E5570 la-c841p rev 3.0 - charger / battery issues
  • Jdown79
    • Sep 2020
    • 9
    Hey guys, beginning to work on board level faults.
    Machine is our stock, came in not charging batt. Battery is brand new, tested in another machine as not faulty. In Bios, originally it would say Battery: Health excellent, Charging: Idle, AC adaptor: Unknown
    Using different genuine AC adaptors changed nothing.
    Opening up showed liquid damage, PU1 was burnt out, and PR823 had rust on it.
    Replaced PU1, no change. Replaced PR823, and the symptoms have changed.
    Now battery shows as not installed, and AC adaptor : unknown.
    I dont believe that either component is wrongly placed after staring at the board for however long.
    What IC's are responsible for the detection of genuine chargers? I think thats my next port of call.
    Thanks in advance.
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3592
    • slovakia
    Re: E5570 la-c841p rev 3.0 - charger / battery issues
    post schematic
    • Jdown79
      • Sep 2020
      • 9
      Aplogies, here we are.
      https://www.badcaps.net/forum/showth...04#post1053304
      • Techtiger
        • Oct 2014
        • 1602
        • france
        whats is the voltage on all pins of Battery Connector with battrey inserted
        PBAT_SMBCLK_C
        PBAT_PRES#_C
        PBAT_SMBDAT_C
        +PBATT
          VIP Moderator
          • Aug 2018
          • 4386
          • Bulgaria 🇧🇬
          Check resistance to ground in line NB_PSID first, then check continuity between NB_PSID and PS_ID. Are you sure PU1 is OK and is soldered correctly? You can unsolder PU1, and short pin3 to pin4 to check - if everything is OK (in the line) charger wattage must be detected in the BIOS, but furst check resistance to ground in NB_PSID line, there must be a reason for PU1 to burn (most probably someone is tried to power up the machine with HP adapter). If the resistance to ground is low in the NB_PSID line, check PD6 diode (most probably will be shorted).
          Become a Badcaps supporter
          Thanks to all supporters.​
          • Jdown79
            • Sep 2020
            • 9
            Originally posted by techtiger
            PBAT_SMBCLK_C - 3.2-3.3v
            PBAT_PRES#_C - 50mv
            PBAT_SMBDAT_C - 3.2-3.3v
            +PBATT - 11.8v
            • Jdown79
              • Sep 2020
              • 9
              Originally posted by Vesko356
              [B] check PD6 diode (most probably will be shorted).
              Full disclosure, unaware if I'm testing the diode correctly, bare with me.
              Third pin continuitity tests to ground, all 3 pins continuity test with each other.
              EDIT:Seems to be alive, passing .8v
                VIP Moderator
                • Aug 2018
                • 4386
                • Bulgaria 🇧🇬
                What 8v??? What voltage are you talking about? It's a Dell not HP. It's a data signal line, one wire signal communication protocol line between the charger (Dallas/Maxim DS2501 chip) and the MEC5085 chip. PD6 is placed for protection against voltage in that line! Pin 2 and 3 are common and are connected to NB_PSID line, pin 1 is connected to dround! See the diagram! If it's a continuity between pin 1 and 2+3 NB_PSID line is shorted to ground, so the line is shorted or not? If the line is shorted you must replace PD6 (it's a ESD protection diode). Or you can remove it just for testing (but must be replaced later). After that charger wattage must be detected in the BIOS (if you soldered PU1 correctly, if not remove it and short pin3 to pin4). Simple as that.
                • 469896rammy
                  • Jan 2020
                  • india
                  replace pu1
                  • 469896rammy
                    • Jan 2020
                    • india
                    voltages at pu1 pins
                    • wws911
                      • Apr 2020
                      • 10
                      • South Africa
                      i had the same issue
                      on a bench supplu i used 16,5v the batery worked
                        NVDC charger configuration...
                        11-05-2024, 03:28 PM
                        ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                        Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                        The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                        for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                        Narrow VDC applications where the system power source is
                        either the battery pack or the regulated output of the charger.
                        This makes the max voltage to the system equal to the max
                        battery voltage instead of the max adapter voltage. Operating
                        at lower system voltage can improve...
                        11-05-2024, 04:43 PM
                      • Bowline
                        by Bowline
                        06-11-2025, 10:13 AM
                        Milwaukee M18 HD12.0 (12 amp hour battery pack) unbalanced failure charger refusing
                        I have two Milwaukee 12 amp hours battery packs that have an issue with battery cells very unbalanced these are probably over 4 years old and been heavily used in the past but now get occasionally used heavily and when I went to use the grinder tool the battery lost battery battery power very quickly so I decided to open it up and found some battery cells voltage from 3.6 to 4.1 no wonder the battery charger was not fully charging them 3 out of 4 LEDs were on meaning that it was only 75% charged
                        So I have put them on the battery testing machine to drain each battery cell down to...
                        09-04-2022, 04:45 PM
                        Texas Instruments bq24745 bq24745RHDR bq24745RHDT Battery Charger IC for Laptop Computers Datasheet
                        The bq24745 bq24745RHDR bq24745RHDT is a high-efficiency, synchronous battery charger with an integrated input-current comparator, offering low component count for space-constrained, multi-chemistry battery-charging applications. The input-current, charge-current, and charge-voltage DACs allow very high regulation accuracies that can be easily programmed by the system power-management microcontroller using the SMBus interface. The bq24745 charges two, three, or four series Li+ cells, and is available in a 28-pin, 5-mm x 5 mm QFN package.
                        The bq24745 features dynamic power management...
                        10-23-2024, 02:50 AM
