No EC_ON on LA-B972
  • raajkumar
    • Mar 2015
    • 354
    • Srilanka
    No EC_ON on LA-B972
    I have an issue on LA-B972 Board. Unfortunately i don't have schematic for the mboard. I checked with similar schematics but i don't have RSMRST, EC_ON on this mboard. Have +3V Ldo and +5V LDo. +3V ALW_EC on KB9012qf also available but there is no power on Bios chip pin no. 8. Does anyone having any clue.
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3577
    • slovakia
    Re: No EC_ON on LA-B972
    on never laptops there must not be voltage 3.3ALW and 3,3V on bios, it is generated after push of start button
    • raajkumar
      • Mar 2015
      • 354
      • Srilanka
      I know that. SIO having EC_VCC on pins 9, 22, 33, 96, 111, 125, 67 and power switch also having +3V. But it is not producing EC_RSMRST, PBTN_OUT and EC_ON.
      Does anyone having Schematic or Boardview for LA-B972 Board. I checked with LA-A992P Schematic but its not matched and totally different.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        AD_ID fine?? Try changing dc jack as well . I had a similar case on LA-A994P where EC_ON was missing. Ultimately changing the dc jack helped.
        • raajkumar
          • Mar 2015
          • 354
          • Srilanka
          I will try and let you know soon
          • raajkumar
            • Mar 2015
            • 354
            • Srilanka
            It worked but unfortunately i got 1.0Volt on bios pin no 8.
            • raajkumar
              • Mar 2015
              • 354
              • Srilanka
              Is there any difference between KB9012QF A4 and KB9012QF A3 SIO Chips. Because this board has KB9012QF A3 SIO chip but i don't have that in stock. So i replaced with KB9012QF A4 SIO chip. Is it giving any trouble on this case?
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                KB9012QF-A3 and A4- i've replaced them on many mb's and have always worked. Did it on Dell LA-9981P yesterday only, original was with suffix A4 but replaced with suffix A3.
                • Fernon@Repair
                  MSI mpg b560m bazooka motherboard RSMRST# signal missing
                  by Fernon@Repair
                  I have MSI mpg b560m bazooka motherboard . this motherboard RSMRST# signal missing . i already reprogram bios but same condition
                  My Motherboard this power stages are ok ...but 3vsb voltage have 4.17v (image added)
                  VCCRTC ok
                  RTCRST# ok
                  ATX_5VSB ok
                  SIO_3VA ok
                  3VDSW ok
                  DPWROK ok
                  SLP_SUS# ok
                  VSB_ENABLE# ok
                  5VDUAL ok
                  3VSB showing 4.17V
                  PCH_1P8_VSB ok
                  PCH_VCCIN_AUX ok
                  RSMRST# No voltage
                  this all voltages are ok but RSMRST# voltage is missing i did try to re program bios and change io but same...
                  06-03-2025, 10:49 AM
                • AstutePauciloquent
                  Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
                  by AstutePauciloquent
                  Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
                  I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
                  11-23-2023, 11:02 PM
                • imtmiissa
                  Ask about IO KB9012QF
                  by imtmiissa
                  Hi, I want to change KB9012QF A4 on bored model LA9981P for KB9012QF A3 on bored model LA-9104P can i do it without programming because it in old bored and already programmed
                  02-17-2023, 08:50 AM
                • kalilinux25
                  Missing RSMRST# on hp JAL50-LA-4101P
                  by kalilinux25
                  First problem of the laptop was when cahrger connected Charger led is not present..
                  after checking all ive decided to flash the bios.
                  Now the DC jack glows ,after checking the first reset signal the RSMRST# IS ov
                  32,768KHZ is present at Y5 on oscilloscpoe
                  RTCRST# has 3.3v @ CLRP2
                  RSMRST# 0v @ pin 100 f ec
                  ON/OFFBTN @ pin 32 has 3.3v when triggered goes 0v and goes 3.3v if released
                  PWRBTN_OUT# @ 117 has 3.3v if triggered the switch doesnt goes to 0v .
                  EC_ON @ 102 -3.3v
                  Ill also attched my backup...
                  04-29-2022, 09:22 PM
                • admharsha7777
                  Dell Inspiron 3520 rsmrst missing Help
                  by admharsha7777
                  I have this Problem with Dell Inspiron 3520 40_DV15 MLK MB 11280 mother board,
                  I couldn't found board view for this board I have similar schematic currently board not turning on.
                  +RTC_VCC is ok
                  RTC_RST# 2.5V on q2102 drain pin, in this mosfet gate RTCRST_ON_ showing 0V also kbc RTCRST_ON is 0V
                  SRTC_RST# also 2.5V
                  3D3V_AUX_S5 is precent
                  S5_ENABLE is ok
                  5V_S5 is ok
                  3D3V_S5 is ok
                  Ac in# is 0V
                  +5VA_PCH_VCC5REFSUS i don't know where to check
                  PM_RSMRST# No voltage
                  AC_PRESENT...
                  10-05-2023, 02:37 AM
