S7 edge power issues
  • bananz0
    • Aug 2020
    • 11
    • Kenya
    Hi Everyone,
    I have an S7 edge (G935F) that stopped fast charging and charges for about 10 hours. It draws 480ma and I can't find what's wrong. It also stopped mtp connection to pc and otg doesn't work at all. I did replace the charging daughter board but nothing changed. Does anyone have any idea of what's wrong?
    Also mods, if this is not the right place to post please feel free to remove it.
  • UA_GSM
    • Sep 2020
    • Horodenka
    Re: S7 edge power issues
    use picture bro
    • bananz0
      • Aug 2020
      • 11
      • Kenya
      All of them seem okay. Can it be the power management ic?
      • mrcliem
        • Mar 2020
        • 25
        • Indonesia
        Check usb data line D+ and D-, most likely shorted protection diode
        • PantherDave
          by PantherDave
          Hi all!
          05-29-2024, 02:01 PM
        • GLISIT
          by GLISIT
          01-16-2025, 02:29 PM
        • zlr8r
          Dell inspiron 17 (7786) - DP/N 09P7JP - odd power issues, starting with no power LED
          by zlr8r
          hey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
          Ill try and give as much info as I can.
          Dell Inspiron 17 (7786) Laptop
          Service Tag: 5J0NHT2
          Bios: 1.9.0
          When I received this , it would only flicker on the KB backlight for a second, then off and on.
          Then it started getting weirder!
          Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has...
          12-12-2023, 09:31 PM
        • sli4
          Original NES power issues
          by sli4
          I recently turned on my old NES to find the red light won't go on at all. When powered on it shows black bars on the tv and a loud buzz through the tv speakers. Powering it off, the buzz goes away and tv goes back to normal (white snow).
          I tested the power supply itself and it is outputting 9V as it should - first two solder joints on the board at the power port show the same.
          Here's where it starts getting funky - When powered on, one side of the 7805 voltage regulator is showing 18V and the other is about 8.7V (center 0).
          On the big blue connector I get...
          11-28-2024, 12:52 PM
