Lenovo ideapad 100-15IBD battery issue
  • Spider1211
    • Oct 2019
    • 532
    • Mauritius
    Hey guys, I recently did a fresh install of windows 10 on a lenovo ideapad 100-15IBD. As soon as the freshly installed windows did its first boot I noticed the battery icon said "0% plugged in, not charging".
    The battery was working fine prior to fresh install. I tried installing drivers but no success.
    Doing a web search, this seems to be a common issue. I tried puling out battery + cmos battery, pressing power button and re-plugging everything back. On initial boot it say "plugged in, charging" but after a minute or so turns back to "0% plugged in, not charging". Restarting does not change anything. Tried uninstalling driver in windows manager, still nothing.
    Laptop shuts off when charger is removed.
    Battery amber led flashes quickly upon connecting charger (known good original charger used) but turns to a constant slow blink after a few seconds. As per documentation, this would indicate battery is less than 5%. I tried leaving it connected for a few hours but no luck.
    Any idea what could be wrong and any potential fix please?
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: Lenovo ideapad 100-15IBD battery issue
    As always first thing to be suspected is the battery itself.
    • Spider1211
      • Oct 2019
      • 532
      • Mauritius
      My thought exactly, but I unfortunately do not have a spare known good battery to test.
      The fact that this issue only started right after a fresh install is either purely coincidental that the battery died at that very same time or could be something software related?(given that it was working fine prior).
      • Duranitron
        • Jul 2014
        • 544
        • Philippines
        try to charge it without turning on the laptop. try also to uninstall the Microsoft ACPI-Compliant in device manager then restart the unit...
        Never stop LEARNING because life never stops TEACHING!
        • Spider1211
          • Oct 2019
          • 532
          • Mauritius
          Tried, but still same issue. Even tried charging with HDD disconnected. :/
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3627
            • slovakia
            measure voltage on battery when charging
            • Spider1211
              • Oct 2019
              • 532
              • Mauritius
              Forgot to mention in earlier post. I actually did measure voltage but forgot to post, sorry.
              When charger is initially plugged in, B+ voltage on battery connector can be seen oscillating between 16V and 0V for about 20 seconds and then stays at a few mV (typically 120- 160ish mV).
              I checked mosfets and caps near battery charging circuit but all seems OK. There also seems to be data activity on battery data line also.
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3627
                • slovakia
                16V is too much, u have probably shorted high side mosfet or something bad in charging circuit
                • Spider1211
                  • Oct 2019
                  • 532
                  • Mauritius
                  That was also my conclusion, but all mosfets seem ok and not shorted. But again, I am still a bit skeptic/confused regarding a possible hardware fault as the whole charging thing started right after a fresh windows install. I did read a few comments when browsing for a root cause that other people faced similar issue.
                  Or I might have just been "Lucky" and something related to battery died at the same time as fresh install
                    • 21874
                    Can you check the state of the battery with BatteryMon - https://www.passmark.com/products/batmon/
                    Did you install the lenovo ACPI driver - https://pcsupport.lenovo.com/gb/en/p...r%20Management
                    • Spider1211
                      • Oct 2019
                      • 532
                      • Mauritius
                      Yes, I did install this driver also but to no avail.
                      Thank you for the link. Will check same and report back at earliest.
                      • Spider1211
                        • Oct 2019
                        • 532
                        • Mauritius
                        Please find attached picture of battery monitor results.
                        Plugged in and charging -> result when windows first loads
                        Plugged in not charging -> result after 30ish seconds
                        • dellxps15
                          • Feb 2014
                          • 1598
                          • italy
                          u can use also hwinfo program and see what battery tells.
                          pc start with battery only ?
                          is there a reset botton for the battery ?
                          • Spider1211
                            • Oct 2019
                            • 532
                            • Mauritius
                            OK, I will try that at earliest.
                            No, it does not. Also, if it is ON and you pull AC out it just turns off.
                            Battery reset button? There is a reset button to go into lenovo recovey menu, tried that but no luck.
                            • Vesko356
                              VIP Moderator
                              • Aug 2018
                              • 4386
                              • Bulgaria 🇧🇬
                              Battery voltage = 0.808V.... This battery is just dead and needs to be replaced, try with known good one.
                              Become a Badcaps supporter
                              Thanks to all supporters.
                              • Spider1211
                                • Oct 2019
                                • 532
                                • Mauritius
                                I forgot to mention that I also ran lenovo diagnostics and it reported a healthy battery.
                                  • 21874
                                  Found a support article - Battery may discharge when laptop is powered off or in a sleep state - ThinkPad, ideapad
                                  https://pcsupport.lenovo.com/gb/en/p...tions/ht509457
                                  I don`t think its related to whats happened to your battery though. The BatteryMon Current capacity reading is wierd,how is it reading so low. Maybe a corrupt EC ? .Try another battery .
                                  • Spider1211
                                    • Oct 2019
                                    • 532
                                    • Mauritius
                                    Read that before posting, but unfortunately no luck. I will be returning the laptop to the person as is. It is not worth time and effort to go into EC stuff.
                                    I haven't ruled out a potentially bad battery (since everything seems to be pointing in that direction), especially the fluctuating voltage described in earlier post. Unfortunately I do not have a known good battery to test and confirm. If the person agrees to it, I might take the battery out and check for potentially dead/dying cells.
                                    Thank you guys for your help, appreciate it
                                    • Spider1211
                                      • Oct 2019
                                      • 532
                                      • Mauritius
                                      Update:
                                      Spoke to the owner and apparently he's been having battery issues for a while now but did not mention this(surprise surprise -_-). So, most likely it is a bad battery in this case and would need replacement.
                                      • code share
                                        Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
                                        by code share
                                        I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
                                        Here's what I've tried so far:
                                        • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
                                        • Booted successfully on AC power only with the battery disconnected
                                        • Visual inspection of the battery — no swelling, burn marks, or connector damage
                                        • Battery
                                        04-21-2025, 12:50 PM
                                      • mkdj
                                        ASUS X571 no power : battery issue?
                                        by mkdj
                                        Mark and model: ASUS X571
                                        Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                                        Tests already made:
                                        - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                                        - I have removed...
                                        07-14-2025, 09:16 AM
                                      • totof
                                        Lenovo Ideapad 3 15ALC6 motherboard issue
                                        by totof
                                        I have a Lenovo Ideapad 3-15ALC6 computer that I'm trying to repair.
                                        Initially, the computer wouldn't start, and there was no power consumption from the charger. The board itself is reference HS261&HS561&HS761 NM-D521 rev 3.0, where you can find the schematic and board view here: https://www.badcaps.net/forum/troubl...-hs761-nm-d521
                                        When I opened it, I noticed three burnt components near...
                                        10-26-2025, 10:27 AM
                                      • Bowline
                                        by Bowline
                                        06-11-2025, 10:13 AM
                                      • jared101
                                        Lenovo Ideapad 320-15IKA NM-B452 not charging battery
                                        by jared101
                                        NM-B452
                                        Hi guys. I've used the forum a lot but never asked questions before. I had a Lenovo come in that was shorted on the 20V rail. I fixed that and thought my job was done until I realized it wasn't charging the battery. Here is what I've checked so far
                                        On the BQ24780SRUYR charging ic
                                        VCC 20V
                                        SMBUS lines
                                        SDA 3.3V
                                        SCL 3.3V
                                        Current Sensing lines
                                        ACP/ACN 2.3 ohms
                                        SRP/SRN 21.2 ohms
                                        REGEN line 6V
                                        PHASE .84V with no battery installed(this may be normal)
                                        08-03-2022, 09:19 PM
