP3V3_S5 3.2v
              PP3V3_S3 0v
              PP3V3_S0 0v
              PP1V25_ENET_ISNS 0v
              PP1V8_S3 0v
              PP1V8_S3_ISNS 0v
              PP1V8_S0 0v
              PP1V5_S0 0v
              PP1V25_S0 0v
              PP1V05_S0 1v
              PPVCORE_S0_NB_R 1v
              PP0V9_S3_MEM_VREF 0.9v
              PP0V9_S0 0.9v
              PP3V3_ENET 3.2v
              PP1V9_ENET 0v
              PP1V25_ENET 0v
              PPBUS_FW_FWPWRSW_F 12.59v
              PPVP_FW 12.41v
              PPVP_FW_PORTA_UF 12.42v
              PPVP_FW_PORTB_UF 12.39v
              PP3V3_FW 3.3v
              PP1V95_FW 1.9v
              PP3V3_GPU 0v
              PP3V3_GPU_TMDS 0v
              PP1V8_GPU 0v
              PP1V25_GPU 0v
              PPVCORE_GPU 0v
              • piernov
                • Jan 2016
                • 4437
                • France
                Originally posted by lcdcaps1
                PP5V_S5 0v
                That would be a problem, double check this measurement.
                PP1V05_S0 1v
                PPVCORE_S0_NB_R 1v
                PP0V9_S0 0.9v
                It sounds suprising that some random S0 rails come up when you're not even getting correct PP5V_S5, and no other S3 rails. Again double check your measurements.
                • lcdcaps1
                  • Oct 2011
                  • 322
                  So I need to find out what creates PP5V_S0
                  • lcdcaps1
                    • Oct 2011
                    • 322
                    Does anyone know what can be used as a substitute for IRF7707PBF, please
                    • lcdcaps1
                      • Oct 2011
                      • 322
                      Hi
                      This machine model does not auto power on when magsafe is connected
                      I plugged in magsafe and touched the power on pads with tweezers to turn on and get voltage measurements
                      I get a green light and voltage measurements are as I posted them
                      I get 5v on pin 1 on u7300, which is PP5V_S5
                      but if i check other places where PP5V_S5 should be is not there
                      Can anyone advise on what might cause this
                      has anyone got experience with this board, please
                      • lcdcaps1
                        • Oct 2011
                        • 322
                        I have 4.9v on PP5V_S5
                        I checked on c8900
                        • dellxps15
                          • Feb 2014
                          • 1597
                          • italy
                          in diode mode value of gpu power rail ? it has old nvidia kown to fail...
                          • lcdcaps1
                            • Oct 2011
                            • 322
                            Hi seems like it is trying to boot because The fan starts to spin and then stops
                            About 2 seconds between starting and stopping
                            I checked all_sys_pwrgd, on Pin 4 of u7880 and get 3.2v
                            • lcdcaps1
                              • Oct 2011
                              • 322
                              Which power rail for the gpu
                              there are a few
                              • lcdcaps1
                                • Oct 2011
                                • 322
                                ok on c1252 which is PPVCORE_S0_CPU i get 0,7v
                                If I keep My probe on c1252 and when the fan starts I get 0.7v but then when fan stops the voltage goes down to 0v but when fan starts spinning the voltage goes to 0.7v
                                • piernov
                                  • Jan 2016
                                  • 4437
                                  • France
                                  Of course the GPU will be dead if it hasn't been replaced by the fixed revision, but they don't short when failing. Only when they are mistakenly reflowed…
                                  • dellxps15
                                    • Feb 2014
                                    • 1597
                                    • italy
                                    half fan spin could be also cpu circuit... clock generator and so on
                                    • lcdcaps1
                                      • Oct 2011
                                      • 322
                                      any chance of helping me further, please
                                      I know that this model had a bad gpu but surely the fan should spin continuously
                                      • dellxps15
                                        • Feb 2014
                                        • 1597
                                        • italy
                                        if it was a newer model we could see if current resistor were ok, but here it use ISL6255AHRZ and different layout. tomorrow ill see datasheet and see if we can find some news
                                        edit: check if R7905 is 18 ohm
                                        • YasaCh
                                          Sony kdl 40p5500 red light keeps blinking 3 times
                                          by YasaCh
                                          Hello...
                                          my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
                                          i opened the back cover no sign of damage on the powery suply or motherboard
                                          when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
                                          another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
                                          07-07-2025, 11:53 AM
                                        • Fergal22
                                          Samsung UE40F5300AK blinking red light
                                          by Fergal22
                                          I have the above tv that just shows a red light blinking twice 5 times, i have taken the back off and all the capacitors seem ok,
                                          When i disconnect the mainboard from the PSU all the led's light up blinking fast but as soon as i reconnect the mainboard back to the power supply i get the red light blinking again twice 5 times,
                                          I have attached pictures of the Mainboard, PSU and a small video (zipped) showing what happens when i disconnect the lead from the psu
                                          Any help would be appreciated...
                                          02-02-2023, 09:19 AM
                                        • matty24
                                          Samsung UE50MU6172 - red light blinking
                                          by matty24
                                          Hello. I have problem with Samsung UE50MU6172.
                                          TV won't turn on, red standby light is blinking.
                                          Power supply BN44-00807A is fine. I replaced it with the new one.​
                                          Main board BN41-02568B (BN94-12530E)
                                          I've read a dump (W25Q40CL). Can someone check it od fix it for me?...
                                          03-02-2025, 08:57 AM
                                        • norbiszoke
                                          Samsung 50AU7172, only blinking red light
                                          by norbiszoke
                                          We have this set here in our shop that is not ginving sign of life besides red light that is blinking one time after pressing the button and nothing more... After detaching the mainboard from the PSU (this set has separate board thank god?! or not...) the backlight comes on. After reattaching nothing besides red light.... Can anyone from the forum help me here? Thank you in advance. Here's a link with images of the mainboard and the memory IC's that are on it.
                                          Regards, Norbert!...
                                          04-17-2024, 06:54 AM
                                        • huzo
                                          HP 470 G5 blinking amber light no power
                                          by huzo
                                          The board is daox8cmb6eo and i can't find no boardview or schematics on the forum or anywhere...
                                          So i plug in the charger, amber light starts blinking ,there is 3.3V and 5V present, and 2.4V on the power button,board doesn't turn on, no shorts...
                                          I've tried flashing the bios...
                                          interesting thing is the battery was around 7,8V, and it's 11.1V battery, the mosfet near the battery is open, but not charging,i desoldered it,tested it and it's fine ,but the amber light kept going on the charger so i charged the battery with power supply and got it to about 10.5V...
                                          06-08-2023, 04:08 PM
