hp 450 g2 la-b181p no data
  • menshawy
    • Aug 2013
    • 400
    • egypt
    hi friends
    i have hp 450 g2 mb LA-B181P with no data problem
    when i connect the adapter power button Responds after abut 30 sec
    before press power button
    pl303 +3VDSP 3.4v ok
    pl302 +5VDSP 5.05v ok
    uh5 pin8 +3V_PCH 3.4v ok
    u17 MEC1322-NU pin 85 rsmrst pin85 0v
    after press power button
    u17 MEC1322-NU pin 85 rsmrst pin85 3.4v ok
    u17 MEC1322-NU pin 38 SLP_S4# 0v
    u17 MEC1322-NU pin 81 SLP_S3# 0v
    q21
    pin 1&2 VIN1 +3VDS 3.4 v ok
    pin 6&7 VIN2 +5VDS 5.05v ok
    pin 3 & 5 SLP_S3# 0v
    pin 9&8 13&14 0v
    help please
    thanks for all
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: hp 450 g2 la-b181p no data
    Check AC_PRES_OUT / ADP_A_ID RTC Diode
    • menshawy
      • Aug 2013
      • 400
      • egypt
      AC_PRES_OUT u17 pin 99 3.3v ok
      ADP_A_ID u17 pin 42 2.0v
      RTC Diode dc1
      pin1 3.06
      pin 3 3.4v
      thanks man
      • Techtiger
        • Oct 2014
        • 1602
        • france
        Check SLP_A# ON/OFFBTN# pin 4 & PM_RSMRST out put side of the Resistor
        • menshawy
          • Aug 2013
          • 400
          • egypt
          SLP_A# u17 pin 93 0v
          ON/OFFBTN# pin 4 3.4v
          PM_RSMRST pin 85 3.4v
          thanks you
          • Techtiger
            • Oct 2014
            • 1602
            • france
            Page 42 PCH power ok can you confirm! Did you check RSMRST after the resistor? Check the resistance SLP S3 SIO pin ?
            • menshawy
              • Aug 2013
              • 400
              • egypt
              q30
              D&S 3.4V
              G 0V
              RSMRST after the resistor 3.4 v ok
              SLP S3 SIO pin don't has short
              thanks for help
              • Techtiger
                • Oct 2014
                • 1602
                • france
                Q21 Just the resistance to Ground pin 13 14 8 9 if ok put a jumper pin 1 to 14 pin 6 to 9 after check from your hands what’s getting worm if ok then try to power up & see
                • Techtiger
                  • Oct 2014
                  • 1602
                  • france
                  Try to Flash BIOS with a working one voltage on YC2 2 caps ? JCMOS1 / JME1 voltage?
                  • cxl2156565
                    • Jul 2020
                    • fiji
                    AC_PRES_OUT only 2.0v
                    • Fernon@Repair
                      MSI mpg b560m bazooka motherboard RSMRST# signal missing
                      by Fernon@Repair
                      I have MSI mpg b560m bazooka motherboard . this motherboard RSMRST# signal missing . i already reprogram bios but same condition
                      My Motherboard this power stages are ok ...but 3vsb voltage have 4.17v (image added)
                      VCCRTC ok
                      RTCRST# ok
                      ATX_5VSB ok
                      SIO_3VA ok
                      3VDSW ok
                      DPWROK ok
                      SLP_SUS# ok
                      VSB_ENABLE# ok
                      5VDUAL ok
                      3VSB showing 4.17V
                      PCH_1P8_VSB ok
                      PCH_VCCIN_AUX ok
                      RSMRST# No voltage
                      this all voltages are ok but RSMRST# voltage is missing i did try to re program bios and change io but same...
                      06-03-2025, 10:49 AM
                    • lapfix
                      Lenovo Air 15ITL NM-D211 missing RSMRST !
                      by lapfix
                      Lenovo Air 15ITL.
                      NM-D211
                      This laptop won't power on , when power supply is on it takes 0.001 , button trigger on it becomes after a couple of seconds 0.061 amp..and nothing
                      No heating (Of COURSE) , no short to GNd at all coils present , 3/5 valw is present , 3/5 vl present.
                      With the power plane , at state 4 +1.8VALW and +3ALW_PCH must be present but no one due to enable signal is missing .
                      when button trigger on , 3v dow to zero than 3v , the super io send BTN_OUT#_R to pch but no rsmrst ..0v.
                      i follow his line , no short .
                      10-21-2025, 05:53 AM
                    • AstutePauciloquent
                      Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
                      by AstutePauciloquent
                      Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
                      I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
                      11-23-2023, 11:02 PM
                    • kalilinux25
                      Missing RSMRST# on hp JAL50-LA-4101P
                      by kalilinux25
                      First problem of the laptop was when cahrger connected Charger led is not present..
                      after checking all ive decided to flash the bios.
                      Now the DC jack glows ,after checking the first reset signal the RSMRST# IS ov
                      32,768KHZ is present at Y5 on oscilloscpoe
                      RTCRST# has 3.3v @ CLRP2
                      RSMRST# 0v @ pin 100 f ec
                      ON/OFFBTN @ pin 32 has 3.3v when triggered goes 0v and goes 3.3v if released
                      PWRBTN_OUT# @ 117 has 3.3v if triggered the switch doesnt goes to 0v .
                      EC_ON @ 102 -3.3v
                      Ill also attched my backup...
                      04-29-2022, 09:22 PM
                    • admharsha7777
                      Dell Inspiron 3520 rsmrst missing Help
                      by admharsha7777
                      I have this Problem with Dell Inspiron 3520 40_DV15 MLK MB 11280 mother board,
                      I couldn't found board view for this board I have similar schematic currently board not turning on.
                      +RTC_VCC is ok
                      RTC_RST# 2.5V on q2102 drain pin, in this mosfet gate RTCRST_ON_ showing 0V also kbc RTCRST_ON is 0V
                      SRTC_RST# also 2.5V
                      3D3V_AUX_S5 is precent
                      S5_ENABLE is ok
                      5V_S5 is ok
                      3D3V_S5 is ok
                      Ac in# is 0V
                      +5VA_PCH_VCC5REFSUS i don't know where to check
                      PM_RSMRST# No voltage
                      AC_PRESENT...
                      10-05-2023, 02:37 AM
