820-2132-A, A1229 blinking light on magsafe
  • lcdcaps1
    • Oct 2011
    • 322
    Re: 820-2132-A, A1229 blinking light on magsafe
    Originally posted by dellxps15
    if it was a newer model we could see if current resistor were ok, but here it use ISL6255AHRZ and different layout. tomorrow ill see datasheet and see if we can find some news
    edit: check if R7905 is 18 ohm
    Hi
    Thanks I'll check and report
    • lcdcaps1
      • Oct 2011
      • 322
      I checked R7905 and it is 18.1 ohm
      • dellxps15
        • Feb 2014
        • 1598
        • italy
        check R7904, R7906
        • lcdcaps1
          • Oct 2011
          • 322
          check R7904, R7906
          ok i will check
          but can you let me know if c7196 is not there would this cause the half fan spin problem
          • dellxps15
            • Feb 2014
            • 1598
            • italy
            according to solder on it u can spot if something was present, but according to schematic it should be there
            • lcdcaps1
              • Oct 2011
              • 322
              #26
              Would this missing component be causing the problem
              • dellxps15
                • Feb 2014
                • 1598
                • italy
                #27
                nope
                • lcdcaps1
                  • Oct 2011
                  • 322
                  #28
                  Ok i just checked
                  R7906 is 2.4 ohms
                  R7904 is 000.2 ohms
                  On the schematic it says R7904 should be 220 ohms in one place but in another place in a box, says something different
                  Should this be 0 hms or 220 ohms
                  Please
                  Can anyone measure on a good board please
                  • dellxps15
                    • Feb 2014
                    • 1598
                    • italy
                    #29
                    Originally posted by lcdcaps1
                    Ok i just checked
                    R7906 is 2.4 ohms
                    R7904 is 000.2 ohms
                    Please
                    on schematic they are 2.2 and 270, but in the datasheet https://www.renesas.com/cn/en/www/do...et/isl6255.pdf it report 2.2 and 40 , so one is ok, but the other is not. try remove it and measure without any connection.
                    R7908 is 0.01. maybe it make interference in the measure of r7904
                    • piernov
                      • Jan 2016
                      • 4439
                      • France
                      #30
                      R7904 is ok. SMD resistors don't fail shorted.
                      • lcdcaps1
                        • Oct 2011
                        • 322
                        #31
                        hi
                        thanks for the reply
                        i will check and report back
                        would this be the cause of it not turning on fully
                        what do you think please
                        thanks again
                        • lcdcaps1
                          • Oct 2011
                          • 322
                          #32
                          so which resistors do i need to recheck and remove
                          • lcdcaps1
                            • Oct 2011
                            • 322
                            #33
                            Hi all
                            • lcdcaps1
                              • Oct 2011
                              • 322
                              #34
                              Do you have any other ideas pls
                              • lcdcaps1
                                • Oct 2011
                                • 322
                                #35
                                Hi
                                attached image is a screen shot from the schematic that shows r7904 is to be 0 ohm
                                not sure if Mine is measuring correctly because the schematic shows two different values for r7904
                                • lcdcaps1
                                  • Oct 2011
                                  • 322
                                  #36
                                  I have been doing more measurements
                                  I have found pm_s4_state_L gives me 3.2v when the fan spins but when it stops goes to 0v
                                  • lcdcaps1
                                    • Oct 2011
                                    • 322
                                    #37
                                    My PPVCORE_S0_CPU is shorted to 0.4 0hm
                                    • dellxps15
                                      • Feb 2014
                                      • 1598
                                      • italy
                                      #38
                                      post u7100 voltage.
                                      it charge battery ? it work with battery only ?
                                      • lcdcaps1
                                        • Oct 2011
                                        • 322
                                        #39
                                        post u7100 voltage.
                                        Hi
                                        I dont know about charging battery
                                        which voltages do you need regarding u7100
                                        • lcdcaps1
                                          • Oct 2011
                                          • 322
                                          #40
                                          I have tested the s0 rails for ohms
                                          and they are below
                                          PP5V_S0 2.245k ohm
                                          PPVCORE_S0_CPU 0.5 ohm
                                          PPVCORE_S0_NB_GFX 42.1 ohm
                                          PP3V3_S0 0.7k ohm
                                          PP1V8_S0 1.3k ohm
                                          PP1V5_S0 462 ohm
                                          PP1V25_S0 130 ohm
                                          PP1V05_S0 26.3 ohm
                                          PPVCORE_S0_NB_R 26.1 ohm
                                          PP0V9_S0 1.4k ohm
                                          • YasaCh
                                            Sony kdl 40p5500 red light keeps blinking 3 times
                                            by YasaCh
                                            Hello...
                                            my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
                                            i opened the back cover no sign of damage on the powery suply or motherboard
                                            when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
                                            another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
                                            07-07-2025, 11:53 AM
                                          • Fergal22
                                            Samsung UE40F5300AK blinking red light
                                            by Fergal22
                                            I have the above tv that just shows a red light blinking twice 5 times, i have taken the back off and all the capacitors seem ok,
                                            When i disconnect the mainboard from the PSU all the led's light up blinking fast but as soon as i reconnect the mainboard back to the power supply i get the red light blinking again twice 5 times,
                                            I have attached pictures of the Mainboard, PSU and a small video (zipped) showing what happens when i disconnect the lead from the psu
                                            Any help would be appreciated...
                                            02-02-2023, 09:19 AM
                                          • matty24
                                            Samsung UE50MU6172 - red light blinking
                                            by matty24
                                            Hello. I have problem with Samsung UE50MU6172.
                                            TV won't turn on, red standby light is blinking.
                                            Power supply BN44-00807A is fine. I replaced it with the new one.​
                                            Main board BN41-02568B (BN94-12530E)
                                            I've read a dump (W25Q40CL). Can someone check it od fix it for me?...
                                            03-02-2025, 08:57 AM
                                          • norbiszoke
                                            Samsung 50AU7172, only blinking red light
                                            by norbiszoke
                                            We have this set here in our shop that is not ginving sign of life besides red light that is blinking one time after pressing the button and nothing more... After detaching the mainboard from the PSU (this set has separate board thank god?! or not...) the backlight comes on. After reattaching nothing besides red light.... Can anyone from the forum help me here? Thank you in advance. Here's a link with images of the mainboard and the memory IC's that are on it.
                                            Regards, Norbert!...
                                            04-17-2024, 06:54 AM
                                          • huzo
                                            HP 470 G5 blinking amber light no power
                                            by huzo
                                            The board is daox8cmb6eo and i can't find no boardview or schematics on the forum or anywhere...
                                            So i plug in the charger, amber light starts blinking ,there is 3.3V and 5V present, and 2.4V on the power button,board doesn't turn on, no shorts...
                                            I've tried flashing the bios...
                                            interesting thing is the battery was around 7,8V, and it's 11.1V battery, the mosfet near the battery is open, but not charging,i desoldered it,tested it and it's fine ,but the amber light kept going on the charger so i charged the battery with power supply and got it to about 10.5V...
                                            06-08-2023, 04:08 PM
