Missing RSMRST# on hp JAL50-LA-4101P
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    First problem of the laptop was when cahrger connected Charger led is not present..
    after checking all ive decided to flash the bios.
    Now the DC jack glows ,after checking the first reset signal the RSMRST# IS ov
    32,768KHZ is present at Y5 on oscilloscpoe
    RTCRST# has 3.3v @ CLRP2
    RSMRST# 0v @ pin 100 f ec
    ON/OFFBTN @ pin 32 has 3.3v when triggered goes 0v and goes 3.3v if released
    PWRBTN_OUT# @ 117 has 3.3v if triggered the switch doesnt goes to 0v .
    EC_ON @ 102 -3.3v
    Ill also attched my backup bin.
    jal50 la-4101p
    2009-05-08
    rev 1.0
    jal50 43154432l24 rev:g2 b930 bios f.42 97f4 sticker
    DV4-1465DX S/N: CND93020P9
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Missing RSMRST# on hp JAL50-LA-4101P
    Have you checked the basic requirement of SIO??
    • kalilinux25
      • Mar 2018
      • 2089
      • ZAMBOANGA SIBUGAY
      yes sir the required requirements t power the sio is ok
      • kalilinux25
        • Mar 2018
        • 2089
        • ZAMBOANGA SIBUGAY
        what part of the board should I check if the pch need to be reflowed?
        • kalilinux25
          • Mar 2018
          • 2089
          • ZAMBOANGA SIBUGAY
          PCH_PWROK is 0v @ 104
          • kalilinux25
            • Mar 2018
            • 2089
            • ZAMBOANGA SIBUGAY
            its already fixed ive found that the pin 32 of the ec has cut going to the r593 i just runned a wire and fixed the issue
            • Fernon@Repair
              MSI mpg b560m bazooka motherboard RSMRST# signal missing
              by Fernon@Repair
              I have MSI mpg b560m bazooka motherboard . this motherboard RSMRST# signal missing . i already reprogram bios but same condition
              My Motherboard this power stages are ok ...but 3vsb voltage have 4.17v (image added)
              VCCRTC ok
              RTCRST# ok
              ATX_5VSB ok
              SIO_3VA ok
              3VDSW ok
              DPWROK ok
              SLP_SUS# ok
              VSB_ENABLE# ok
              5VDUAL ok
              3VSB showing 4.17V
              PCH_1P8_VSB ok
              PCH_VCCIN_AUX ok
              RSMRST# No voltage
              this all voltages are ok but RSMRST# voltage is missing i did try to re program bios and change io but same...
              06-03-2025, 10:49 AM
            • lapfix
              Lenovo Air 15ITL NM-D211 missing RSMRST !
              by lapfix
              Lenovo Air 15ITL.
              NM-D211
              This laptop won't power on , when power supply is on it takes 0.001 , button trigger on it becomes after a couple of seconds 0.061 amp..and nothing
              No heating (Of COURSE) , no short to GNd at all coils present , 3/5 valw is present , 3/5 vl present.
              With the power plane , at state 4 +1.8VALW and +3ALW_PCH must be present but no one due to enable signal is missing .
              when button trigger on , 3v dow to zero than 3v , the super io send BTN_OUT#_R to pch but no rsmrst ..0v.
              i follow his line , no short .
              10-21-2025, 05:53 AM
            • admharsha7777
              Dell Inspiron 3520 rsmrst missing Help
              by admharsha7777
              I have this Problem with Dell Inspiron 3520 40_DV15 MLK MB 11280 mother board,
              I couldn't found board view for this board I have similar schematic currently board not turning on.
              +RTC_VCC is ok
              RTC_RST# 2.5V on q2102 drain pin, in this mosfet gate RTCRST_ON_ showing 0V also kbc RTCRST_ON is 0V
              SRTC_RST# also 2.5V
              3D3V_AUX_S5 is precent
              S5_ENABLE is ok
              5V_S5 is ok
              3D3V_S5 is ok
              Ac in# is 0V
              +5VA_PCH_VCC5REFSUS i don't know where to check
              PM_RSMRST# No voltage
              AC_PRESENT...
              10-05-2023, 02:37 AM
            • ugamazing
              820-02020 PPBUS_AON missing
              by ugamazing
              Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
              Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
              02-05-2025, 04:21 PM
            • jpreza
              Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
              by jpreza
              I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
              Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
              It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
              Looking at the card, it appears to be missing the following:
              1x 1.0uH inductor - orange square
              2x...
              11-01-2024, 10:54 PM
